Disabling Xen menu and custom plymouth
in other distributions there is no Xen menu showing up for 5 seconds after GRUB, how can i disable it or shorten the timeout?
there is also the boot option to show a plymouth screen like in Qubes with a loading bar, or terminal output. how can i make it show the terminal output like this picture
thanks.
sudo nano /etc/default/grub
and change
GRUB_TIMEOUT=5 to 0
GRUB_DEFAULT=saved to 0
Search rhgb in the GRUB_CMDLINE, remove it. you can also remove quiet for more boot log.
if you boot with uefi
sudo grub2-mkconfig -o /boot/efi/EFI/qubes/grub.cfg
bios legacy
perfect solution, thanks :slight_smile:
