Disk keypass refuse to work anymore
Hi everyone,
I’ve installed Qubes last week. Everything worked fine. This morning when I tried booting it, I cannot see the passkey I’m typing for the disk. F8 doesn’t work anymore and typing the passkey “blindly” doesn’t do anything.
Can you help me to solve this problem ?
As if your keyboard not working …
Do you have the default graphical password textfield and see no input?
What happens when you hit ESC? You should see the systemd output and be able to type your disc pw.
Yes, ESC bring to the terminal but nothing happen when I enter the passkey.
I really don’t know what could happened to end up like this.
I still see dots printing on screen when I type the passkey, but no way to modify what is displaying as before. I tried another usb keyboard and a ps2, same result.
Push ESC key. You will be in a terminal. At least you will see asteriks as you type password and you will see whatever it passed or not.
PS: I don’t see anything in a gui as I type almost from the beginning (years now).
Thank you for your reply. I usually do it without gui on FreeBSD and OpenBSD. This is the second time a Qubes installation end up like this on my pc. Maybe is it hardware related ? The first time I let go but this time I hoped someone could have a solution. For now I reinstalled a FreeBSD. Il will retry later.
