How can I pick a default audio device? When I start a new qube I need to enter PulseAudio control panel to change audio device, or it won’t have any sound. This is particularly annoying for disposables. I don’t seen an option in the menus.
In dom0 pavucontrol you have a “Output Devices” tab with all your devices. Each one has a “check” logo, have you tried to select the device you want to use with it?
Thanks, it worked but “set as fallback” sure is unintuitive.
