I successfully installed and booted the latest version of Qubes OS (4.2.4) on a 9800X3D CPU. However, I encountered an issue where essential components such as sys-net and sys-firewall were missing. My attempts to create these components were unsuccessful, indicating that there was a problem during the installation process.
journal.log (254.5 KB)
After installing the OS and before I could configure it, a shell opened with the following warnings (rewritten for clarity):
warning: /dev/mapper/qubes_dom0-root does not exist
warning: /dev/qubes_dom0/root does not exist
warning: /dev/qubes_dom0/swap does not exist
generating: "/run/initramfs/rdsosreport.txt"
Entering emergency mode. Exit the shell to continue.
Type "journalctl" to view system logs.
[Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
ccp 0000:0b:00.2: tee: ring init command failed (0x00000005)
ccp 000:0b:00.2: tee: failed to init ring buffer
hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
nouveau 0000:01:00.0: unknown chipset (193000a1)
Warning: not all disks have been found.
Warning: you might want to regenerate your initramfs.
After forcing a reboot, I was able to access the configuration and successfully boot into Qubes OS, though the essential apps were still missing.
