Debian-13-minimal: fstrim: the discard operation is not supported
I am observing something I can’t explain:
On debian-13-xfce:
# fstrim -v /
/: 13.7 GiB (14715064320 bytes) trimmed
# lsblk --discard
NAME    DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO
xvda           0      512K       2T         0
├─xvda1        0      512K       2T         0
├─xvda2        0      512K       2T         0
└─xvda3        0      512K       2T         0
xvdb           0      512K       2T         0
xvdc           0      512K       2T         0
├─xvdc1        0      512K       2T         0
└─xvdc3        0      512K       2T         0
xvdd           0        0B       0B         0
On debian-13-minimal:
# fstrim -v /
fstrim: /: the discard operation is not supported
# lsblk --discard
xvda           0        0B       0B         0
├─xvda1        0        0B       0B         0
├─xvda2        0        0B       0B         0
└─xvda3        0        0B       0B         0
xvdb           0        0B       0B         0
xvdc           0        0B       0B         0
├─xvdc1        0        0B       0B         0
└─xvdc3        0        0B       0B         0
xvdd           0        0B       0B         0
What is the reason for this discrepancy?
Any possible fix?
fstrim -av works for me in the minimal template.
Is the ‘root’ volume of debian-13-minimal stored on a different pool that’s using the legacy ‘file’ driver?
Is Bleachbit free space cleaner an alternative to insecure disk wipe?
@rustybird
Yes.
Why does it create this problem?
Just one of the many problems with the legacy ‘file’ driver. In this case, it’s because its device-mapper based snapshot implementation in dom0 does not support discard on the kernel level.
@rustybird
You are a living encyclopedia of file/snapshot/volume management stuff. :slight_smile:
Thank you!
