I tried to switch from Debian 10 to 11. Sadly, there is a problem with dependencies. I guess it is an upstream Debian 11 problem. I am not 100% sure. Even if it is an upstream problem it should be fixed.
Problem: Dependency “libappindicator1” is not included. Affected programs (many) like Wire Messenger, Keybase and LBRY.
Will this be fixed by QubesOS or is it an upstream problem?
It’s an upstream problem for Wire, and those other applications.
libappindicator1 is removed from Debian after Debian-10 - there has been
plenty of warning. It’s not in sid and it wont be coming back.
There are many alternatives.
The obvious fix is to repackage Wire to not require that package.
You could also try using the package from Debian-10, which sometimes
works in this sort of case.
Check out https://packages.debian.org to find the package - you’ll need
libindicator7 and libappindicator1 - pull those in to your template and
manually install using apt install
I suggest doing this in a clone of your template to avoid breakage.
It may or may not work.
Until @necker provides more helpful reply, that may be your best
bet.
Thanks @unman. I can see that wasn’t helpful for @wilsonb
I misremembered how I got Wire working in Debian 11. I was initially thinking of my VeraCrypt install which had dependency issues that were easily fixed with the commands I mentioned.
For Wire, I now recall I had problems getting apt-key working so I opted to use the AppImage installer provided at https://wire.com/downloads. AppImage doesn’t require dependencies and I was easily able to get Wire up and running.
I know this doesn’t address the issue of the libappindicator1 dependency in Debian 11 but it did address the general dependency problem of getting Wire running in Debian 11.
Also, fwiw, I continue to have problems getting Wire to retain certain settings with this install. The app launches at boot and keeps me logged in across sessions but I have to reset my preference for Dark mode every time I start the VM which is tedious but tolerable.
I resolved this by installing Gnome Tweak Tools in the template. Then in the appVM I opened “Tweaks” from the VM app menu and chose the Dark Theme in the Appearance tab.
Then I opened the appVM Terminal and used sudo nano ~./config/gtk-3.0/settings.ini
and sudo nano ~./config/gtk-4.0/settings.ini
to each include:
gtk-applicaiton-prefer-dark-theme=1
Then I restarted Wire and the dark theme setting within the Wire options now persists. Apparently the Wire app is using the Debian system dark setting when configuring preferences and Gnome Tweak Tools is needed for Debian VMs to have a dark theme. Not sure why it worked at all before - but now it persists between boots.
