I want to press the Ctrl + Alt + Delete keys to open the lock screen of a Windows Server VM.
However, when I do that, QubeOS gets locked instead.
How can I resolve this issue?
Hi kzlz
Sounds like you have keyboard binding in Qubes for Ctrl+Alt+Delete that intercepts the press before the VM. Have you looked in[1]:
Q → Gear Icon → System Settings → Keyboard → Application Shortcuts
[1]: Place/path probably depends on Qubes release and personal customization
This post reminds me when using VNC with Windows systems (a very long time ago) there was a special menu and one of the options was send ctrl+alt+del.
Within the popular FOSS software collection there is probably an on-screen keyboard that could be used within the designated Xorg server qube (today this is dom0).
I can imagine how an on-screen keyboard or even just send ctrl+alt+delete as a menu item in a window menu (handled by the window manager) could be very useful for Windows (and other highly obscure) guest OS.
The VNC viewer from tigervnc (on Fedora) still have the F8-menu with:
Send F8
Send Ctrl-Alt-Del
… also when the remote machine is Linux.
In KDE, you can change this under “SystemsSettings->Session Management->LogOut”.
It’s a configurable shortcut.
In Xfce, Settings->Keyboard->ApplicationShortcuts:
Highlight entry and Remove.
Either of these will remove the Qubes response to CAD.
Alternatively, a small script will allow you to pass CAD in to any qube:
#!/bin/sh
if [ $# -eq 1 ]; then
xdotool search --name $1 key ctrl+alt+Delete
else
echo "You must specify qube"
fi
exit
Save this on your path in dom0, and assign it to a shortcut.
