I’m playing with the debian-12-minimal template and found a problem.
I right click on the template in qube manager and ‘run command in qube’ and enter ‘xterm’ as the command. The qube starts and then I get an error popup: ‘Command ‘xterm’ returned non zero exit status 1’
At this point the qube has started. If I do the same again then xterm starts.
The debian-12 template does the same.
The debian-12-xcfe works fine - xterm starts first time.
Am I doing something wrong or is there a problem with the templates?
