Dell Latitude 7424 Rugged Extreme
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
bios: |
  1.29.0
cpu: |
  Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914] (rev 08)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
memory: |
  65394
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.4
    xen: |
      4.17.5
    kernel: |
      6.12.21-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
To make Qubes OS run on this laptop, I had to:
  • change SATA Operation mode from RAID On to AHCI, otherwise no disks were detected by Anaconda
  • make sure that dom0’s Linux commandline has the options nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off set, otherwise hard lockups and forced restarts were presents
  • for extra security, I decided not to automatically accept USB keyboards and mice during the initial setup: the touchpad and touchscreen are USB devices, but the keyboard is not, meaning that once logged in, I can just manually accept the touchpad and touchscreen with the keyboard once dom0 prompts me
Some curiosities unrelated to Qubes OS, but might be worth mentioning in case someone else has the same configuration and wonders if these are Qubes-related bugs:
  • the touchpad, i.e. Interlink Electronics Inc. VersaPad doesn’t distinguish between clicking the left button and tapping on it, i.e. tap-to-click toggling doesn’t exist and tap-to-click can’t be turned off
  • rebooting doesn’t work at all and causes a software lockup of some sort, shutdown your system and start from a powered off state instead
HCL_Dell_Latitude_7424_Rugged_Extreme.yml (858 Bytes)
Software lockup before Firmware/BIOS (in the shutdown process of the existing session). or at the boot after soft restart (GRUB? Plymouth?)?
During the shutting-down part of an attempted reboot, the laptop does not power off and instead idles with a backlit display.
It’s not a Qubes OS bug, as this happens even if trying to reboot from firmware settings, but wanted to mention it just in case someone thinks it is a Qubes OS bug and files a ticket.
