OS: R4.1
TemplateVM: fedora-35
Hello,
I am trying to install Discord on my TemplateVM to use is on the personal AppVM.
So I installed snap on the TemplateVM without any problems or errors. Then I restarted it and installed Discord via Snap.
After refreshing applications it also shows in the App shortcuts (for both, AppVM and TemplateVM). So I shutdown template, removed sys-firewall internet access and added shortcut in personal AppVM.
But now when I try to start Discord, the AppVM boots and nothing further happens. No GUI loading or any error messages.
The weird thing about this is, that I am able to start Discord successfully in the TemplateVM and I am able to use it there (for example logging in and chatting).
I also tried to use debian-11 and also created a new AppVM. Both without success.
So basicly I have 2 questions:
- Does anyone have this issue too or is able to fix this? I have absolutely 0 clue why this happens.
- If it is not possible to fix this, should I use Discord via this TemplateVM? For this I need internet access for this, but isn´t this a huge security issue or can this be ignored? (Internet access provided via sys-firewall and not directly via sys-net for sure :D)
Thanks in advance! <3
