Thank you for your time.
I followed your instructions and I was able to add a new screen resolution.
After saving the new settings, Debian HVM turned black, after 10 seconds the 1920X1080 resolution returned.
I installed the hwinfo utility to view information about the OS kernel frame buffer:
$ hwinfo --framebuffer
02: None 00.0: 11001 VESA Framebuffer
[Created at bios.459]
Unique ID: rdCR.bMFFGolbcb2
Hardware Class: framebuffer
Model: "SeaBIOS Developers SeaBIOS VBE Adapter"
Vendor: "SeaBIOS Developers"
Device: "SeaBIOS VBE Adapter"
SubVendor: "SeaBIOS VBE(C) 2011"
SubDevice:
Revision: "Rev. 1"
Memory Size: 16 MB
Memory Range: 0xf1000000-0xf1ffffff (rw)
Mode 0x0300: 640x400 (+640), 8 bits
Mode 0x0301: 640x480 (+640), 8 bits
Mode 0x0303: 800x600 (+800), 8 bits
Mode 0x0305: 1024x768 (+1024), 8 bits
Mode 0x0307: 1280x1024 (+1280), 8 bits
Mode 0x030d: 320x200 (+640), 15 bits
Mode 0x030e: 320x200 (+640), 16 bits
Mode 0x030f: 320x200 (+960), 24 bits
Mode 0x0310: 640x480 (+1280), 15 bits
Mode 0x0311: 640x480 (+1280), 16 bits
Mode 0x0312: 640x480 (+1920), 24 bits
Mode 0x0313: 800x600 (+1600), 15 bits
Mode 0x0314: 800x600 (+1600), 16 bits
Mode 0x0315: 800x600 (+2400), 24 bits
Mode 0x0316: 1024x768 (+2048), 15 bits
Mode 0x0317: 1024x768 (+2048), 16 bits
Mode 0x0318: 1024x768 (+3072), 24 bits
Mode 0x0319: 1280x1024 (+2560), 15 bits
Mode 0x031a: 1280x1024 (+2560), 16 bits
Mode 0x031b: 1280x1024 (+3840), 24 bits
Mode 0x031c: 1600x1200 (+1600), 8 bits
Mode 0x031d: 1600x1200 (+3200), 15 bits
Mode 0x031e: 1600x1200 (+3200), 16 bits
Mode 0x031f: 1600x1200 (+4800), 24 bits
Mode 0x0340: 320x200 (+1280), 24 bits
Mode 0x0341: 640x400 (+2560), 24 bits
Mode 0x0342: 640x480 (+2560), 24 bits
Mode 0x0343: 800x600 (+3200), 24 bits
Mode 0x0344: 1024x768 (+4096), 24 bits
Mode 0x0345: 1280x1024 (+5120), 24 bits
Mode 0x0346: 320x200 (+320), 8 bits
Mode 0x0347: 1600x1200 (+6400), 24 bits
Mode 0x0348: 1152x864 (+1152), 8 bits
Mode 0x0349: 1152x864 (+2304), 15 bits
Mode 0x034a: 1152x864 (+2304), 16 bits
Mode 0x034b: 1152x864 (+3456), 24 bits
Mode 0x034c: 1152x864 (+4608), 24 bits
Mode 0x0375: 1280x768 (+2560), 16 bits
Mode 0x0376: 1280x768 (+3840), 24 bits
Mode 0x0377: 1280x768 (+5120), 24 bits
Mode 0x0378: 1280x800 (+2560), 16 bits
Mode 0x0379: 1280x800 (+3840), 24 bits
Mode 0x037a: 1280x800 (+5120), 24 bits
Mode 0x037b: 1280x960 (+2560), 16 bits
Mode 0x037c: 1280x960 (+3840), 24 bits
Mode 0x037d: 1280x960 (+5120), 24 bits
Mode 0x037e: 1440x900 (+2880), 16 bits
Mode 0x037f: 1440x900 (+4320), 24 bits
Mode 0x0380: 1440x900 (+5760), 24 bits
Mode 0x0381: 1400x1050 (+2800), 16 bits
Mode 0x0382: 1400x1050 (+4200), 24 bits
Mode 0x0383: 1400x1050 (+5600), 24 bits
Mode 0x0384: 1680x1050 (+3360), 16 bits
Mode 0x0385: 1680x1050 (+5040), 24 bits
Mode 0x0386: 1680x1050 (+6720), 24 bits
Mode 0x0387: 1920x1200 (+3840), 16 bits
Mode 0x0388: 1920x1200 (+5760), 24 bits
Mode 0x0389: 1920x1200 (+7680), 24 bits
Mode 0x038a: 2560x1600 (+5120), 16 bits
Mode 0x038b: 2560x1600 (+7680), 24 bits
Mode 0x038c: 2560x1600 (+10240), 24 bits
Mode 0x038d: 1280x720 (+2560), 16 bits
Mode 0x038e: 1280x720 (+3840), 24 bits
Mode 0x038f: 1280x720 (+5120), 24 bits
Mode 0x0390: 1920x1080 (+3840), 16 bits
Mode 0x0391: 1920x1080 (+5760), 24 bits
Mode 0x0392: 1920x1080 (+7680), 24 bits
Mode 0x0393: 1600x900 (+3200), 16 bits
Mode 0x0394: 1600x900 (+4800), 24 bits
Mode 0x0395: 1600x900 (+6400), 24 bits
Mode 0x0396: 2560x1440 (+5120), 16 bits
Mode 0x0397: 2560x1440 (+7680), 24 bits
Mode 0x0398: 2560x1440 (+10240), 24 bits
Mode 0x0399: 3840x2160 (+7680), 16 bits
Mode 0x039f: 960x540 (+1920), 16 bits
Mode 0x03a0: 960x540 (+2880), 24 bits
Mode 0x03a1: 960x540 (+3840), 24 bits
Mode 0x03a2: 1280x1080 (+2560), 16 bits
Mode 0x03a3: 1280x1080 (+3840), 24 bits
Mode 0x03a4: 1280x1080 (+5120), 24 bits
Mode 0x03a5: 2160x1080 (+4320), 16 bits
Mode 0x03a6: 2160x1080 (+6480), 24 bits
Mode 0x03a7: 2160x1080 (+8640), 24 bits
Mode 0x03a8: 2560x1080 (+5120), 16 bits
Mode 0x03a9: 2560x1080 (+7680), 24 bits
Mode 0x03aa: 2560x1080 (+10240), 24 bits
Mode 0x03ab: 2560x1440 (+5120), 16 bits
Mode 0x03ac: 2560x1440 (+7680), 24 bits
Mode 0x03ad: 2560x1440 (+10240), 24 bits
Mode 0x03ae: 3200x1800 (+6400), 16 bits
Mode 0x03b1: 3440x1440 (+6880), 16 bits
Mode 0x03b2: 3440x1440 (+10320), 24 bits
Mode 0x03b4: 3840x1080 (+7680), 16 bits
Mode 0x03b5: 3840x1080 (+11520), 24 bits
Mode 0x03b6: 3840x1080 (+15360), 24 bits
Mode 0x03b7: 3840x1600 (+7680), 16 bits
Mode 0x03cc: 2048x1152 (+4096), 16 bits
Mode 0x03cd: 2048x1152 (+6144), 24 bits
Mode 0x03ce: 2048x1152 (+8192), 24 bits
Mode 0x03cf: 2048x1536 (+4096), 16 bits
Mode 0x03d0: 2048x1536 (+6144), 24 bits
Mode 0x03d1: 2048x1536 (+8192), 24 bits
Mode 0x03d2: 2560x1600 (+5120), 16 bits
Mode 0x03d3: 2560x1600 (+7680), 24 bits
Config Status: cfg=new, avail=yes, need=no, active=unknown
As you can see from the command output, 2560x1600 screen resolution is supported, but it cannot be set.
I don’t understand what’s going on at all.
I installed Windows 10 HVM and the screen resolution changes without any problems, I tried different OS Linux and everything is the same, I cannot set the resolution higher than 1920X1080.
What am I doing wrong ?
