Desktop Computer, Dedicated GPU Compatible with Qubes
Hello everyone, new to forums, been using qubes for years though.
So, as the titles suggests, I have a desktop computer that used to be fully compatible with qubes, the gpu I had broke down and I am in need of a new one. Is there a cheap dedicated GPU that is compatible with Qubes with little to no fixes? I checked the hcl but GPUs there tend to be old and no longer available to be bought new, which is a requirement for me. Is there one you recommend? with Black Friday around the corner I was willing to buy one for cheap, I can afford only low end gpus… Any, thanks for the time spent reading this.
Hi
I think anything AMD will be ok, while NVIDIA cards won’t work well as they need a proprietary driver which is a huge pain to install and maintain in dom0. Intel dedicated cards (Arc) may work too.
I have successfully used many different Nvidia Quadro cards (400, p1000, 600). All cheap
There is currently a kernel issue with some Nvidia cards but fix should be out soon.
