This is how to use me_cleaner on the T480, but this will work on other laptops as well.
The main requirement is an eprom programmer, you are going to need to read and write the firmware eprom. The CH341a is a cheap ($10) option that should work with most roms, you are also going to need a clip to connect the programmer to the chip.
Read the ROM
First you need to dump the rom, if you don’t know how to find the EPROM search Google.
$ flashrom -p ch341a_spi -r firmware.rom
If this fails and return a list of possible chip types, then you need to specify the chip to be used, picking any chip from the list should work, you use -c to specify the chip type.
$ flashrom -p ch341a_spi -c MX25L12805D -r firmware.rom
Command output
flashrom v1.2 on Linux 5.15.0-48-generic (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Found Winbond flash chip "MX25L12805D" (16384 kB, SPI) on ch341a_spi.
Reading flash... done.
When you are able to read the firmware, you should read it 2-3 times and compare the files using the md5sum command. It’s very important that you have a valid and verified ROM dump, if you have multiple files with the same md5 checksum you know it is a valid dump.
NOT HAVING A VALID BACKUP CAN RESULT IN YOU BRICKING THE LAPTOP
$ md5sum firmware1.rom firmware2.rom firmware3.rom
Command output
3e83a431f807d483e63a7aae55c73b89 firmware1.rom
3e83a431f807d483e63a7aae55c73b89 firmware2.rom
3e83a431f807d483e63a7aae55c73b89 firmware3.rom
Cleaning the ROM
Cleaning the ROM on the T480 adds a 30 sec boot delay, unless you really want the ROM cleaned, you should use the HAP disable method.
All you need to do to clean the dump is use me_cleaner, it will create a new image with ME removed, which you can write to the firmware EPROM.
$ ~/src/me_cleaner/me_cleaner.py firmware.rom -S -O clean.rom
On newer versions of ME this is not likely to work without whitelisting ME modules, which is done with the -w option. On the T480, you need to whitelist DLMP and MFS.
$ ~/src/me_cleaner/me_cleaner.py firmware.rom -S -w DLMP,MFS -O clean.rom
Command output
Full image detected
Found FPT header at 0x3010
Found 11 partition(s)
Found FTPR header: FTPR partition spans from 0x1000 to 0xa8000
Found FTPR manifest at 0x1478
ME/TXE firmware version 11.8.92.4222 (generation 3)
Public key match: Intel ME, firmware versions 11.x.x.x
The HAP bit is NOT SET
Reading partitions list...
FTPR (0x00001000 - 0x0000a8000, 0x000a7000 total bytes): NOT removed
FTUP (0x00110000 - 0x0001bc000, 0x000ac000 total bytes): removed
DLMP (0x000a6000 - 0x0000a9000, 0x00003000 total bytes): NOT removed
PSVN (0x00000e00 - 0x000001000, 0x00000200 total bytes): removed
IVBP (0x0010c000 - 0x000110000, 0x00004000 total bytes): removed
MFS (0x000a8000 - 0x00010c000, 0x00064000 total bytes): NOT removed
NFTP (0x00110000 - 0x0001bc000, 0x000ac000 total bytes): removed
ROMB ( no data here , 0x00000000 total bytes): nothing to remove
FLOG (0x001bc000 - 0x0001bd000, 0x00001000 total bytes): removed
UTOK (0x001bd000 - 0x0001bf000, 0x00002000 total bytes): removed
ISHC ( no data here , 0x00000000 total bytes): nothing to remove
Removing partition entries in FPT...
Removing EFFS presence flag...
Correcting checksum (0x5e)...
Reading FTPR modules list...
FTPR.man (uncompressed, 0x001478 - 0x002064): NOT removed, partition manif.
rbe.met (uncompressed, 0x002064 - 0x0020fa): NOT removed, module metadata
fptemp.met (uncompressed, 0x0020fa - 0x002132): NOT removed, module metadata
kernel.met (uncompressed, 0x002132 - 0x0021c0): NOT removed, module metadata
syslib.met (uncompressed, 0x0021c0 - 0x002224): NOT removed, module metadata
bup.met (uncompressed, 0x002224 - 0x0027e6): NOT removed, module metadata
pm.met (uncompressed, 0x0027e6 - 0x002894): NOT removed, module metadata
vfs.met (uncompressed, 0x002894 - 0x0031c0): NOT removed, module metadata
evtdisp.met (uncompressed, 0x0031c0 - 0x00334e): NOT removed, module metadata
loadmgr.met (uncompressed, 0x00334e - 0x003476): NOT removed, module metadata
busdrv.met (uncompressed, 0x003476 - 0x0037fa): NOT removed, module metadata
gpio.met (uncompressed, 0x0037fa - 0x003944): NOT removed, module metadata
prtc.met (uncompressed, 0x003944 - 0x003af4): NOT removed, module metadata
policy.met (uncompressed, 0x003af4 - 0x003cb4): NOT removed, module metadata
crypto.met (uncompressed, 0x003cb4 - 0x003e3e): NOT removed, module metadata
heci.met (uncompressed, 0x003e3e - 0x00400a): NOT removed, module metadata
storage.met (uncompressed, 0x00400a - 0x004306): NOT removed, module metadata
pmdrv.met (uncompressed, 0x004306 - 0x00442a): NOT removed, module metadata
maestro.met (uncompressed, 0x00442a - 0x004514): NOT removed, module metadata
fpf.met (uncompressed, 0x004514 - 0x00462c): NOT removed, module metadata
hci.met (uncompressed, 0x00462c - 0x00472e): NOT removed, module metadata
fwupdate.met (uncompressed, 0x00472e - 0x004836): NOT removed, module metadata
ptt.met (uncompressed, 0x004836 - 0x004942): NOT removed, module metadata
touch_fw.met (uncompressed, 0x004942 - 0x004a80): NOT removed, module metadata
rbe (Huffman , 0x004a80 - 0x007940): NOT removed, essential
fptemp (LZMA/uncomp., 0x007940 - 0x009940): removed
kernel (Huffman , 0x009940 - 0x019980): NOT removed, essential
syslib (Huffman , 0x019980 - 0x02abc0): NOT removed, essential
bup (Huffman , 0x02abc0 - 0x0546c0): NOT removed, essential
pm (LZMA/uncomp., 0x0546c0 - 0x056980): removed
vfs (LZMA/uncomp., 0x056980 - 0x05ec80): removed
evtdisp (LZMA/uncomp., 0x05ec80 - 0x060640): removed
loadmgr (LZMA/uncomp., 0x060640 - 0x0634c0): removed
busdrv (LZMA/uncomp., 0x0634c0 - 0x064d40): removed
gpio (LZMA/uncomp., 0x064d40 - 0x065e40): removed
prtc (LZMA/uncomp., 0x065e40 - 0x0669c0): removed
policy (LZMA/uncomp., 0x0669c0 - 0x06b700): removed
crypto (LZMA/uncomp., 0x06b700 - 0x0793c0): removed
heci (LZMA/uncomp., 0x0793c0 - 0x07d280): removed
storage (LZMA/uncomp., 0x07d280 - 0x0816c0): removed
pmdrv (LZMA/uncomp., 0x0816c0 - 0x082840): removed
maestro (LZMA/uncomp., 0x082840 - 0x0845c0): removed
fpf (LZMA/uncomp., 0x0845c0 - 0x085f80): removed
hci (LZMA/uncomp., 0x085f80 - 0x086800): removed
fwupdate (LZMA/uncomp., 0x086800 - 0x08b540): removed
ptt (LZMA/uncomp., 0x08b540 - 0x0a0e80): removed
touch_fw (LZMA/uncomp., 0x0a0e80 - 0x0a8000): removed
The ME minimum size should be 1118208 bytes (0x111000 bytes)
The ME region can be reduced up to:
00003000:00113fff me
Setting the HAP bit in PCHSTRP0 to disable Intel ME...
Checking the FTPR RSA signature... VALID
Done! Good luck!
On other laptops, finding the modules you need to whitelist is going to require some trial and error. Adding all the modules from the partition list and removing them one at a time is one way to do it, but it does take some time because you need to flash the ROM multiple times.
HAP disabling ME
HAP disabling ME doesn’t modify the ME section of the ROM, it sets a bit in the Intel Flash Descriptor (IFD). Because it doesn’t delete the ROM content you don’t need to worry about whitelisting modules.
$ ~/src/me_cleaner/me_cleaner.py firmware.rom -s -O disabled.rom
Command output
Full image detected
Done! Good luck!
Write the ROM
When you have made an image with me_cleaner you just need to write it to the EPROM, and you are done.
$ flashrom -p ch341a_spi -c MX25L12805D -w new_firmware.rom
Command output
Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi.
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Unbrick your laptop
If the laptop is unable to boot, you can flash the original ROM, make sure you make a backup of the original ROM.
If you tried to clean the ROM, and it doesn’t work, you can always try to HAP disable ME.
