sudo dfn remove qubes-template-whonix-gw-15
returns
Error in PREUN scriptlet in rpm package qubes-template-whonix-gw-15
It says it was supposed to be removed but was not.
Yes I did read - Fail to remove whonix-gw-15
Is it possible to cut and paste from the dom terminal?
Do you have removed/switched before to new versions the sys-whonix, the anon-whonix and the whonix-ws dvm? If the whonix-ws and/or gw template is in use, removing is failing.
