Dell Precision 7540
layout:
  'hcl'
type:
  'notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  Precision 7540
bios: |
  1.15.1
cpu: |
  Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec4] (rev 0d)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] [8086:3e9b] (rev 02) (prog-if 00 [VGA controller])
  Advanced Micro Devices, Inc. [AMD/ATI] Lexa XT [Radeon PRO WX 3200] [1002:6981] (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
  Intel Corporation Wi-Fi 6 AX200 (rev 1a)
memory: |
  16138
scsi: |
usb: |
  2
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.3
  kernel: |
    5.14.15-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
  • Installed 4.1RC3
  • 16GB Ram
  • Dual Intel CoffeeLake/AMD PRO WX 320 Graphics card
  • Dual boots with windows 11 (yes I know, but I currently HAVE to have it, VM won’t do)
Everything works. Only issue I had when after initial install, sys-net would not start. I had to enable strict reset for wifi/ethernet
It is my main OS that I use
Thank you @drwelander for your HCL report, which is online now.
