Ok,
I am using Chat GPT to teach me how to install a website locally it is basically having me use a Node.js install tool called npm. That’s fine no worries there. However I am having trouble with the version of java in the template and the qube. I am getting errors from the version of java that I am using and when I try to update it in the template. I run into the lack of having a net Qube with the template.
When I try to just do it in the qube it doesn’t have the version manager “n” I downloaded in the template.
My thoughts are I need to update the template with the newer version of java then Roberts your mothers brother. So, what are the oh crap things I need to watch out for with either white listing the template or giving it a net qube and how do I make sure the version trickles down.
I am going to go dig into the docs for qubes on how to do this but I just wanted to ping the pink matter on the best way to get this done.
I thought of changing the template I don’t know enough details to know if fedora would help this. IDK. Any help is appreciated.
ok I connected the template vm to the net qube and get the Nod.js version updated but not making down to the qube how do I make sure this happens. I am going to go look for it, excuse me if this becomes a diary maybe it will help some-one else.
So I installed n on the app vm locally updated the node.js version seems to be working for now will it be persistent IDK.
