Debian-11, whonix-gw-16, and whonix-ws-16 not updating
On 4.1 for the past few days debian-11, whonix-gw-16, and whonix-ws-16 not updating though it worked fine earlier. Fedora-38 and dom0 are updating fine too. Error listed as “Failed to return clean data” for all three templates.
It’s probably this known bug:
Yes, but in addition to debian-11 both whonix-gw-17 & whonix-ws-17 are impacted now.
Are you sure that you are currently using whonix-17? Since it’s based on bookworm, it shouldn’t be affected by this issue.
Apologies. whonix-16, not 17
Make sure to install the new salt package in fedora-38 and it will work again.
I changed template of default-mgmt-dvm to debian-11 and all updates work again.
Finally I remembered an earlier case, where the update succeeded from ‘Qube Manager’.
Updated 1st fedora-38 and 2nd whonix-gw-16 from ‘Qube Manager’, then without error.
‘Qubes Update’ then still asked to update whonix-gw-16. Let it run, which found packages are up to date and left a notification. default-mgmt-dvm is still fedora-38.
