It’s quite the opposite actually. Before the author of the malicious script had to know that the target uses Qubes OS and therefore add code that would use proxy 8082. Or the actual user had to understand what’s going on and provide the proxy address.
Now any malicious script will simply work with a 3 second pause! What progress!
I for one take away from this discussion: I will secure my UpdateProxy and share instructions how to do so… so it becomes impossible to download ANYTHING that I have not whitelisted.
I would continue to advocate that the wrapper was pausing WHILE TELLING THE USER what was going to happen next, but now get that it would not serve the expected outcome… While reminding everyone that scripts calling the proxy directly today would work, without that non-existing safeguard. And that people not blocking that feature (which is used by dnf/apt to update Templates) as of today could have scripts download stuff if no wrappers are made available to pause, failsafe those downloads. So what to do with that?
Having 3 seconds pausing will open more widely, I get the point.
Following others considerations, it would be better to have the wrappers failsafe, explaining why, or have MOTD explaining security properties/differences implemented in the TemplateVM.
Solutions are:
Deploy GPG keys + Repos from packages.
MOTD/wrappers educate/telling users what is going on/what to do.
Have users pass explicitely wget/curl/other arguments to be able to use those commands.
Have cloned TemplateVMs have internet access momentarily.
Well, now more then even, I would love to have tinyproxy logs to at least match hostnames/timestamps for dnf/apt update attempts. Otherwise, this proxy is more security by obscurity (not knowing where the proxy was, which is not randomized per install but static per installation) and once known, can be used by scripts.
Again, the idea was to permit installation per upstream software installation guides. Did not want to address malware download scripts, evolved in such way to pause user before doing so, where now people want more protection from the proxy once knowing that it is there to be used if known per such script.
Insurgo:
And that is, having an organisation deploying those repos+gpg keys, or, having Qubes take side into deploying some repositories/not others.
This is in effect what we do with Whonix. I think it’s a question of pragmatism, if an app is open source, used by millions and has a high relevance to a large part of our user base then I don’t think it’s unreasonable to include its repo.
Even if I take this argument, I still think the correct solution is to expose a safe way to explicitly add repos.
Insurgo:
For the other points, the only solution to your comments would be to remove the proxy in Templates (they are used and wrapped by dnf/apt today), which could be interpreted by security by obscurity. A script downloaded per other qube, pushed into templates calling wget/curl with proxy arguments would work as is, today.
I’m actually pretty shocked there isn’t a more granular whitelist here if I’m honest. All the same, it’s very different to have some proxy at the lower level for the purposes of making the package manager work as opposed to making this an idiom that is exposed to the user.
Sven:
I get that and also where you are coming from. And I am not opposed to making Qubes OS easier to use, quite the opposite. However, IMHO this should NEVER come at the cost of lowering the default level of security provided.
My point of view is that I always found it icky that the only thing between a malicious install script in a template and the internet was the knowledge that there is a proxy at port 8082. Then @unman’s post confirmed to me that once Qubes OS was more secure and that barrier was lowered in the name of convenience. I am in no position to judge or re-evaluate past decisions made by people much smarter than me. However, for me this thread has made it impossible to ignore this itch.
Luckily there is nothing stopping me from either reintroducing a whitelist to apt-cacher-ng (I don’t use tinyproxy) or simply having a dedicated proxy VM for the UpdateProxy and configure it’s firewall. Or maybe once again @adw post a key insight that makes me re-evaluate this.
But this is another topic than your thread. I think with the MOTD we found a good compromise and I hope it will get adopted.
Thank you also for all your hard work on heads. It is a corner stone of my setup. I’ll probably be rocking this T430 with Ivy Bridge for the rest of my days unless some kind of miracle happens (open architecture).
@marmarek@unman@patrick.whonix (you are not here?) @fepitre@Demi :
Then, I am questionning, really, current Qubes Template approach with proxy, and would love to see what it was before, what changed and where it is now.
Following the reaction of a lot of current thread participants, it seems that the proxy logic permitting dnf/apt was pure magic, where once exposed, caused a strong reaction from them. Now they know that a wide internet access from TemplateVM is available from http://127.0.0.1:8082 blew their mind, now seeing that this principle was, if we abuse language, security by obscurity.
Some are looking to close it down more (@sven) while others are disappointed from the fact that some scripts might just use be using it now. My attempt being to facilite this usage exposed its existence, which @unman pointed to some past disagreement in changes in the past I cannot directly point back to. The fact persists. That proxy is currently effective, people are against using it directly for better UX because it would make it more easy to use by following official software installation guides, because some random script could be using it, targeting a proxy that is available in all Q4.0/Q4.1 TemplateVMs to permit dnf/apt updates from default, currently Qubes trusted, repositories.
This dichotomy is making me uncomfortable, personally. The information is available. If we prohibit users from using curl/wget because scripts would too easily use such binaries, its just a matter of time and or intense research to find some scripts which are using http://127.0.0.1:8082 for scripts tageting Qubes users into bypassing TemplateVM security measures. Yet, we do not want to facilitate UX by having wrappers to pause external downloads, while being aware that such scripts might exist and that some Qubes users might have ran into it to compromise their Templates already.
We now fallback into desiring to implement MOTD to educate users of TemplateVM limitations/security properties limiting them to be able to use such applications directly, while I now agree with @Sven (multiple stances) and @laurel.straddle :
That such proxy exposure, if not facilitated, still exists, and as of now is more like a security by obscurity measure then anything else.
Please point to the PR/Issues that made the changes happen upstream. I would like to see what were the reasonings of hiding its usage more then securing it. Or understand why proxy was decided over fw rules. Understand before/after such discussions and technical/UX justifications/considerations that made the change happen.
@laurel.straddle To me, that use case is the perfect good example for a qube (where the built application can be launched from build path) or a standalone qube, where user is experimenting, while the TemplateVM use case is the user wanting to install trusted upstream software installation guide, where he expects those trusted installation instructions to just work (because wget/curl are used everywhere in those instructions) while those software are not part of a lot of ecosystem’s repositories.
If a user wants to install GUIX on top of Debian, I expect that user to be technical enough to be able to clone a templatevm, open internet access to it, do what he wants.
But to me, once again, limiting UX with some obscure undocumented protection (in situ) the user not able to comprehend in situ problems (hence wrappers blocking/delaying being a good way to go forward if we keep proxy) goes against all UX principles (@ninavizz/@marmarek please debate of the issue and come back with a settlement!!!).
We cannot have a one size fits all. But the wrapper principles exposed in this PoC, as far as the current discussion goes, could have simply extended the 3 seconds warning to 30 seconds:
With a Qubes configurable delay from Qubes Template GUI, or qvm-prefs, to toggle “advanced_user” or “proxy_delay” to deal with the situation and documented properly. But we need to take a stance here. Security by obscurity is a big no to me, and I guess most of Qubes user base. @unman: please help me here.
I understand all points of views here. But as of now, we currently have a proxy which most thought was offering more protection that it offers. The fact is that it can be called directly and totally and easily bypassed by scripts, which is the reason why this PoC is rejected. At the same time, the current implementation is the reason why this PoC came to life, because it goes against UX principles. But the PoC is rejected because it exposes the current implementation limits? Well. The current implementation is then wrong. Sorry, but this is consequently a fact. Otherwise, the current implementation would limit the scope of the proxy. Don’t get me wrong, I understand that the proxy permits dnf/apt access. But it being fixed to 127.0.0.1 8082, and that now being known making some want to change it, exposes its limits. And past, maybe better, implementation seem to have done a too far jump to an extreme, and now is a time to think of something better. Otherwise, a wrapper around its implementation should have fixed UX problems. That is my opinion. We can document it, but scripts just being able to download stuff will still be a possibility, which is why people reject the PoC.
Reactions are contradictory. And someone from Qubes Team need to present alternatives that would limit such proxy usage, explain the changes that happened before pointing to past discussions/issues/PR and UX addressed, one way or the other.
I cannot emphasise more then this: GUI will have to deal with the same problems of being able to at least import GPG public keys, and add additional repository URLs. Packaging all GPG keys and repositories is simply not possible. And partly addressing this issue will just make it pop later on. IT was asked again and again and again. Where the current Template Proxy existing on 127.0.0.1 8082 is now a concern, the justification for not accepting current PoC being that random script would have access to the internet.
Well. Scripts found online to address current implementation limitations are probably just calling scripts, using the proxy directly, as we speak.
This was all news to me. (I had been vaguely aware of these historical events as they happened but didn’t understand the specifics or implications until you clearly explained them.) You might consider opening an issue to (re-?)improve the security of the default configuration (in the spirit of secure defaults), since the vast majority of Qubes users will probably never be aware of your instructions and even fewer will implement them.
On the other hand, I’d understand if one were reticent to open an issue that relitigates a matter about which @marmarek has already decided. I don’t know what the deciding argument was, but if I had to guess, just based on general Qubes principles, it might’ve been that installation scripts that run in templates are already trusted (or, perhaps more precisely, that each template is already assumed to be only as trusted as the installation scripts that run in it). So, perhaps a thread here or on qubes-devel might be more appropriate (either a new one or a revival of the old one, if anyone can find it).
@adw For some reason, I missed that point before. Of course, deploying repository information and GPG key doesn’t make sense without installing the desired software in template. The user is following upstream instructions to add repo+gpg key+installing software
Of course, adding a repository (no problem, no network access required) will work but package won’t install unless GPG key is downloaded. From upstream documentations, one last time, that either requires sudo to call wget/curl and put the file directly where expected, or call wget/curl without root privileges and then have root privileges to put it in place (See Signal/Session examples in OP). In either case, and all cases I have personally observed, either curl or wget are used in those installation guides. And in most scripts I have seen, either curl/wget is used to get content online.
This is why, even if time passed and you did modifications on core documentation for software installation (good!), I still think wrappers around wget/curl would address the situation here until we come up with a better approach.
Those wrappers detecting if we are in a template without internet access (default) should offer a non-blocking warning of what is going to happen next: what is wget/curl, what the URL going to be downloaded is, and give a chance to the user to cancel the operation (Pause 3 seconds). I remind again that if a script is doing 3 downloads, the wrappers will be called 3 times, pause 3 times and warn the user 3 times. We could even go farther here, and also point the user to the possibility of calling qvm-volume revert tamplate_name:root if catched too late. Maybe this is a precedent to call for education, while not modifying OS (wrapping is not modifying, but intercepting).
Otherwise, this would be the approach proposed by @Demi : having them deployed (software repositories are there, keys are deployed, which means repositories information is fetched at each template updates, the software being installed or not). The question on that approach would be to know if the Qubes packages containing those additional repositories and GPG keys, would be deployed by default or not, and if they would be part of default Templates by Qubes OS team. Note here: your same reasoning here applies @adw: It would not make any sense to deploy GPG keys without deploying repositories definitions. But as opposed to your point here: it would make sense to deploy GPG keys and repository definitions without installing the software in question. @adw@deeplow@Demi : in that case, if Qubes decides to go in that direction to resolve the problem, package repositories+GPG keys should probably be individual packages, or persona/use case related, I’m not sure of the best avenue to go from here. Maybe communication related open source related repositories (Signal,Element,Session,etc). But in my mind, the wrapper again wins for other reasons. One being to not poke repositories for software not being installed to reduce network consumption, where I think the wrapper approach again wins without the user opening network access to a template. On that note, I keep receiving questions on a daily basis on how to deploy those GPG keys, even though upstream instructions have been updated. The obvious reason to that is, and I agree:
So again, I would advocate for:
Which would be non-blocking while educating, on the spot for all use cases covered here, script or manual installation. 3 seconds is not much to wait if a user is doing this for the first time. Users that are installing untrusted repositories and software would probably follow updated core Qubes software installation guide, assigning network.
The wrappers could just warn the user he is downloading stuff, not pause download. And the same wrappers called in Qubes… As in latest PoC.
Reminder:
I am still convinced this wrapper approach would be better then what we have now.
The other movement being to strengthen the proxy as it was before, so that trusted repositories are used normally per TemplateVMs and where installing anything untrusted would require to assign network to Template per core updated docs. But the current implementation is to me still questionable, permitting to call wget/curl with proxy to do anything. (The wrapper would still catch that, by the way, in the current PoC)
@marmarek unfortunately, your export solution here, without additional hack, won’t successfully permit installation of Element per upstream instructions, since their wget call is made with sudo. So simply exposing the proxy for current user won’t simply work.
