I installed the Qubes OS4.1 but it installs the Xfce but it fails to install the rest of the qubes!?
Whonix, debian, fedore is unavailable? The check boxes cannot be checked?
It went thru the test during installation without any problem.
Any idea what might cause the issues? Thanks
reinstall is the solution, if problem persist. check your qubes installation medium.
I’ve done a lot of 4.1 installs and never encountered this,although I
have seen other reports.
It might be helpful if you identified the machine(if you are comfortable
doing this.)
The templates are available on the install medium,and you can install
them from there, rather than reinstalling.
On the other hand a *slow and careful reinstall might help point
to what went wrong the first time.
I reinstalled a new V-4.1.1 and it’s working great. Thanks
