debian-14 templates for testing
I put up a couple of Debian-14 templates, for any one who'd like to try
them in 4.3
There's a debian-14-xfce and debian-14-minimal - some rough edges on the
build, but otherwise pretty usable. You probably should check the
repository definitions to see if they need tuning for use with/without
cacher.
I think it's a little early for an official build, but I'll put up PRs
to allow this.
The templates are available here, signed with my Qubes signing key:
https://qubes.3isec.org
A new kali-core follows shortly, based on forky as it should be..
wow. thanks :slight_smile:
@unman
Where can one see your procedure for creating templates?
I would like to learn how it works.
I simply use qubesbuilderv2 - the modifications for building forky are
trivial - no keepassxc so there has to be a custom package.list, but
otherwise as .
I’ve posted before about modifying to build derivates - usually just a
question of adding scripts to copy in keys, create repos, and install
custom packages.
For new templates like OpenBSD it’s more difficult. In that case I use a
custom install and then process the generated disk image in to a normal
template package.
You can see these approaches on GitHub
@unman
Thanks. I will research the info you shared.
hey @unman Is it possible in the future that every debian template ship with my apparmor profiles ? dkzkz/apparmor-qubes: Apparmor profile for debian template in Qubes OS - Codeberg.org i don’t know if i have to ask this to you or someone else
It’s possible, but I would think they will need extensive feedback
before deployment.
Use the existing thread for gathering that, or open a new soliciting
feedback?
I’ve posted a new kali-core template for 4.3 for testing. It’s pretty
minimal but you can install whatever kali packages or meta packages you
want.
For information on meta packages look here
Okay thanks you i will do it
