Per my last post I have now been using Qubes for 2 months now I believe and still loving it.
I have however been encountering issues with disposable vms as every time I start one it simply just shutdown.
Note I am not experiencing this issue with the whoinix dvms.
Please let me know whichever logs you require from the template for analysis.
Did it work before?
Is it shutting down no matter which app you’re trying to start in this disposable?
Will it shutdown as well if you start “Run terminal” app for this disposable?
It had worked before but now it just constantly shuts down the disposable vm after it starts few seconds after seeing the “started” notification.
I have made no changes to it, it simply just stopped working about 3 weeks ago if recall correctly.
Just to make sure: are you starting the disposable by pressing “Start qube” in the App menu or by starting some app in the disposable (e.g. browser)?
