Raist
January 17, 2024, 1:29am
1
Can anyone tell me why when running lscpu different vulnerability issues are listed between Dom0 and VMs? Its the same process shouldn’t it be identical?
Dom0
Vulnerabilities:
Gather data sampling: Not affected
Itlb multihit: KVM: Mitigation: VMX unsupported
L1tf: Mitigation; PTE Inversion
Mds: Mitigation; Clear CPU buffers; SMT Host state unknown
Meltdown: Unknown (XEN PV detected, hypervisor mitigation required)
Mmio stale data: Vulnerable: Clear CPU buffers attempted, no microcode; SMT Host state unknown
Retbleed: Mitigation; IBRS
Spec rstack overflow: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; IBRS, IBPB conditional, STIBP conditional, RSB filling, PBRSB-eIBRS Not affected
Srbds: Unknown: Dependent on hypervisor status
Tsx async abort: Not affected
VS
VM Qube
Vulnerabilities:
Meltdown: Mitigation; PTI
Mmio stale data: Mitigation; Clear CPU buffers; SMT Host state unknown
sanitization
Spectre v2: Mitigation; IBRS, IBPB conditional, RSB filling, PBRSB-
eIBRS Not affected
This might because of the different virt modes. dom0 is PV, domU is
default PVH (edit: except when PCI passthrough is required).
Try creating a PV domU and post the results. Also, what virt mode is
the “VM qube”?
Note: I do not recommend ever using PV
outside of a testing setup, like for answering this question.
Raist
January 18, 2024, 1:48am
3
template and app vm’s are all PVH by default, if Dom0 is also PVH you think they’d give the same results. I’ve found other discrepancies as well so I hope someone can address this as I’m not sure if i should reload my machine or what is going on and I feel like it could be a security issue.
so far I’ve found the original post issue with the vuln listed differently. I’ve also found lscpu differences and SMT differences. For example lscpu in dom0 pulls 4 threads per core which is not expected behavior for my CPU with SMT turned off. Template/App VM lscpu does return the expected values for a machine with SMT turned off.
[Qube@dom0 ~]$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 39 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Vendor ID: GenuineIntel
Model name: Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz
CPU family: 6
Model: 142
Thread(s) per core: 4
Core(s) per socket: 1
Socket(s): 1
Stepping: 10
BogoMIPS: 3791.99
[user@fedora-38-xfce ~]$ lscpu
CPU(s): 2
On-line CPU(s) list: 0,1
CPU family: 6
Model: 142
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Stepping: 10
BogoMIPS: 3791.99
further confirmed by cat /sys/devices/system/cpu/smt/active if SMT is active it returns value 1, if not active it returns value 0. Dom0 returns 1 and template/app VM return value 0. Value 0 is the expected behavior as SMT should be disabled globally by default.
I searched lscpu in the forums to find others peoples results in the past. In the past Dom0 has returned expected value for other users so that leads me to believe something is wrong. Either something is currently bugged or it’s my machine specifically but since I’ve changed basically nothing since the fresh install idk what I could have possibly done.
Please post your xen boot params to ensure that smt
did not somehow get set to ‘on’.
dom0 is PV in qubes, but this could change
in the future
Raist
January 18, 2024, 5:49pm
5
I’m not sure if this is what you’re looking for I’m pretty new to terminal, if you need another cmd ran let me know.
[Qube@dom0 ~]$ sudo sysctl -a
abi.vsyscall32 = 1
crypto.fips_enabled = 0
crypto.fips_name = Linux Kernel Cryptographic API
crypto.fips_version = 6.6.9-1.qubes.fc37.x86_64
debug.exception-trace = 1
debug.kprobes-optimization = 1
dev.cdrom.autoclose = 1
dev.cdrom.autoeject = 0
dev.cdrom.check_media = 0
dev.cdrom.debug = 0
dev.cdrom.info = CD-ROM information, Id: cdrom.c 3.20 2003/12/17
dev.cdrom.info =
dev.cdrom.info = drive name:
dev.cdrom.info = drive speed:
dev.cdrom.info = drive # of slots:
dev.cdrom.info = Can close tray:
dev.cdrom.info = Can open tray:
dev.cdrom.info = Can lock tray:
dev.cdrom.info = Can change speed:
dev.cdrom.info = Can select disk:
dev.cdrom.info = Can read multisession:
dev.cdrom.info = Can read MCN:
dev.cdrom.info = Reports media changed:
dev.cdrom.info = Can play audio:
dev.cdrom.info = Can write CD-R:
dev.cdrom.info = Can write CD-RW:
dev.cdrom.info = Can read DVD:
dev.cdrom.info = Can write DVD-R:
dev.cdrom.info = Can write DVD-RAM:
dev.cdrom.info = Can read MRW:
dev.cdrom.info = Can write MRW:
dev.cdrom.info = Can write RAM:
dev.cdrom.info =
dev.cdrom.info =
dev.cdrom.lock = 1
dev.hpet.max-user-freq = 64
dev.i915.oa_max_sample_rate = 100000
dev.i915.perf_stream_paranoid = 1
dev.mac_hid.mouse_button2_keycode = 97
dev.mac_hid.mouse_button3_keycode = 100
dev.mac_hid.mouse_button_emulation = 0
dev.raid.speed_limit_max = 200000
dev.raid.speed_limit_min = 1000
dev.scsi.logging_level = 0
dev.tty.ldisc_autoload = 1
dev.tty.legacy_tiocsti = 0
fs.aio-max-nr = 1048576
fs.aio-nr = 0
fs.binfmt_misc.status = enabled
fs.dentry-state = 29360 21073 45 0 7871 0
fs.dir-notify-enable = 1
fs.epoll.max_user_watches = 878525
fs.fanotify.max_queued_events = 16384
fs.fanotify.max_user_groups = 128
fs.fanotify.max_user_marks = 31970
fs.file-max = 9223372036854775807
fs.file-nr = 7392 0 9223372036854775807
fs.inode-nr = 21960 480
fs.inode-state = 21960 480 0 0 0 0 0
fs.inotify.max_queued_events = 16384
fs.inotify.max_user_instances = 128
fs.inotify.max_user_watches = 30067
fs.lease-break-time = 45
fs.leases-enable = 1
fs.mount-max = 100000
fs.mqueue.msg_default = 10
fs.mqueue.msg_max = 10
fs.mqueue.msgsize_default = 8192
fs.mqueue.msgsize_max = 8192
fs.mqueue.queues_max = 256
fs.nr_open = 1073741816
fs.overflowgid = 65534
fs.overflowuid = 65534
fs.pipe-max-size = 1048576
fs.pipe-user-pages-hard = 0
fs.pipe-user-pages-soft = 16384
fs.protected_fifos = 1
fs.protected_hardlinks = 1
fs.protected_regular = 1
fs.protected_symlinks = 1
fs.quota.allocated_dquots = 0
fs.quota.cache_hits = 0
fs.quota.drops = 0
fs.quota.free_dquots = 0
fs.quota.lookups = 0
fs.quota.reads = 0
fs.quota.syncs = 0
fs.quota.writes = 0
fs.suid_dumpable = 2
kernel.acct = 4 2 30
kernel.acpi_video_flags = 0
kernel.arch = x86_64
kernel.auto_msgmni = 0
kernel.bootloader_type = 144
kernel.bootloader_version = 0
kernel.bpf_stats_enabled = 0
kernel.cad_pid = 1
kernel.cap_last_cap = 40
kernel.core_pattern = |/usr/lib/systemd/systemd-coredump %P %u %g %s %t %c %h
kernel.core_pipe_limit = 16
kernel.core_uses_pid = 1
kernel.ctrl-alt-del = 0
kernel.dmesg_restrict = 1
kernel.domainname = (none)
kernel.firmware_config.force_sysfs_fallback = 0
kernel.firmware_config.ignore_sysfs_fallback = 0
kernel.ftrace_dump_on_oops = 0
kernel.ftrace_enabled = 1
kernel.hardlockup_all_cpu_backtrace = 0
kernel.hardlockup_panic = 0
kernel.hostname = dom0
kernel.io_delay_type = 0
kernel.io_uring_disabled = 0
kernel.io_uring_group = -1
kernel.kexec_load_disabled = 0
kernel.kexec_load_limit_panic = -1
kernel.kexec_load_limit_reboot = -1
kernel.keys.gc_delay = 300
kernel.keys.maxbytes = 20000
kernel.keys.maxkeys = 200
kernel.keys.persistent_keyring_expiry = 259200
kernel.keys.root_maxbytes = 25000000
kernel.keys.root_maxkeys = 1000000
kernel.kptr_restrict = 0
kernel.latencytop = 0
kernel.max_lock_depth = 1024
kernel.max_rcu_stall_to_panic = 0
kernel.modprobe = /sbin/modprobe
kernel.modules_disabled = 0
kernel.msg_next_id = -1
kernel.msgmax = 8192
kernel.msgmnb = 16384
kernel.msgmni = 32000
kernel.ngroups_max = 65536
kernel.nmi_watchdog = 0
kernel.ns_last_pid = 8674
kernel.numa_balancing = 0
kernel.numa_balancing_promote_rate_limit_MBps = 65536
kernel.oops_all_cpu_backtrace = 0
kernel.oops_limit = 10000
kernel.osrelease = 6.6.9-1.qubes.fc37.x86_64
kernel.ostype = Linux
kernel.overflowgid = 65534
kernel.overflowuid = 65534
kernel.panic = -1
kernel.panic_on_io_nmi = 0
kernel.panic_on_oops = 1
kernel.panic_on_rcu_stall = 0
kernel.panic_on_unrecovered_nmi = 0
kernel.panic_on_warn = 0
kernel.panic_print = 0
kernel.perf_cpu_time_max_percent = 25
kernel.perf_event_max_contexts_per_stack = 8
kernel.perf_event_max_sample_rate = 100000
kernel.perf_event_max_stack = 127
kernel.perf_event_mlock_kb = 516
kernel.perf_event_paranoid = 2
kernel.pid_max = 4194304
kernel.poweroff_cmd = /sbin/poweroff
kernel.print-fatal-signals = 0
kernel.printk = 3 4 1 7
kernel.printk_delay = 0
kernel.printk_devkmsg = on
kernel.printk_ratelimit = 5
kernel.printk_ratelimit_burst = 10
kernel.pty.max = 4096
kernel.pty.nr = 9
kernel.pty.reserve = 1024
kernel.random.boot_id = 988fc31a-df48-4317-8bb1-8d527743782c
kernel.random.entropy_avail = 256
kernel.random.poolsize = 256
kernel.random.urandom_min_reseed_secs = 60
kernel.random.uuid = 05d9a956-e1ac-4af7-86ab-03554085f085
kernel.random.write_wakeup_threshold = 256
kernel.randomize_va_space = 2
kernel.real-root-dev = 0
kernel.sched_autogroup_enabled = 1
kernel.sched_cfs_bandwidth_slice_us = 5000
kernel.sched_child_runs_first = 0
kernel.sched_deadline_period_max_us = 4194304
kernel.sched_deadline_period_min_us = 100
kernel.sched_energy_aware = 1
kernel.sched_rr_timeslice_ms = 100
kernel.sched_rt_period_us = 1000000
kernel.sched_rt_runtime_us = 950000
kernel.sched_schedstats = 0
kernel.sched_util_clamp_max = 1024
kernel.sched_util_clamp_min = 1024
kernel.sched_util_clamp_min_rt_default = 1024
kernel.seccomp.actions_avail = kill_process kill_thread trap errno user_notif trace log allow
kernel.seccomp.actions_logged = kill_process kill_thread trap errno user_notif trace log
kernel.sem = 32000 1024000000 500 32000
kernel.sem_next_id = -1
kernel.shm_next_id = -1
kernel.shm_rmid_forced = 0
kernel.shmall = 18446744073692774399
kernel.shmmax = 18446744073692774399
kernel.shmmni = 4096
kernel.soft_watchdog = 1
kernel.softlockup_all_cpu_backtrace = 0
kernel.softlockup_panic = 0
kernel.split_lock_mitigate = 1
kernel.stack_tracer_enabled = 0
kernel.sysctl_writes_strict = 1
kernel.sysrq = 16
kernel.tainted = 0
kernel.task_delayacct = 0
kernel.threads-max = 30832
kernel.timer_migration = 1
kernel.traceoff_on_warning = 0
kernel.tracepoint_printk = 0
kernel.unknown_nmi_panic = 0
kernel.unprivileged_bpf_disabled = 2
kernel.usermodehelper.bset = 4294967295 511
kernel.usermodehelper.inheritable = 4294967295 511
kernel.version = #1 SMP PREEMPT_DYNAMIC Sun Jan 7 17:14:59 GMT 2024
kernel.warn_limit = 0
kernel.watchdog = 1
kernel.watchdog_cpumask = 0-3
kernel.watchdog_thresh = 10
kernel.yama.ptrace_scope = 0
net.core.bpf_jit_enable = 1
net.core.bpf_jit_harden = 0
net.core.bpf_jit_kallsyms = 1
net.core.bpf_jit_limit = 528482304
net.core.busy_poll = 0
net.core.busy_read = 0
net.core.default_qdisc = fq_codel
net.core.dev_weight = 64
net.core.dev_weight_rx_bias = 1
net.core.dev_weight_tx_bias = 1
net.core.devconf_inherit_init_net = 0
net.core.fb_tunnels_only_for_init_net = 0
net.core.flow_limit_cpu_bitmap = 0
net.core.flow_limit_table_len = 4096
net.core.gro_normal_batch = 8
net.core.high_order_alloc_disable = 0
net.core.max_skb_frags = 17
net.core.message_burst = 10
net.core.message_cost = 5
net.core.netdev_budget = 300
net.core.netdev_budget_usecs = 2000
net.core.netdev_max_backlog = 1000
net.core.netdev_rss_key = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
net.core.netdev_tstamp_prequeue = 1
net.core.netdev_unregister_timeout_secs = 10
net.core.optmem_max = 81920
net.core.rmem_default = 212992
net.core.rmem_max = 212992
net.core.rps_default_mask = 0
net.core.rps_sock_flow_entries = 0
net.core.skb_defer_max = 64
net.core.somaxconn = 4096
net.core.tstamp_allow_data = 1
net.core.txrehash = 1
net.core.warnings = 0
net.core.wmem_default = 212992
net.core.wmem_max = 212992
net.core.xfrm_acq_expires = 30
net.core.xfrm_aevent_etime = 10
net.core.xfrm_aevent_rseqth = 2
net.core.xfrm_larval_drop = 1
net.ipv4.cipso_cache_bucket_size = 10
net.ipv4.cipso_cache_enable = 1
net.ipv4.cipso_rbm_optfmt = 0
net.ipv4.cipso_rbm_strictvalid = 1
net.ipv4.conf.all.accept_local = 0
net.ipv4.conf.all.accept_redirects = 1
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.conf.all.arp_accept = 0
net.ipv4.conf.all.arp_announce = 0
net.ipv4.conf.all.arp_evict_nocarrier = 1
net.ipv4.conf.all.arp_filter = 0
net.ipv4.conf.all.arp_ignore = 0
net.ipv4.conf.all.arp_notify = 0
net.ipv4.conf.all.bc_forwarding = 0
net.ipv4.conf.all.bootp_relay = 0
net.ipv4.conf.all.disable_policy = 0
net.ipv4.conf.all.disable_xfrm = 0
net.ipv4.conf.all.drop_gratuitous_arp = 0
net.ipv4.conf.all.drop_unicast_in_l2_multicast = 0
net.ipv4.conf.all.force_igmp_version = 0
net.ipv4.conf.all.forwarding = 0
net.ipv4.conf.all.igmpv2_unsolicited_report_interval = 10000
net.ipv4.conf.all.igmpv3_unsolicited_report_interval = 1000
net.ipv4.conf.all.ignore_routes_with_linkdown = 0
net.ipv4.conf.all.log_martians = 0
net.ipv4.conf.all.mc_forwarding = 0
net.ipv4.conf.all.medium_id = 0
net.ipv4.conf.all.promote_secondaries = 0
net.ipv4.conf.all.proxy_arp = 0
net.ipv4.conf.all.proxy_arp_pvlan = 0
net.ipv4.conf.all.route_localnet = 0
net.ipv4.conf.all.rp_filter = 0
net.ipv4.conf.all.secure_redirects = 1
net.ipv4.conf.all.send_redirects = 1
net.ipv4.conf.all.shared_media = 1
net.ipv4.conf.all.src_valid_mark = 0
net.ipv4.conf.all.tag = 0
net.ipv4.conf.default.accept_local = 0
net.ipv4.conf.default.accept_redirects = 1
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.default.arp_accept = 0
net.ipv4.conf.default.arp_announce = 0
net.ipv4.conf.default.arp_evict_nocarrier = 1
net.ipv4.conf.default.arp_filter = 0
net.ipv4.conf.default.arp_ignore = 0
net.ipv4.conf.default.arp_notify = 0
net.ipv4.conf.default.bc_forwarding = 0
net.ipv4.conf.default.bootp_relay = 0
net.ipv4.conf.default.disable_policy = 0
net.ipv4.conf.default.disable_xfrm = 0
net.ipv4.conf.default.drop_gratuitous_arp = 0
net.ipv4.conf.default.drop_unicast_in_l2_multicast = 0
net.ipv4.conf.default.force_igmp_version = 0
net.ipv4.conf.default.forwarding = 0
net.ipv4.conf.default.igmpv2_unsolicited_report_interval = 10000
net.ipv4.conf.default.igmpv3_unsolicited_report_interval = 1000
net.ipv4.conf.default.ignore_routes_with_linkdown = 0
net.ipv4.conf.default.log_martians = 0
net.ipv4.conf.default.mc_forwarding = 0
net.ipv4.conf.default.medium_id = 0
net.ipv4.conf.default.promote_secondaries = 1
net.ipv4.conf.default.proxy_arp = 0
net.ipv4.conf.default.proxy_arp_pvlan = 0
net.ipv4.conf.default.route_localnet = 0
net.ipv4.conf.default.rp_filter = 2
net.ipv4.conf.default.secure_redirects = 1
net.ipv4.conf.default.send_redirects = 1
net.ipv4.conf.default.shared_media = 1
net.ipv4.conf.default.src_valid_mark = 0
net.ipv4.conf.default.tag = 0
net.ipv4.conf.lo.accept_local = 0
net.ipv4.conf.lo.accept_redirects = 1
net.ipv4.conf.lo.accept_source_route = 0
net.ipv4.conf.lo.arp_accept = 0
net.ipv4.conf.lo.arp_announce = 0
net.ipv4.conf.lo.arp_evict_nocarrier = 1
net.ipv4.conf.lo.arp_filter = 0
net.ipv4.conf.lo.arp_ignore = 0
net.ipv4.conf.lo.arp_notify = 0
net.ipv4.conf.lo.bc_forwarding = 0
net.ipv4.conf.lo.bootp_relay = 0
net.ipv4.conf.lo.disable_policy = 1
net.ipv4.conf.lo.disable_xfrm = 1
net.ipv4.conf.lo.drop_gratuitous_arp = 0
net.ipv4.conf.lo.drop_unicast_in_l2_multicast = 0
net.ipv4.conf.lo.force_igmp_version = 0
net.ipv4.conf.lo.forwarding = 0
net.ipv4.conf.lo.igmpv2_unsolicited_report_interval = 10000
net.ipv4.conf.lo.igmpv3_unsolicited_report_interval = 1000
net.ipv4.conf.lo.ignore_routes_with_linkdown = 0
net.ipv4.conf.lo.log_martians = 0
net.ipv4.conf.lo.mc_forwarding = 0
net.ipv4.conf.lo.medium_id = 0
net.ipv4.conf.lo.promote_secondaries = 1
net.ipv4.conf.lo.proxy_arp = 0
net.ipv4.conf.lo.proxy_arp_pvlan = 0
net.ipv4.conf.lo.route_localnet = 0
net.ipv4.conf.lo.rp_filter = 2
net.ipv4.conf.lo.secure_redirects = 1
net.ipv4.conf.lo.send_redirects = 1
net.ipv4.conf.lo.shared_media = 1
net.ipv4.conf.lo.src_valid_mark = 0
net.ipv4.conf.lo.tag = 0
net.ipv4.fib_multipath_hash_fields = 7
net.ipv4.fib_multipath_hash_policy = 0
net.ipv4.fib_multipath_use_neigh = 0
net.ipv4.fib_notify_on_flag_change = 0
net.ipv4.fib_sync_mem = 524288
net.ipv4.fwmark_reflect = 0
net.ipv4.icmp_echo_enable_probe = 0
net.ipv4.icmp_echo_ignore_all = 0
net.ipv4.icmp_echo_ignore_broadcasts = 1
net.ipv4.icmp_errors_use_inbound_ifaddr = 0
net.ipv4.icmp_ignore_bogus_error_responses = 1
net.ipv4.icmp_msgs_burst = 50
net.ipv4.icmp_msgs_per_sec = 1000
net.ipv4.icmp_ratelimit = 1000
net.ipv4.icmp_ratemask = 6168
net.ipv4.igmp_link_local_mcast_reports = 1
net.ipv4.igmp_max_memberships = 20
net.ipv4.igmp_max_msf = 10
net.ipv4.igmp_qrv = 2
net.ipv4.inet_peer_maxttl = 600
net.ipv4.inet_peer_minttl = 120
net.ipv4.inet_peer_threshold = 65664
net.ipv4.ip_autobind_reuse = 0
net.ipv4.ip_default_ttl = 64
net.ipv4.ip_dynaddr = 0
net.ipv4.ip_early_demux = 1
net.ipv4.ip_forward = 0
net.ipv4.ip_forward_update_priority = 1
net.ipv4.ip_forward_use_pmtu = 0
net.ipv4.ip_local_port_range = 32768 60999
net.ipv4.ip_local_reserved_ports =
net.ipv4.ip_no_pmtu_disc = 0
net.ipv4.ip_nonlocal_bind = 0
net.ipv4.ip_unprivileged_port_start = 1024
net.ipv4.ipfrag_high_thresh = 4194304
net.ipv4.ipfrag_low_thresh = 3145728
net.ipv4.ipfrag_max_dist = 64
net.ipv4.ipfrag_secret_interval = 0
net.ipv4.ipfrag_time = 30
net.ipv4.neigh.default.anycast_delay = 100
net.ipv4.neigh.default.app_solicit = 0
net.ipv4.neigh.default.base_reachable_time_ms = 30000
net.ipv4.neigh.default.delay_first_probe_time = 5
net.ipv4.neigh.default.gc_interval = 30
net.ipv4.neigh.default.gc_stale_time = 60
net.ipv4.neigh.default.gc_thresh1 = 128
net.ipv4.neigh.default.gc_thresh2 = 512
net.ipv4.neigh.default.gc_thresh3 = 1024
net.ipv4.neigh.default.interval_probe_time_ms = 5000
net.ipv4.neigh.default.locktime = 100
net.ipv4.neigh.default.mcast_resolicit = 0
net.ipv4.neigh.default.mcast_solicit = 3
net.ipv4.neigh.default.proxy_delay = 80
net.ipv4.neigh.default.proxy_qlen = 64
net.ipv4.neigh.default.retrans_time_ms = 1000
net.ipv4.neigh.default.ucast_solicit = 3
net.ipv4.neigh.default.unres_qlen = 101
net.ipv4.neigh.default.unres_qlen_bytes = 212992
net.ipv4.neigh.lo.anycast_delay = 100
net.ipv4.neigh.lo.app_solicit = 0
net.ipv4.neigh.lo.base_reachable_time_ms = 30000
net.ipv4.neigh.lo.delay_first_probe_time = 5
net.ipv4.neigh.lo.gc_stale_time = 60
net.ipv4.neigh.lo.interval_probe_time_ms = 5000
net.ipv4.neigh.lo.locktime = 100
net.ipv4.neigh.lo.mcast_resolicit = 0
net.ipv4.neigh.lo.mcast_solicit = 3
net.ipv4.neigh.lo.proxy_delay = 80
net.ipv4.neigh.lo.proxy_qlen = 64
net.ipv4.neigh.lo.retrans_time_ms = 1000
net.ipv4.neigh.lo.ucast_solicit = 3
net.ipv4.neigh.lo.unres_qlen = 101
net.ipv4.neigh.lo.unres_qlen_bytes = 212992
net.ipv4.nexthop_compat_mode = 1
net.ipv4.ping_group_range = 0 2147483647
net.ipv4.raw_l3mdev_accept = 1
net.ipv4.route.error_burst = 5000
net.ipv4.route.error_cost = 1000
net.ipv4.route.gc_elasticity = 8
net.ipv4.route.gc_interval = 60
net.ipv4.route.gc_min_interval = 0
net.ipv4.route.gc_min_interval_ms = 500
net.ipv4.route.gc_thresh = -1
net.ipv4.route.gc_timeout = 300
net.ipv4.route.max_size = 2147483647
net.ipv4.route.min_adv_mss = 256
net.ipv4.route.min_pmtu = 552
net.ipv4.route.mtu_expires = 600
net.ipv4.route.redirect_load = 20
net.ipv4.route.redirect_number = 9
net.ipv4.route.redirect_silence = 20480
net.ipv4.tcp_abort_on_overflow = 0
net.ipv4.tcp_adv_win_scale = 1
net.ipv4.tcp_allowed_congestion_control = reno cubic
net.ipv4.tcp_app_win = 31
net.ipv4.tcp_autocorking = 1
net.ipv4.tcp_available_congestion_control = reno cubic
net.ipv4.tcp_available_ulp = espintcp mptcp
net.ipv4.tcp_base_mss = 1024
net.ipv4.tcp_challenge_ack_limit = 2147483647
net.ipv4.tcp_child_ehash_entries = 0
net.ipv4.tcp_comp_sack_delay_ns = 1000000
net.ipv4.tcp_comp_sack_nr = 44
net.ipv4.tcp_comp_sack_slack_ns = 100000
net.ipv4.tcp_congestion_control = cubic
net.ipv4.tcp_dsack = 1
net.ipv4.tcp_early_demux = 1
net.ipv4.tcp_early_retrans = 3
net.ipv4.tcp_ecn = 2
net.ipv4.tcp_ecn_fallback = 1
net.ipv4.tcp_ehash_entries = 32768
net.ipv4.tcp_fack = 0
net.ipv4.tcp_fastopen = 1
net.ipv4.tcp_fastopen_blackhole_timeout_sec = 0
net.ipv4.tcp_fastopen_key = 00000000-00000000-00000000-00000000
net.ipv4.tcp_fin_timeout = 60
net.ipv4.tcp_frto = 2
net.ipv4.tcp_fwmark_accept = 0
net.ipv4.tcp_invalid_ratelimit = 500
net.ipv4.tcp_keepalive_intvl = 75
net.ipv4.tcp_keepalive_probes = 9
net.ipv4.tcp_keepalive_time = 7200
net.ipv4.tcp_l3mdev_accept = 0
net.ipv4.tcp_limit_output_bytes = 1048576
net.ipv4.tcp_low_latency = 0
net.ipv4.tcp_max_orphans = 16384
net.ipv4.tcp_max_reordering = 300
net.ipv4.tcp_max_syn_backlog = 256
net.ipv4.tcp_max_tw_buckets = 16384
net.ipv4.tcp_mem = 46062 61417 92124
net.ipv4.tcp_migrate_req = 0
net.ipv4.tcp_min_rtt_wlen = 300
net.ipv4.tcp_min_snd_mss = 48
net.ipv4.tcp_min_tso_segs = 2
net.ipv4.tcp_moderate_rcvbuf = 1
net.ipv4.tcp_mtu_probe_floor = 48
net.ipv4.tcp_mtu_probing = 0
net.ipv4.tcp_no_metrics_save = 0
net.ipv4.tcp_no_ssthresh_metrics_save = 1
net.ipv4.tcp_notsent_lowat = 4294967295
net.ipv4.tcp_orphan_retries = 0
net.ipv4.tcp_pacing_ca_ratio = 120
net.ipv4.tcp_pacing_ss_ratio = 200
net.ipv4.tcp_plb_cong_thresh = 128
net.ipv4.tcp_plb_enabled = 0
net.ipv4.tcp_plb_idle_rehash_rounds = 3
net.ipv4.tcp_plb_rehash_rounds = 12
net.ipv4.tcp_plb_suspend_rto_sec = 60
net.ipv4.tcp_probe_interval = 600
net.ipv4.tcp_probe_threshold = 8
net.ipv4.tcp_recovery = 1
net.ipv4.tcp_reflect_tos = 0
net.ipv4.tcp_reordering = 3
net.ipv4.tcp_retrans_collapse = 1
net.ipv4.tcp_retries1 = 3
net.ipv4.tcp_retries2 = 15
net.ipv4.tcp_rfc1337 = 0
net.ipv4.tcp_rmem = 4096 131072 6291456
net.ipv4.tcp_sack = 1
net.ipv4.tcp_shrink_window = 0
net.ipv4.tcp_slow_start_after_idle = 1
net.ipv4.tcp_stdurg = 0
net.ipv4.tcp_syn_linear_timeouts = 4
net.ipv4.tcp_syn_retries = 6
net.ipv4.tcp_synack_retries = 5
net.ipv4.tcp_syncookies = 1
net.ipv4.tcp_thin_linear_timeouts = 0
net.ipv4.tcp_timestamps = 1
net.ipv4.tcp_tso_rtt_log = 9
net.ipv4.tcp_tso_win_divisor = 3
net.ipv4.tcp_tw_reuse = 2
net.ipv4.tcp_window_scaling = 1
net.ipv4.tcp_wmem = 4096 16384 4194304
net.ipv4.tcp_workaround_signed_windows = 0
net.ipv4.udp_child_hash_entries = 0
net.ipv4.udp_early_demux = 1
net.ipv4.udp_hash_entries = 2048
net.ipv4.udp_l3mdev_accept = 0
net.ipv4.udp_mem = 92124 122834 184248
net.ipv4.udp_rmem_min = 4096
net.ipv4.udp_wmem_min = 4096
net.ipv4.xfrm4_gc_thresh = 32768
net.ipv6.anycast_src_echo_reply = 0
net.ipv6.auto_flowlabels = 1
net.ipv6.bindv6only = 0
net.ipv6.calipso_cache_bucket_size = 10
net.ipv6.calipso_cache_enable = 1
net.ipv6.conf.all.accept_dad = 0
net.ipv6.conf.all.accept_ra = 1
net.ipv6.conf.all.accept_ra_defrtr = 1
net.ipv6.conf.all.accept_ra_from_local = 0
net.ipv6.conf.all.accept_ra_min_hop_limit = 1
net.ipv6.conf.all.accept_ra_min_lft = 0
net.ipv6.conf.all.accept_ra_mtu = 1
net.ipv6.conf.all.accept_ra_pinfo = 1
net.ipv6.conf.all.accept_ra_rt_info_max_plen = 0
net.ipv6.conf.all.accept_ra_rt_info_min_plen = 0
net.ipv6.conf.all.accept_ra_rtr_pref = 1
net.ipv6.conf.all.accept_redirects = 1
net.ipv6.conf.all.accept_source_route = 0
net.ipv6.conf.all.accept_untracked_na = 0
net.ipv6.conf.all.addr_gen_mode = 0
net.ipv6.conf.all.autoconf = 1
net.ipv6.conf.all.dad_transmits = 1
net.ipv6.conf.all.disable_ipv6 = 0
net.ipv6.conf.all.disable_policy = 0
net.ipv6.conf.all.drop_unicast_in_l2_multicast = 0
net.ipv6.conf.all.drop_unsolicited_na = 0
net.ipv6.conf.all.enhanced_dad = 1
net.ipv6.conf.all.force_mld_version = 0
net.ipv6.conf.all.force_tllao = 0
net.ipv6.conf.all.forwarding = 0
net.ipv6.conf.all.hop_limit = 64
net.ipv6.conf.all.ignore_routes_with_linkdown = 0
net.ipv6.conf.all.ioam6_enabled = 0
net.ipv6.conf.all.ioam6_id = 65535
net.ipv6.conf.all.ioam6_id_wide = 4294967295
net.ipv6.conf.all.keep_addr_on_down = 0
net.ipv6.conf.all.max_addresses = 16
net.ipv6.conf.all.max_desync_factor = 600
net.ipv6.conf.all.mc_forwarding = 0
net.ipv6.conf.all.mldv1_unsolicited_report_interval = 10000
net.ipv6.conf.all.mldv2_unsolicited_report_interval = 1000
net.ipv6.conf.all.mtu = 1280
net.ipv6.conf.all.ndisc_evict_nocarrier = 1
net.ipv6.conf.all.ndisc_notify = 0
net.ipv6.conf.all.ndisc_tclass = 0
net.ipv6.conf.all.optimistic_dad = 0
net.ipv6.conf.all.proxy_ndp = 0
net.ipv6.conf.all.ra_defrtr_metric = 1024
net.ipv6.conf.all.regen_max_retry = 3
net.ipv6.conf.all.router_probe_interval = 60
net.ipv6.conf.all.router_solicitation_delay = 1
net.ipv6.conf.all.router_solicitation_interval = 4
net.ipv6.conf.all.router_solicitation_max_interval = 3600
net.ipv6.conf.all.router_solicitations = -1
net.ipv6.conf.all.rpl_seg_enabled = 0
net.ipv6.conf.all.seg6_enabled = 0
net.ipv6.conf.all.seg6_require_hmac = 0
net.ipv6.conf.all.suppress_frag_ndisc = 1
net.ipv6.conf.all.temp_prefered_lft = 86400
net.ipv6.conf.all.temp_valid_lft = 604800
net.ipv6.conf.all.use_oif_addrs_only = 0
net.ipv6.conf.all.use_optimistic = 0
net.ipv6.conf.all.use_tempaddr = 0
net.ipv6.conf.default.accept_dad = 1
net.ipv6.conf.default.accept_ra = 1
net.ipv6.conf.default.accept_ra_defrtr = 1
net.ipv6.conf.default.accept_ra_from_local = 0
net.ipv6.conf.default.accept_ra_min_hop_limit = 1
net.ipv6.conf.default.accept_ra_min_lft = 0
net.ipv6.conf.default.accept_ra_mtu = 1
net.ipv6.conf.default.accept_ra_pinfo = 1
net.ipv6.conf.default.accept_ra_rt_info_max_plen = 0
net.ipv6.conf.default.accept_ra_rt_info_min_plen = 0
net.ipv6.conf.default.accept_ra_rtr_pref = 1
net.ipv6.conf.default.accept_redirects = 1
net.ipv6.conf.default.accept_source_route = 0
net.ipv6.conf.default.accept_untracked_na = 0
net.ipv6.conf.default.addr_gen_mode = 0
net.ipv6.conf.default.autoconf = 1
net.ipv6.conf.default.dad_transmits = 1
net.ipv6.conf.default.disable_ipv6 = 0
net.ipv6.conf.default.disable_policy = 0
net.ipv6.conf.default.drop_unicast_in_l2_multicast = 0
net.ipv6.conf.default.drop_unsolicited_na = 0
net.ipv6.conf.default.enhanced_dad = 1
net.ipv6.conf.default.force_mld_version = 0
net.ipv6.conf.default.force_tllao = 0
net.ipv6.conf.default.forwarding = 0
net.ipv6.conf.default.hop_limit = 64
net.ipv6.conf.default.ignore_routes_with_linkdown = 0
net.ipv6.conf.default.ioam6_enabled = 0
net.ipv6.conf.default.ioam6_id = 65535
net.ipv6.conf.default.ioam6_id_wide = 4294967295
net.ipv6.conf.default.keep_addr_on_down = 0
net.ipv6.conf.default.max_addresses = 16
net.ipv6.conf.default.max_desync_factor = 600
net.ipv6.conf.default.mc_forwarding = 0
net.ipv6.conf.default.mldv1_unsolicited_report_interval = 10000
net.ipv6.conf.default.mldv2_unsolicited_report_interval = 1000
net.ipv6.conf.default.mtu = 1280
net.ipv6.conf.default.ndisc_evict_nocarrier = 1
net.ipv6.conf.default.ndisc_notify = 0
net.ipv6.conf.default.ndisc_tclass = 0
net.ipv6.conf.default.optimistic_dad = 0
net.ipv6.conf.default.proxy_ndp = 0
net.ipv6.conf.default.ra_defrtr_metric = 1024
net.ipv6.conf.default.regen_max_retry = 3
net.ipv6.conf.default.router_probe_interval = 60
net.ipv6.conf.default.router_solicitation_delay = 1
net.ipv6.conf.default.router_solicitation_interval = 4
net.ipv6.conf.default.router_solicitation_max_interval = 3600
net.ipv6.conf.default.router_solicitations = -1
net.ipv6.conf.default.rpl_seg_enabled = 0
net.ipv6.conf.default.seg6_enabled = 0
net.ipv6.conf.default.seg6_require_hmac = 0
net.ipv6.conf.default.suppress_frag_ndisc = 1
net.ipv6.conf.default.temp_prefered_lft = 86400
net.ipv6.conf.default.temp_valid_lft = 604800
net.ipv6.conf.default.use_oif_addrs_only = 0
net.ipv6.conf.default.use_optimistic = 0
net.ipv6.conf.default.use_tempaddr = 0
net.ipv6.conf.lo.accept_dad = -1
net.ipv6.conf.lo.accept_ra = 1
net.ipv6.conf.lo.accept_ra_defrtr = 1
net.ipv6.conf.lo.accept_ra_from_local = 0
net.ipv6.conf.lo.accept_ra_min_hop_limit = 1
net.ipv6.conf.lo.accept_ra_min_lft = 0
net.ipv6.conf.lo.accept_ra_mtu = 1
net.ipv6.conf.lo.accept_ra_pinfo = 1
net.ipv6.conf.lo.accept_ra_rt_info_max_plen = 0
net.ipv6.conf.lo.accept_ra_rt_info_min_plen = 0
net.ipv6.conf.lo.accept_ra_rtr_pref = 1
net.ipv6.conf.lo.accept_redirects = 1
net.ipv6.conf.lo.accept_source_route = 0
net.ipv6.conf.lo.accept_untracked_na = 0
net.ipv6.conf.lo.addr_gen_mode = 0
net.ipv6.conf.lo.autoconf = 1
net.ipv6.conf.lo.dad_transmits = 1
net.ipv6.conf.lo.disable_ipv6 = 0
net.ipv6.conf.lo.disable_policy = 0
net.ipv6.conf.lo.drop_unicast_in_l2_multicast = 0
net.ipv6.conf.lo.drop_unsolicited_na = 0
net.ipv6.conf.lo.enhanced_dad = 1
net.ipv6.conf.lo.force_mld_version = 0
net.ipv6.conf.lo.force_tllao = 0
net.ipv6.conf.lo.forwarding = 0
net.ipv6.conf.lo.hop_limit = 64
net.ipv6.conf.lo.ignore_routes_with_linkdown = 0
net.ipv6.conf.lo.ioam6_enabled = 0
net.ipv6.conf.lo.ioam6_id = 65535
net.ipv6.conf.lo.ioam6_id_wide = 4294967295
net.ipv6.conf.lo.keep_addr_on_down = 0
net.ipv6.conf.lo.max_addresses = 16
net.ipv6.conf.lo.max_desync_factor = 600
net.ipv6.conf.lo.mc_forwarding = 0
net.ipv6.conf.lo.mldv1_unsolicited_report_interval = 10000
net.ipv6.conf.lo.mldv2_unsolicited_report_interval = 1000
net.ipv6.conf.lo.mtu = 65536
net.ipv6.conf.lo.ndisc_evict_nocarrier = 1
net.ipv6.conf.lo.ndisc_notify = 0
net.ipv6.conf.lo.ndisc_tclass = 0
net.ipv6.conf.lo.optimistic_dad = 0
net.ipv6.conf.lo.proxy_ndp = 0
net.ipv6.conf.lo.ra_defrtr_metric = 1024
net.ipv6.conf.lo.regen_max_retry = 3
net.ipv6.conf.lo.router_probe_interval = 60
net.ipv6.conf.lo.router_solicitation_delay = 1
net.ipv6.conf.lo.router_solicitation_interval = 4
net.ipv6.conf.lo.router_solicitation_max_interval = 3600
net.ipv6.conf.lo.router_solicitations = -1
net.ipv6.conf.lo.rpl_seg_enabled = 0
net.ipv6.conf.lo.seg6_enabled = 0
net.ipv6.conf.lo.seg6_require_hmac = 0
net.ipv6.conf.lo.suppress_frag_ndisc = 1
net.ipv6.conf.lo.temp_prefered_lft = 86400
net.ipv6.conf.lo.temp_valid_lft = 604800
net.ipv6.conf.lo.use_oif_addrs_only = 0
net.ipv6.conf.lo.use_optimistic = 0
net.ipv6.conf.lo.use_tempaddr = -1
net.ipv6.fib_multipath_hash_fields = 7
net.ipv6.fib_multipath_hash_policy = 0
net.ipv6.fib_notify_on_flag_change = 0
net.ipv6.flowlabel_consistency = 1
net.ipv6.flowlabel_reflect = 0
net.ipv6.flowlabel_state_ranges = 0
net.ipv6.fwmark_reflect = 0
net.ipv6.icmp.echo_ignore_all = 0
net.ipv6.icmp.echo_ignore_anycast = 0
net.ipv6.icmp.echo_ignore_multicast = 0
net.ipv6.icmp.error_anycast_as_unicast = 0
net.ipv6.icmp.ratelimit = 1000
net.ipv6.icmp.ratemask = 0-1,3-127
net.ipv6.idgen_delay = 1
net.ipv6.idgen_retries = 3
net.ipv6.ioam6_id = 16777215
net.ipv6.ioam6_id_wide = 72057594037927935
net.ipv6.ip6frag_high_thresh = 4194304
net.ipv6.ip6frag_low_thresh = 3145728
net.ipv6.ip6frag_secret_interval = 0
net.ipv6.ip6frag_time = 60
net.ipv6.ip_nonlocal_bind = 0
net.ipv6.max_dst_opts_length = 2147483647
net.ipv6.max_dst_opts_number = 8
net.ipv6.max_hbh_length = 2147483647
net.ipv6.max_hbh_opts_number = 8
net.ipv6.mld_max_msf = 64
net.ipv6.mld_qrv = 2
net.ipv6.neigh.default.anycast_delay = 100
net.ipv6.neigh.default.app_solicit = 0
net.ipv6.neigh.default.base_reachable_time_ms = 30000
net.ipv6.neigh.default.delay_first_probe_time = 5
net.ipv6.neigh.default.gc_interval = 30
net.ipv6.neigh.default.gc_stale_time = 60
net.ipv6.neigh.default.gc_thresh1 = 128
net.ipv6.neigh.default.gc_thresh2 = 512
net.ipv6.neigh.default.gc_thresh3 = 1024
net.ipv6.neigh.default.interval_probe_time_ms = 5000
net.ipv6.neigh.default.locktime = 0
net.ipv6.neigh.default.mcast_resolicit = 0
net.ipv6.neigh.default.mcast_solicit = 3
net.ipv6.neigh.default.proxy_delay = 80
net.ipv6.neigh.default.proxy_qlen = 64
net.ipv6.neigh.default.retrans_time_ms = 1000
net.ipv6.neigh.default.ucast_solicit = 3
net.ipv6.neigh.default.unres_qlen = 101
net.ipv6.neigh.default.unres_qlen_bytes = 212992
net.ipv6.neigh.lo.anycast_delay = 100
net.ipv6.neigh.lo.app_solicit = 0
net.ipv6.neigh.lo.base_reachable_time_ms = 30000
net.ipv6.neigh.lo.delay_first_probe_time = 5
net.ipv6.neigh.lo.gc_stale_time = 60
net.ipv6.neigh.lo.interval_probe_time_ms = 5000
net.ipv6.neigh.lo.locktime = 0
net.ipv6.neigh.lo.mcast_resolicit = 0
net.ipv6.neigh.lo.mcast_solicit = 3
net.ipv6.neigh.lo.proxy_delay = 80
net.ipv6.neigh.lo.proxy_qlen = 64
net.ipv6.neigh.lo.retrans_time_ms = 1000
net.ipv6.neigh.lo.ucast_solicit = 3
net.ipv6.neigh.lo.unres_qlen = 101
net.ipv6.neigh.lo.unres_qlen_bytes = 212992
net.ipv6.route.gc_elasticity = 9
net.ipv6.route.gc_interval = 30
net.ipv6.route.gc_min_interval = 0
net.ipv6.route.gc_min_interval_ms = 500
net.ipv6.route.gc_thresh = 1024
net.ipv6.route.gc_timeout = 60
net.ipv6.route.max_size = 2147483647
net.ipv6.route.min_adv_mss = 1220
net.ipv6.route.mtu_expires = 600
net.ipv6.route.skip_notify_on_dev_down = 0
net.ipv6.seg6_flowlabel = 0
net.ipv6.xfrm6_gc_thresh = 32768
net.mptcp.add_addr_timeout = 120
net.mptcp.allow_join_initial_addr_port = 1
net.mptcp.checksum_enabled = 0
net.mptcp.enabled = 1
net.mptcp.pm_type = 0
net.mptcp.scheduler = default
net.mptcp.stale_loss_cnt = 4
net.netfilter.nf_log.0 = NONE
net.netfilter.nf_log.1 = NONE
net.netfilter.nf_log.10 = NONE
net.netfilter.nf_log.2 = NONE
net.netfilter.nf_log.3 = NONE
net.netfilter.nf_log.4 = NONE
net.netfilter.nf_log.5 = NONE
net.netfilter.nf_log.6 = NONE
net.netfilter.nf_log.7 = NONE
net.netfilter.nf_log.8 = NONE
net.netfilter.nf_log.9 = NONE
net.netfilter.nf_log_all_netns = 0
net.unix.max_dgram_qlen = 512
user.max_cgroup_namespaces = 15416
user.max_fanotify_groups = 128
user.max_fanotify_marks = 31970
user.max_inotify_instances = 128
user.max_inotify_watches = 30067
user.max_ipc_namespaces = 15416
user.max_mnt_namespaces = 15416
user.max_net_namespaces = 15416
user.max_pid_namespaces = 15416
user.max_time_namespaces = 15416
user.max_user_namespaces = 15416
user.max_uts_namespaces = 15416
vm.admin_reserve_kbytes = 8192
vm.compact_unevictable_allowed = 1
vm.compaction_proactiveness = 20
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.dirtytime_expire_seconds = 43200
vm.extfrag_threshold = 500
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256 256 32 0 0
vm.max_map_count = 65530
vm.memfd_noexec = 0
vm.memory_failure_early_kill = 0
vm.memory_failure_recovery = 1
vm.min_free_kbytes = 7946
vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
vm.mmap_min_addr = 65536
vm.mmap_rnd_bits = 32
vm.mmap_rnd_compat_bits = 16
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 3
vm.page_lock_unfairness = 5
vm.panic_on_oom = 0
vm.percpu_pagelist_high_fraction = 0
vm.stat_interval = 1
vm.swappiness = 60
vm.unprivileged_userfaultfd = 0
vm.user_reserve_kbytes = 122926
vm.vfs_cache_pressure = 100
vm.watermark_boost_factor = 15000
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
xen.balloon.hotplug_unpopulated = 0
Edit - i think this info in Grub may have been what you were asking for. Shows SMT=off but isn’t acting like it. also list a different kernel version than the above pull for some reason.
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=false
GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="rd.luks.uuid=luks-1b0c427c-7ec0-4370-9dca-ac196769ea9c rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles 6.1.62-1.qubes.fc37.x86_64 x86_64 rhgb quiet"
GRUB_DISABLE_RECOVERY="true"
GRUB_THEME="/boot/grub2/themes/qubes/theme.txt"
GRUB_CMDLINE_XEN_DEFAULT="console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096"
GRUB_DISABLE_OS_PROBER="true"
GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX rd.qubes.hide_all_usb"
running xenpm start 1 returns the following as well
CPU0: Residency(ms) Avg Res(ms)
C0 159 (15.93%) 0.26
C1 7 ( 0.71%) 0.06
C2 129 (12.92%) 0.63
C3 38 ( 3.81%) 0.89
C4 119 (11.89%) 1.39
C5 103 (10.28%) 2.29
C6 419 (41.80%) 3.64
C7 26 ( 2.66%) 6.67
C8 0 ( 0.00%) 0.00
P0 148 (100.00%)
P1 0 ( 0.00%)
P2 0 ( 0.00%)
P3 0 ( 0.00%)
P4 0 ( 0.00%)
P5 0 ( 0.00%)
P6 0 ( 0.00%)
P7 0 ( 0.00%)
P8 0 ( 0.00%)
P9 0 ( 0.00%)
P10 0 ( 0.00%)
P11 0 ( 0.00%)
P12 0 ( 0.00%)
P13 0 ( 0.00%)
P14 0 ( 0.00%)
P15 0 ( 0.00%)
Avg freq 1045000 KHz
CPU1: Residency(ms) Avg Res(ms)
C0 183 (18.34%) 0.26
C1 7 ( 0.75%) 0.08
C2 157 (15.70%) 0.52
C3 25 ( 2.51%) 0.72
C4 142 (14.26%) 1.46
C5 178 (17.84%) 2.32
C6 296 (29.55%) 2.79
C7 10 ( 1.05%) 3.50
C8 0 ( 0.00%) 0.00
P0 173 (100.00%)
P1 0 ( 0.00%)
P2 0 ( 0.00%)
P3 0 ( 0.00%)
P4 0 ( 0.00%)
P5 0 ( 0.00%)
P6 0 ( 0.00%)
P7 0 ( 0.00%)
P8 0 ( 0.00%)
P9 0 ( 0.00%)
P10 0 ( 0.00%)
P11 0 ( 0.00%)
P12 0 ( 0.00%)
P13 0 ( 0.00%)
P14 0 ( 0.00%)
P15 0 ( 0.00%)
Avg freq 1121000 KHz
CPU2: Residency(ms) Avg Res(ms)
C0 164 (16.42%) 0.26
C1 0 ( 0.06%) 0.06
C2 165 (16.54%) 0.54
C3 54 ( 5.47%) 0.84
C4 116 (11.62%) 1.15
C5 159 (15.92%) 3.13
C6 332 (33.16%) 3.02
C7 7 ( 0.80%) 3.99
C8 0 ( 0.00%) 0.00
P0 153 (100.00%)
P1 0 ( 0.00%)
P2 0 ( 0.00%)
P3 0 ( 0.00%)
P4 0 ( 0.00%)
P5 0 ( 0.00%)
P6 0 ( 0.00%)
P7 0 ( 0.00%)
P8 0 ( 0.00%)
P9 0 ( 0.00%)
P10 0 ( 0.00%)
P11 0 ( 0.00%)
P12 0 ( 0.00%)
P13 0 ( 0.00%)
P14 0 ( 0.00%)
P15 0 ( 0.00%)
Avg freq 1102000 KHz
CPU3: Residency(ms) Avg Res(ms)
C0 165 (16.52%) 0.22
C1 5 ( 0.52%) 0.10
C2 161 (16.14%) 0.45
C3 64 ( 6.43%) 1.07
C4 133 (13.32%) 1.35
C5 173 (17.31%) 2.41
C6 298 (29.75%) 2.81
C7 0 ( 0.00%) 0.00
C8 0 ( 0.00%) 0.00
P0 154 (100.00%)
P1 0 ( 0.00%)
P2 0 ( 0.00%)
P3 0 ( 0.00%)
P4 0 ( 0.00%)
P5 0 ( 0.00%)
P6 0 ( 0.00%)
P7 0 ( 0.00%)
P8 0 ( 0.00%)
P9 0 ( 0.00%)
P10 0 ( 0.00%)
P11 0 ( 0.00%)
P12 0 ( 0.00%)
P13 0 ( 0.00%)
P14 0 ( 0.00%)
P15 0 ( 0.00%)
Avg freq 950000 KHz
CPU4: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU5: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU6: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU7: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU8: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU9: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU10: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU11: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU12: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU13: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU14: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
CPU15: Residency(ms) Avg Res(ms)
Avg freq 950000 KHz
Socket 0
PC1 0 ms 0.00%
PC2 65 ms 6.53%
PC3 379 ms 37.90%
Core 0 CPU 0
CC1 0 ms 0.00%
CC2 0 ms 0.00%
CC3 36 ms 3.65%
CC4 0 ms 0.00%
CC5 0 ms 0.00%
CC6 114 ms 11.38%
CC7 539 ms 53.78%
Core 1 CPU 1
CC1 0 ms 0.00%
CC2 0 ms 0.00%
CC3 23 ms 2.36%
CC4 0 ms 0.00%
CC5 0 ms 0.00%
CC6 137 ms 13.67%
CC7 475 ms 47.40%
Core 2 CPU 2
CC1 0 ms 0.00%
CC2 0 ms 0.00%
CC3 52 ms 5.19%
CC4 0 ms 0.00%
CC5 0 ms 0.00%
CC6 110 ms 11.02%
CC7 491 ms 49.01%
Core 3 CPU 3
CC1 0 ms 0.00%
CC2 0 ms 0.00%
CC3 61 ms 6.17%
CC4 0 ms 0.00%
CC5 0 ms 0.00%
CC6 127 ms 12.73%
CC7 461 ms 46.07%
It is.
ISTM that dom0 could be ‘exempt’ from some CPU restrictions
that are applied to any domU. Since I am not a Xen developer,
I think your best odds for an answer are on
the xen-devel or xen-users mailing list.
Raist
January 19, 2024, 11:41pm
7
running Journalctl -k I get the below for the kernel boot, this seems to imply the boot command lines in Grub 2 that turn off smt and push the microcode etc. is not executing at boot?
-- Boot 73556647d7d04c91ac1cff38713ce65a --
Jan 19 08:58:55 dom0 kernel: Linux version 6.6.9-1.qubes.fc37.x86_64 (mockbuild@04455ea4b32046f1b40726be8d00519c) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 SMP PREEM>
Jan 19 08:58:55 dom0 kernel: Command line: placeholder root=/dev/mapper/qubes_dom0-root ro rd.luks.uuid=luks-1b0c427c-7ec0-4370-9dca-ac196769ea9c rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plym>
Jan 19 08:58:55 dom0 kernel: Released 0 page(s)
Jan 19 08:58:55 dom0 kernel: BIOS-provided physical RAM map:
Jan 19 08:58:55 dom0 kernel: Xen: [mem 0x0000000000000000-0x0000000000057fff] usable
Jan 19 08:58:55 dom0 kernel: Xen: [mem 0x0000000000058000-0x0000000000058fff
“A minute ago I discovered that mds=full,nosmt had to be added to grub for those having mds vulnerability which could cause data leak. Also, nowhere documented as far as I know.”
Not needed.
mds=full is the default (check kernel.org doc), smt is globally disabled in Qubes OS (see /etc/default/grub). So already mitigated by default in Qubes.
Old, but obviously not resolved…
