I’ve successfully installed and ran QubesOS on a DELL PowerEdge T40.
I’m using it in prod since months now and so far it’s working great.
I’ve virtualized few fedoras and a Windows Server 2019 on it which I use daily.
Unfortunately for now I’m too fresh of a member, so I’m not allowed to upload the HLC file.
I will edit later when I can. Until then here’s the content:
Explanation: using strings command we find the offset where are written the boot conf files.
Using this information we replace the begining of the found lines with a # so those lines become comments.
Once the ISO file is fixed and we can “burn” it to the USB stick and boot on the install.
Once installed, I had another issue.
While the installation seemed to have been successfull, the system didn’t boot.
To fix that I used a tiny linux distro and fixed the EFI conf as described in EFI partition as read in UEFI Troubleshooting | Qubes OS
For me the problem was to point on the correct partition which was /dev/sdc1 (I had 3 HDD on this server) in efi/boot64.cfg.
That’s it, after that the system booted properly. Enjoy!
@stopi, I’ve moved your explanation post to a reply here so the HCL is close to the trouble shooting instructions. Hope you don’t mind.
It’s just that generally the HCL table links to the HCL report and this way it will be easier for others to see immediately what you had to troubleshoot.
