Dev: code-signing policy failed
Very often when I do pull requests, my PRs fail the code-signing policy, but not always…
Last example : qubes-builder-gentoo PR#12, see the code-signing failed check.
Is another contributor can help me to understand what I do bad? Thanks.
Maybe I found, I will see on my next PR…
Explanation : my uploaded sign key was expired in the keyservers. I already changed the expiration date in my local vault but I didn’t upload again the sign key to the keyservers…
Edit: solved, it was this…
