Made a TemplateVM with no net qube. In global settings net qube, selected my net qube, bet when started terminal of TemplateVM and run sudo dnf update, it still starts syst-net qube which is not my default one. What do I miss here?
“Default update proxy” in Qubes OS Global Config → Updates is the one that is used for non-Whonix TemplateVM updates. The “Dom0 update proxy” is used only for dom0 updates.
Did you change “Default update proxy” to your net qube?
Ah, that works. Thank you
