I have an old Dell Latitude E6430 which runs qubes perfectly. I have had couple of these and with 16gb they run qubes beautifully. Until this glitch.
I did a fresh install of qubes 4.2 which was working perfectly except that, in haste I forgot to set the time. I buggerized around with it for a while trying to set the time but gave up and then re-installed it. It now works perfectly except that now the CAPS lock which has a little light to tell when CAPS are on has stopped working. It was working perfectly but not now. The rest of the backlit keyboard works fine but not the CAPS lock.
I have checked the bios but there doesn’t seem to be anything there only the backlit option which is working.
Does anyone have an idea of what might be causing this? I suppose that its possible that there is a coincidence that the keyboad has just become faulty in this respect but I’d like to see if there might be another reason before I replace the keyboard.
Thanks for reading.
