layout:
'hcl'
type:
'space-saving'
hvm:
'yes'
iommu:
'yes'
slat:
tpm:
'unknown'
remap:
'yes'
brand: |
Dell Inc.
model: |
OptiPlex 9020
bios: |
A09
cpu: |
Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation 4th Gen Core Processor DRAM Controller [8086:0c00] (rev 06)
chipset-short: |
FIXME
gpu: |
Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Ethernet Connection I217-LM (rev 04)
memory: |
32676
scsi: |
SATA SSD Rev: 61.5
usb: |
3
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.89-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Been using the Optiplex 9020 with Qubes 4.1 as my main machine since early December. It works exceptionally well. Never had an issue with suspend nor any other issues with the machine. I use a ps/2 keyboard and a usb mouse plugged into a ps/2 mouse port with an adapter. The machine is outputted to a 27 inch monitor running 2560x1440 resolution. I connect to the internet via Ethernet cable.
