Created a new Fedora template cube, installed the WIFI driver on it. But after that, the virtual machine stopped running. Error in logs: “kvm: module verification failed: signature and/or required key missing - tainting kernel”
How can I disable the sign check for modules in the template so that they are loaded? Is it possible to use qvm-prefs for this, and can it be done without recompiling the kernel?
