Security Considerations
Most people use screenlockers on a daily basis to prevent unauthorized access to their computers during e.g. coffee breaks. The screen lock functionality is thereby often part of a screensaver. Qubes OS uses `xscreensaver’ for that.
While screenlockers cannot be assumed to withstand serious attacks, most users likely assume that they cannot be bypassed within very little time. They also assume that screenlockers don’t tend to fail after a while.
Unfortunately both of these assumptions usually don’t hold:
- If one of the parent processes of a screenlocker (e.g. the X server) dies or restarts unexpectedly, the screen locker will die and leave the screen unprotected. X server restarts may happen with various graphic driver bugs, e.g. on something as simple as plugging a laptop into a docking station with a monitor.
- Screenlockers tend to have bugs or bad/outdated design.
- Other applications may request the screenlocker to be cleared or otherwise display information in front of the screenlocker window.
The default Qubes OS xscreensaver also suffers from these issues, but at least has high hardware coverage. The Qubes OS design also helps to limit the scope of some of these issues (e.g. only dom0 applications can request the screensaver to quit).
In general it is not advisable to rely on screenlocker security for anything serious.
See qubes-issues for further discussions.
Configuring a custom screenlocker
Qubes OS can be configured to use whatever screenlocker you prefer.
Thanks to xss-lock and xflock4 (by default started via /etc/xdg/autostart/xfce4-xss-lock.desktop) the below screenlockers should work right after their installation in dom0:
xscreensaver-command -lockgnome-screensaver-command --lockxlock -mode blankslock
If you have multiple screenlockers installed, you might have to remove the others first.
For other screenlockers you have to use the following dom0 command to enable them:
xfconf-query -c xfce4-session -p /general/LockCommand -s "[command to start your screenlocker]" --create -t string
Set an empty command to disable them.
Important Note:
xss-lock continually requests a timeout (the one set via xset s) from the X server and if that timeout is hit, it executes xflock4, which in turn executes your screenlocker.
However any bug in xss-lock (e.g. this one or possibly even just a X server disconnect), may cause that trigger to not happen. I.e. do not rely on that trigger for anything sensible, but use a keyboard screenlocker hotkey instead!
Physlock
physlock is an interesting screenlocker alternative as it simply uses the tty logon mechanism as screen locking mechanism. It does not depend on the X server and is therefore not affected by unexpected X server restarts.
The below instructions provide an example of how to install and configure a non-default screenlocker.
Installation
- Install its build dependencies in dom0:
sudo qubes-dom0-update gcc make pam-devel systemd-devel - Download the physlock source code, verify its tag signatures and copy it to dom0.
- Follow the build and install instructions of its README.
- In particular make sure to follow its PAM-related instructions (if you run into an endless
authentication failedloop on locking later, you likely forgot this point).
Configuration
- physlock uses the dom0 root password for unlocking, i.e. you’ll have to set one with
sudo passwd. - Create a helper script at
/usr/bin/screenlock:#!/bin/bash function isRunning { pgrep -a '^physlock$' } #parse args keep_open=1 if [[ "$1" == "--keep-open" ]] ; then keep_open=0 shift fi #NOTE: for some sreason the full path is required below for xss-lock isRunning || { /usr/local/bin/physlock -dms "$@" ; sleep 1 ; } #Idea: #make xss-lock think that it controls the screenlocker, but in fact it doesn't #reason: xss-lock may crash and we don't want it to take down the screen lock if [ $keep_open -eq 0 ] ; then stime=10 while isRunning ; do echo "Sleeping for ${stime}s..." sleep $stime done fi exit 0 - Make it executable with
chmod +x /usr/bin/screenlock. - Make sure
/etc/xdg/autostart/xfce4-xss-lock.desktopexists withxss-lock xflock4(does exist by default in Qubes OS 4). - As regular user, run
xfconf-query -c xfce4-session -p /general/LockCommand -s "/usr/bin/screenlock --keep-open" --create -t stringin dom0. - If you need audio during the screen lock, run
sudo usermod -a -G audio [your user].
You can then use the command screenlock for custom hotkeys etc.
To set the screenlocker timeout, use the xfce GUI or xset.
For example you could create /etc/xdg/autostart/xset.desktop with the following content to set a timeout of 610s on startup:
[Desktop Entry]
Name=xset
Comment=Set screensaver timeout
Exec=bash -c 'sleep 60 && xset s 610'
Terminal=false
Type=Application
StartupNotify=false
- Page archive
- First commit: 24 Sep 2020. Last commit: 08 Dec 2020.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames): 3hhh
- Original author(s) (forum usernames):
- Document license: CC BY 4.0
