I want to apologize for my absence after initiating this thread - coffee spilled onto my keyboard, frying my machine, and it’s taken until now to get a new one I can run Qubes on.
@unman could you elaborate on the health warning for non-advanced users? Is the concern that minimal-template config is more prone to misconfiguring something that will go undetected without advanced understanding?
@Sven you’ve basically written the documentation I had in mind in one post! Legend!
With this fresh machine I started to implement your instructions…
qvm-run --pass-io -u root tpl-deb-10-min “sed -i – ‘s/https:///http://HTTPS////g’ /etc/apt/sources.list”
qvm-run --pass-io -u root tpl-deb-10-min “sed -i – ‘s/https:///http://HTTPS////g’ /etc/apt/sources.list.d/*.list”
Because this wasn’t in a code block, the double dash following the i flag was auto-formatted into an em dash. I was also getting an error in the sed command until I changed the delimiter to #, because / is in the argument. Perhaps if this post is turned into a github guide, it would be fitting to have a hyperlink explaining the sources.list change, as I initially found it quite confusing without being familiar with apt-cacher-ng : How to get apt-cacher-ng to download AND cache packages from Apt HTTPS repositories? - Ask Ubuntu
For clarity, I ran:
qvm-run --pass-io -u root tpl-deb-10-min "sed -i -- 's#https://#http://HTTPS///#g' /etc/apt/sources.list"
qvm-run --pass-io -u root tpl-deb-10-min "sed -i -- 's#https://#http://HTTPS///#g' /etc/apt/sources.list.d/*.list"
The next step (apt update && apt full-upgrade) is where I run into problems, it returned this error message
Err:1 http://HTTPS///deb.debian.org/debian buster InRelease 500 Unable to connect [IP: 127.0.0.1 8082]
Err:2 http://HTTPS///deb.debian.org/debian-security buster/updates InRelease 500 Unable to connect [IP: 127.0.0.1 8082]
Err:3 http://HTTPS///deb.qubes-os.org/r4.0/vm buster InRelease 500 Unable to connect [IP: 127.0.0.1 8082] ...
Did I place the delimiter in the wrong location for sed? Do I need to first install apt-cacher-ng to the tpl-deb-10-min template? You say later down it is an optional package but I use many templates so decided to go with it. Thanks so much everyone! Very hyped at how many insights have already been contributed here.
EDIT: I attempted to integrate Unman’s apt-cacher-ng instructions into Sven’s instructions, for people like me who don’t already have it enabled but need it for this minimal set up. I figured it would be easier for others to make changes on Github for this section of the instructions involving apt-cacher-ng, so made a temporary repo. You’ll notice I split step 2 (clone and setup your own minimal template) into two separate steps, to fit in the apt-cacher-ng instructions. You’ll also notice that I run into an error restarting the service before I’m done setting it up!
