layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Dell Inc.
model: |
Latitude 3520
bios: |
1.30.0
cpu: |
11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Wi-Fi 6 AX201 (rev 20)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
memory: |
32510
scsi: |
usb: |
3
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.6
kernel: |
6.4.8-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Working
- Wifi
- Ethernet
- Video
- Sound
- USB-ports
- Microphone
- HDMI-port
Doesn’t work
- Sleep (adding
mem_sleep_default=deepto kernel param does not help;/sys/power/mem_sleeplistss2idleas only ) - Integrated camera
- MicroSD-card reader
Not tested
- Bluetooth
On MicroSD reader
Attached card is show on the list of USB devices, but attempting to connect it to VM gives notification reading Attaching device Generic_USB2.0-CRW_20121112761000000 to disp3483 failed. Error: QubesException - Device attach failed: Attach timeout, check kernel log for details. VM: "disp3483" File: "/usr/lib/qubes/usb-import" Version Control: https://github.com/QubesOS/qubes-app-linux-usb-proxy/blob/master/src/usb-import.
syslog on VM the card is attached:
[ 1103.161489] audit: type=1100 audit(1695633063.052:254): pid=1520 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1103.162650] audit: type=1103 audit(1695633063.053:255): pid=1520 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1103.197663] audit: type=1130 audit(1695633063.088:256): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1103.216969] audit: type=1101 audit(1695633063.107:257): pid=1522 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1103.217231] audit: type=1103 audit(1695633063.107:258): pid=1522 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 1103.217529] audit: type=1006 audit(1695633063.108:259): pid=1522 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=5 res=1
[ 1103.217607] audit: type=1300 audit(1695633063.108:259): arch=c000003e syscall=1 success=yes exit=1 a0=8 a1=7ffe37eac2c0 a2=1 a3=0 items=0 ppid=1 pid=1522 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[ 1103.217741] audit: type=1327 audit(1695633063.108:259): proctitle="(systemd)"
[ 1103.225540] audit: type=1105 audit(1695633063.116:260): pid=1522 uid=0 auid=0 ses=5 msg='op=PAM:session_open grantors=pam_selinux,pam_selinux,pam_loginuid,pam_keyinit,pam_namespace,pam_systemd_home,pam_keyinit,pam_limits,pam_systemd,pam_unix acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1103.246814] audit: type=1334 audit(1695633063.137:261): prog-id=91 op=LOAD
[ 1104.791906] vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(0)
[ 1104.791948] vhci_hcd vhci_hcd.0: devid(131076) speed(3) speed_str(high-speed)
[ 1104.791992] vhci_hcd vhci_hcd.0: Device attached
[ 1105.009355] usb 1-1: new high-speed USB device number 14 using vhci_hcd
[ 1105.135444] usb 1-1: device descriptor read/64, error -71
[ 1105.362412] usb 1-1: device descriptor read/64, error -71
[ 1105.585472] usb 1-1: new high-speed USB device number 15 using vhci_hcd
[ 1105.709440] usb 1-1: device descriptor read/64, error -71
[ 1105.935403] usb 1-1: device descriptor read/64, error -71
[ 1106.039314] usb usb1-port1: attempt power cycle
[ 1106.157476] usb 1-1: new high-speed USB device number 16 using vhci_hcd
[ 1106.157547] usb 1-1: SetAddress Request (16) to port 0
[ 1106.179037] usb 1-1: device descriptor read/8, error -71
[ 1106.306954] usb 1-1: device descriptor read/8, error -71
[ 1106.529435] usb 1-1: new high-speed USB device number 17 using vhci_hcd
[ 1106.529485] usb 1-1: SetAddress Request (17) to port 0
[ 1106.550068] usb 1-1: device descriptor read/8, error -71
[ 1106.674711] usb 1-1: device descriptor read/8, error -71
[ 1106.783482] usb usb1-port1: unable to enumerate USB device
[ 1109.949866] vhci_hcd: stop threads
[ 1109.949896] vhci_hcd: release socket
[ 1109.949920] vhci_hcd: disconnect device
[ 1110.901742] kauditd_printk_skb: 65 callbacks suppressed
[ 1110.901748] audit: type=1106 audit(1695633070.792:297): pid=1520 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1110.901955] audit: type=1104 audit(1695633070.792:298): pid=1520 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1120.993504] audit: type=1104 audit(1695633080.884:299): pid=1524 uid=0 auid=0 ses=5 msg='op=PAM:setcred grantors=? acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 1120.996467] audit: type=1131 audit(1695633080.887:300): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1121.017689] audit: type=1131 audit(1695633080.908:301): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1133.649070] audit: type=1131 audit(1695633093.539:302): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1133.677377] audit: type=1334 audit(1695633093.568:303): prog-id=108 op=UNLOAD
[ 1133.677426] audit: type=1334 audit(1695633093.568:304): prog-id=107 op=UNLOAD
[ 1133.677475] audit: type=1334 audit(1695633093.568:305): prog-id=106 op=UNLOAD
On sys-usb
[ 1386.207460] audit: type=1100 audit(1695633063.618:254): pid=1699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1386.208579] audit: type=1103 audit(1695633063.619:255): pid=1699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1386.308379] audit: type=1130 audit(1695633063.719:256): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1386.350390] audit: type=1101 audit(1695633063.761:257): pid=1701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1386.350492] audit: type=1103 audit(1695633063.761:258): pid=1701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 1386.351910] audit: type=1006 audit(1695633063.763:259): pid=1701 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=5 res=1
[ 1386.351992] audit: type=1300 audit(1695633063.763:259): arch=c000003e syscall=1 success=yes exit=1 a0=8 a1=7ffc9091ac00 a2=1 a3=0 items=0 ppid=1 pid=1701 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[ 1386.352124] audit: type=1327 audit(1695633063.763:259): proctitle="(systemd)"
[ 1386.367563] audit: type=1105 audit(1695633063.778:260): pid=1701 uid=0 auid=0 ses=5 msg='op=PAM:session_open grantors=pam_selinux,pam_selinux,pam_loginuid,pam_keyinit,pam_namespace,pam_systemd_home,pam_keyinit,pam_limits,pam_systemd,pam_unix acct="root" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1386.403183] audit: type=1334 audit(1695633063.814:261): prog-id=94 op=LOAD
[ 1387.110017] usb usb2-port3: device 2-3 not suspended yet
[ 1387.110208] usbip-host 2-3: usbip-host: register new device (bus 2 dev 4)
[ 1387.125438] usbip-host 2-3: stub up
[ 1387.347627] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.353976] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.357032] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.578697] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.581774] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.583825] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.924797] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.927050] usbip-host 2-3: urb completion with non-zero status -71
[ 1387.931641] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.153695] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.155843] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.158021] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.508443] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.511458] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.515090] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.637909] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.640946] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.643034] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.879569] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.882229] usbip-host 2-3: urb completion with non-zero status -71
[ 1388.885303] usbip-host 2-3: urb completion with non-zero status -71
[ 1389.005543] usbip-host 2-3: urb completion with non-zero status -71
[ 1389.007599] usbip-host 2-3: urb completion with non-zero status -71
[ 1389.010780] usbip-host 2-3: urb completion with non-zero status -71
[ 1392.286795] usbip-host 2-3: recv a header, 0
[ 1392.287030] usbip-host 2-3: lock for reset
[ 1393.202887] kauditd_printk_skb: 65 callbacks suppressed
[ 1393.202892] audit: type=1106 audit(1695633070.614:297): pid=1699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1393.206136] audit: type=1104 audit(1695633070.617:298): pid=1699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 1403.281617] audit: type=1131 audit(1695633080.692:299): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1403.308895] audit: type=1131 audit(1695633080.720:300): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1417.014002] audit: type=1131 audit(1695633094.425:301): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1417.040856] audit: type=1334 audit(1695633094.452:302): prog-id=111 op=UNLOAD
[ 1417.040903] audit: type=1334 audit(1695633094.452:303): prog-id=110 op=UNLOAD
[ 1417.040938] audit: type=1334 audit(1695633094.452:304): prog-id=109 op=UNLOAD
