Any custom DVM template → Settings → Advanced tab → Default disposable template is set to default-dvm.
For example:
- fedora-template-00 → default-dvm
- fedora-template-01 → sys-net-dvm → sys-net.
- fedora-template-02 → sys-firewall-dvm → sys-firewall
both, sys-net-dvm and sys-firewall-dvm share the same Default disposable template – default-dvm.
Help me to understand:
- Why there’s default-dvm for sys-net-dvm and sys-firewall-dvm? Or is that just a pointer for another DVM to use if needed within this DVM?
- If it’s not a pointer, then If fedora-template-00 is compromised then default-dvm is compromised, does that mean sys-net and sys-firewall are also compromised?
