I’m trying to upgrade Debian template, from 12 to 13, using this:
Everything went through without any problems or errors - I have a new Debian-13-xfce template in Qube Manager, but next to the new template is a warning message “ this cube is based on a distribution that is no longer supported. Install new template with Template Manager”. There are no updates available for this cube. So, apparently something went wrong. I’d love any ideas what may have happened.
EDIT: I ran the whole process again (no errors), what I found strange: after cloning, there is nothing to update or upgrade; there was no prompt for overwriting qubes-r4.list file, and after running sudo apt-dist upgrade, again, there was nothing to install or upgrade.
I have not skipped anything. Also, the internal upgrade from 12 to 13 should have taken place (if I’m not mistaken) around step 3/4. And it does not; 0 packages upgraded, installed or removed.
I still dont get why you want to UPGRADE that template instead of installing a new one - so at the end you have debian-12-xfce and debian-13-xfce, and then you can flip the template in your appvms.
qvm-features VMNAME | grep template-name in dom0, replacing VMNAME with your new Debian template’s name.
Personally, with how much I use qubes, I didn’t find reinstalling templates a viable option. With the amount of customization I apply to my templates, I used to always upgrade, as this took way less time. Now that I’ve switched to Ansible I always reinstall, but that’s not easy to set up.
