I am still using Qubes v4.2x
Ctrl+Shift+v not working. Nothing crashes, or visibly happens when I press it. Watching live in dom0 with journalctl -f nothing happens when I press Ctrl+Shift+v
Ctrl+Shift+v to work?
from disp1610 to disp2598 (tried from dom0, or any other, but it doesn’t work across the Qubes OS)
Here are the logs from both, respectively (“FROM” guid.disp1610.log, qrexec.disp1610.log, qubesdb.disp1610.log and the same 3 for the other “TO” qube):
Icon size: 128x128
invalid PMaxSize for 0x6a001d7 (16384/16384)
libvchan_is_eof
Warning: cannot read config file (/var/run/qubes/guid-conf.114): file I/O error
Icon size: 128x128
domain dead
Failed to connect to gui-agent
2026-06-21 05:42:45.604 qrexec-daemon[256384]: qrexec-daemon.c:1040:connect_daemon_socket: connection to socket failed: No such file or directory
WARNING:root:warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be deprecated
INFO:policy:qrexec: qubes.WindowIconUpdater+: disp1610 → @adminvm: allowed to dom0
2026-06-21 05:42:46.026 qrexec-daemon[256389]: qrexec-daemon.c:1040:connect_daemon_socket: connection to socket failed: No such file or directory
INFO:policy:qrexec: qubes.GetDate+nanoseconds: disp1610 → @default: allowed to dom0
2026-06-21 05:43:22.591 qrexec-daemon[256249]: qrexec-daemon.c:1634:main: qrexec-agent has disconnected
domain dead
2026-06-21 05:43:22.593 qrexec-daemon[256249]: qrexec-daemon.c:1499:handle_agent_restart: cannot connect to qrexec agent: No such file or directory
2026-06-21 05:43:22.593 qrexec-daemon[256249]: qrexec-daemon.c:1636:main: Failed to reconnect to qrexec-agent, terminating
2026-06-21 05:43:29.458 qrexec-daemon[256384]: process_io.c:249:qrexec_process_io: vchan connection closed early (fds: 4 4 -1, status: -1 -1)
vchan closed
reconnecting
vchan closed
Icon size: 128x128
invalid PMaxSize for 0x82001d7 (16384/16384)
connect: No such file or directory
Window 0x82001d7 is still set as transient_for for a 0x82001d9 window, but VM tried to destroy it
libvchan_is_eof
Warning: cannot read config file (/var/run/qubes/guid-conf.115): file I/O error
Icon size: 128x128
domain dead
2026-06-21 05:42:51.289 qrexec-daemon[256430]: qrexec-daemon.c:1040:connect_daemon_socket: connection to socket failed: No such file or directory
INFO:policy:qrexec: qubes.WindowIconUpdater+: disp2598 → @adminvm: allowed to dom0
2026-06-21 05:42:53.241 qrexec-daemon[256437]: qrexec-daemon.c:1040:connect_daemon_socket: connection to socket failed: No such file or directory
INFO:policy:qrexec: qubes.GetDate+nanoseconds: disp2598 → @default: allowed to dom0
2026-06-21 05:43:20.980 qrexec-daemon[256366]: qrexec-daemon.c:1634:main: qrexec-agent has disconnected
domain dead
2026-06-21 05:43:20.982 qrexec-daemon[256366]: qrexec-daemon.c:1499:handle_agent_restart: cannot connect to qrexec agent: No such file or directory
2026-06-21 05:43:20.982 qrexec-daemon[256366]: qrexec-daemon.c:1636:main: Failed to reconnect to qrexec-agent, terminating
2026-06-21 05:43:24.246 qrexec-daemon[256430]: process_io.c:249:qrexec_process_io: vchan connection closed early (fds: 4 4 -1, status: -1 -1)
vchan closed
reconnecting
vchan closed
I have checked again and it doesn’t work. qubes.ClipboardPaste was missing, so I copied it from the backup, restarted qubesd but to na avail. Here’s the text for the qubes.ClipboardPaste
Note that policy parsing stops at the first match,
so adding anything below “@anyvm @anyvm action” line will have no effect
Clipboard paste (Ctrl-Shift-V) will treat “ask” as “allow” but only when
called by this keyboard shortcut. “deny” always denies the operation.
Please use a single # to start your custom comments
dom0 @anyvm ask
@anyvm @anyvm ask
The comments are commented out with “##” but I deleted them for the sake of formatting here, otherwise the text would be with the font size of 36 or something
policy-admin.log doesn’t seem to have anything indicative:
policy-admin.log part at the time of these trials
2026-06-20 17:39:17,618 policy.List+ (dom0)
2026-06-20 17:39:17,735 policy.include.List+ (dom0)
2026-06-20 17:39:39,922 policy.Get+30_user (dom0)
2026-06-20 17:40:38,473 policy.Get+50-config-clipboard (dom0)
2026-06-20 17:40:48,106 policy.Get+50-config-input (dom0)
2026-06-20 17:40:59,400 policy.Get+50-config-updates (dom0)
2026-06-20 17:41:09,598 policy.Get+50-gui-sys-gui-gpu (dom0)
2026-06-20 17:41:15,818 policy.Get+50-sys-audio (dom0)
2026-06-20 17:41:34,116 policy.Get+80-whonix (dom0)
2026-06-20 17:41:42,102 policy.Get+85-admin-backup-restore (dom0)
2026-06-20 17:41:56,493 policy.Get+90-admin-default (dom0)
2026-06-20 17:42:19,660 policy.Get+85-admin-backup-restore (dom0)
2026-06-20 17:42:28,509 policy.Get+90-admin-default (dom0)
2026-06-20 17:42:44,943 policy.Get+90-admin-policy-default (dom0)
2026-06-20 17:42:53,561 policy.Get+90-default (dom0)
2026-06-20 17:43:08,120 policy.Get+90-default-gui-daemon (dom0)
2026-06-20 17:43:15,702 policy.Get+90-default-linux (dom0)
2026-06-20 17:43:22,704 policy.Get+90-default-pdf-convert (dom0)
2026-06-20 17:43:28,833 policy.include.Get+admin-global-ro (dom0)
2026-06-20 17:43:37,238 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:44:29,511 policy.include.Get+admin-local-ro (dom0)
2026-06-20 17:44:35,528 policy.include.Get+admin-local-rwx (dom0)
2026-06-20 17:44:50,291 policy.include.Get+admin-policy-ro (dom0)
2026-06-20 17:44:58,205 policy.include.Get+admin-policy-rwx (dom0)
2026-06-20 17:45:16,974 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:48:01,432 policy.include.Get+admin-global-ro (dom0)
2026-06-20 17:48:12,485 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:53:05,913 policy.Get+30_user (dom0)
2026-06-20 17:54:58,526 policy.List+ (dom0)
2026-06-20 17:54:58,657 policy.include.List+ (dom0)
2026-06-20 17:55:05,288 policy.Get+31_user (dom0)
2026-06-20 17:55:41,516 warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be deprecated
2026-06-20 17:55:41,516 ignoring /etc/qubes-rpc/policy/include (not a file)
2026-06-20 17:55:41,517 ignoring /etc/qubes-rpc/policy/whonix.GatewayCommand.rpmsave (ignored suffix)
2026-06-20 17:55:41,517 ignoring /etc/qubes-rpc/policy/whonix.NewStatus.rpmsave (ignored suffix)
2026-06-20 17:55:41,517 ignoring /etc/qubes-rpc/policy/whonix.SdwdateStatus.rpmsave (ignored suffix)
2026-06-20 17:55:41,517 ignoring /etc/qubes-rpc/policy/qubes.USB.rpmsave (ignored suffix)
2026-06-20 17:55:41,517 ignoring /etc/qubes-rpc/policy/xrandr-1920-1080-80,sh.rpmsave (ignored suffix)
2026-06-20 17:55:41,578 policy.Replace+31_user (dom0)
2026-06-20 17:55:41,718 policy.Get+31_user (dom0)
2026-06-20 17:57:19,603 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:57:31,633 warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be deprecated
2026-06-20 17:57:31,633 ignoring /etc/qubes-rpc/policy/include (not a file)
2026-06-20 17:57:31,633 ignoring /etc/qubes-rpc/policy/whonix.GatewayCommand.rpmsave (ignored suffix)
2026-06-20 17:57:31,633 ignoring /etc/qubes-rpc/policy/whonix.NewStatus.rpmsave (ignored suffix)
2026-06-20 17:57:31,633 ignoring /etc/qubes-rpc/policy/whonix.SdwdateStatus.rpmsave (ignored suffix)
2026-06-20 17:57:31,633 ignoring /etc/qubes-rpc/policy/qubes.USB.rpmsave (ignored suffix)
2026-06-20 17:57:31,634 ignoring /etc/qubes-rpc/policy/xrandr-1920-1080-80,sh.rpmsave (ignored suffix)
2026-06-20 17:57:31,665 policy.include.Replace+admin-global-rwx (dom0)
2026-06-20 17:57:31,781 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:57:36,821 policy.include.Get+admin-local-rwx (dom0)
2026-06-20 17:57:44,931 warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be deprecated
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/include (not a file)
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/whonix.GatewayCommand.rpmsave (ignored suffix)
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/whonix.NewStatus.rpmsave (ignored suffix)
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/whonix.SdwdateStatus.rpmsave (ignored suffix)
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/qubes.USB.rpmsave (ignored suffix)
2026-06-20 17:57:44,932 ignoring /etc/qubes-rpc/policy/xrandr-1920-1080-80,sh.rpmsave (ignored suffix)
2026-06-20 17:57:44,957 policy.include.Replace+admin-local-rwx (dom0)
2026-06-20 17:57:45,074 policy.include.Get+admin-local-rwx (dom0)
2026-06-20 17:57:50,364 policy.include.Get+admin-policy-rwx (dom0)
2026-06-20 17:57:58,731 policy.include.Get+admin-policy-rwx (dom0)
2026-06-20 17:58:04,635 policy.include.Get+admin-global-rwx (dom0)
2026-06-20 17:58:09,650 policy.include.Get+admin-local-rwx (dom0)
Also, 50-config-clipboard.policy looks pretty generic:
qubes.ClipboardPaste * @adminvm @anyvm ask
qubes.ClipboardPaste * @anyvm @anyvm ask
I guess I answered all your questions now, but I don’t see how this could help you to help me to debug it, hahaha. In any case, let me know if you’re out of ideas, please.
