Debian over sys-whonix
If I had something that was on debian that I routed over the sys-whonix NetVM would that mean that all network traffic would go over tor? Say I had an application running would that app run over TOR or just in a browser it would route thru TOR?
THX! Sorry for all the questions folks just a beginner tryna learn… this Qubes thing is so difficult makes you wanna give up or just get some concrete answers from the best of y’all out there. You are very appreciated
Yes. You can verify this by running Deb appvm you create with sys-whonix as network, and then going to sys-whonix control panel and stopping it. You’ll see that all internet stops. Like if you did a apt install in terminal it will fail
thank you for your input @corny
