Create a Gaming HVM
I’m using nvidia driver, I disabled the load of “nouveau” within the VM. I tried with both Debian 12 and Fedora 38 and I end up with the exact same error when loading nvidia driver.
On my T470, it was quite easy to setup the passthrough, so I’m not sure what is wrong here.
Jan 22 22:27:05.696138 localhost kernel: Linux version 6.1.0-17-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.69-1 (2023-12-30)
Jan 22 22:27:05.696167 localhost kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-17-amd64 root=/dev/mapper/dmroot ro xen_scrub_pages=0 root=/dev/mapper/dmroot console=tty0 console=hvc0 swiotlb=8192 noresume clocksource=tsc quiet
Jan 22 22:27:05.696183 localhost kernel: BIOS-provided physical RAM map:
Jan 22 22:27:05.696194 localhost kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
Jan 22 22:27:05.696205 localhost kernel: BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
Jan 22 22:27:05.696220 localhost kernel: BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
Jan 22 22:27:05.696233 localhost kernel: BIOS-e820: [mem 0x0000000000100000-0x000000007befefff] usable
Jan 22 22:27:05.696243 localhost kernel: BIOS-e820: [mem 0x000000007beff000-0x000000007befffff] reserved
Jan 22 22:27:05.696253 localhost kernel: BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00afff] ACPI NVS
Jan 22 22:27:05.696262 localhost kernel: BIOS-e820: [mem 0x00000000fc00b000-0x00000000ffffffff] reserved
Jan 22 22:27:05.696272 localhost kernel: NX (Execute Disable) protection: active
Jan 22 22:27:05.696282 localhost kernel: SMBIOS 2.4 present.
Jan 22 22:27:05.696292 localhost kernel: DMI: Xen HVM domU, BIOS 4.17.2 01/03/2024
Jan 22 22:27:05.696301 localhost kernel: Hypervisor detected: Xen HVM
Jan 22 22:27:05.696312 localhost kernel: Xen version 4.17.
Jan 22 22:27:05.696323 localhost kernel: platform_pci_unplug: Netfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated NICs.
Jan 22 22:27:05.696338 localhost kernel: platform_pci_unplug: Blkfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated disks.
                                         You might have to change the root device
                                         from /dev/hd[a-d] to /dev/xvd[a-d]
                                         in your root= kernel command line option
Jan 22 22:27:05.696351 localhost kernel: HVMOP_pagetable_dying not supported
Jan 22 22:27:05.696363 localhost kernel: tsc: Fast TSC calibration using PIT
Jan 22 22:27:05.696374 localhost kernel: tsc: Detected 2495.803 MHz processor
Jan 22 22:27:05.696385 localhost kernel: tsc: Detected 2495.986 MHz TSC
Jan 22 22:27:05.696397 localhost kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jan 22 22:27:05.696408 localhost kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jan 22 22:27:05.696418 localhost kernel: last_pfn = 0x7beff max_arch_pfn = 0x400000000
Jan 22 22:27:05.696428 localhost kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Jan 22 22:27:05.696439 localhost kernel: found SMP MP-table at [mem 0x000f5910-0x000f591f]
Jan 22 22:27:05.696451 localhost kernel: Using GB pages for direct mapping
Jan 22 22:27:05.696465 localhost kernel: Incomplete global flushes, disabling PCID
Jan 22 22:27:05.696476 localhost kernel: RAMDISK: [mem 0x3520f000-0x368fefff]
Jan 22 22:27:05.696486 localhost kernel: ACPI: Early table checksum verification disabled
Jan 22 22:27:05.696497 localhost kernel: ACPI: RSDP 0x00000000000F5860 000024 (v02 Xen   )
Jan 22 22:27:05.696507 localhost kernel: ACPI: XSDT 0x00000000FC00A670 000054 (v01 Xen    HVM      00000000 HVML 00000000)
Jan 22 22:27:05.696518 localhost kernel: ACPI: FACP 0x00000000FC00A370 0000F4 (v04 Xen    HVM      00000000 HVML 00000000)
Jan 22 22:27:05.696528 localhost kernel: ACPI: DSDT 0x00000000FC001040 0092A3 (v02 Xen    HVM      00000000 INTL 20220331)
Jan 22 22:27:05.696539 localhost kernel: ACPI: FACS 0x00000000FC001000 000040
Jan 22 22:27:05.696549 localhost kernel: ACPI: FACS 0x00000000FC001000 000040
Jan 22 22:27:05.696559 localhost kernel: ACPI: APIC 0x00000000FC00A470 000090 (v02 Xen    HVM      00000000 HVML 00000000)
Jan 22 22:27:05.696570 localhost kernel: ACPI: HPET 0x00000000FC00A580 000038 (v01 Xen    HVM      00000000 HVML 00000000)
Jan 22 22:27:05.696583 localhost kernel: ACPI: WAET 0x00000000FC00A5C0 000028 (v01 Xen    HVM      00000000 HVML 00000000)
Jan 22 22:27:05.696595 localhost kernel: ACPI: SSDT 0x00000000FC00A5F0 000031 (v02 Xen    HVM      00000000 INTL 20220331)
Jan 22 22:27:05.696607 localhost kernel: ACPI: SSDT 0x00000000FC00A630 000031 (v02 Xen    HVM      00000000 INTL 20220331)
Jan 22 22:27:05.696617 localhost kernel: ACPI: Reserving FACP table memory at [mem 0xfc00a370-0xfc00a463]
Jan 22 22:27:05.696632 localhost kernel: ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc00a2e2]
Jan 22 22:27:05.696643 localhost kernel: ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
Jan 22 22:27:05.696653 localhost kernel: ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
Jan 22 22:27:05.696669 localhost kernel: ACPI: Reserving APIC table memory at [mem 0xfc00a470-0xfc00a4ff]
Jan 22 22:27:05.696679 localhost kernel: ACPI: Reserving HPET table memory at [mem 0xfc00a580-0xfc00a5b7]
Jan 22 22:27:05.696689 localhost kernel: ACPI: Reserving WAET table memory at [mem 0xfc00a5c0-0xfc00a5e7]
Jan 22 22:27:05.696700 localhost kernel: ACPI: Reserving SSDT table memory at [mem 0xfc00a5f0-0xfc00a620]
Jan 22 22:27:05.696709 localhost kernel: ACPI: Reserving SSDT table memory at [mem 0xfc00a630-0xfc00a660]
Jan 22 22:27:05.696719 localhost kernel: No NUMA configuration found
Jan 22 22:27:05.696728 localhost kernel: Faking a node at [mem 0x0000000000000000-0x000000007befefff]
Jan 22 22:27:05.696738 localhost kernel: NODE_DATA(0) allocated [mem 0x7bed4000-0x7befefff]
Jan 22 22:27:05.696748 localhost kernel: Zone ranges:
Jan 22 22:27:05.696761 localhost kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Jan 22 22:27:05.696771 localhost kernel:   DMA32    [mem 0x0000000001000000-0x000000007befefff]
Jan 22 22:27:05.696780 localhost kernel:   Normal   empty
Jan 22 22:27:05.696790 localhost kernel:   Device   empty
Jan 22 22:27:05.696799 localhost kernel: Movable zone start for each node
Jan 22 22:27:05.696808 localhost kernel: Early memory node ranges
Jan 22 22:27:05.696817 localhost kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
Jan 22 22:27:05.696827 localhost kernel:   node   0: [mem 0x0000000000100000-0x000000007befefff]
Jan 22 22:27:05.696836 localhost kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000007befefff]
Jan 22 22:27:05.696847 localhost kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Jan 22 22:27:05.696857 localhost kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Jan 22 22:27:05.696866 localhost kernel: On node 0, zone DMA32: 16641 pages in unavailable ranges
Jan 22 22:27:05.696878 localhost kernel: ACPI: PM-Timer IO Port: 0xb008
Jan 22 22:27:05.696888 localhost kernel: IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-47
Jan 22 22:27:05.696898 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jan 22 22:27:05.696907 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 low level)
Jan 22 22:27:05.696917 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 low level)
Jan 22 22:27:05.696926 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 low level)
Jan 22 22:27:05.696935 localhost kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Jan 22 22:27:05.696945 localhost kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Jan 22 22:27:05.696954 localhost kernel: TSC deadline timer available
Jan 22 22:27:05.696964 localhost kernel: smpboot: Allowing 6 CPUs, 0 hotplug CPUs
Jan 22 22:27:05.696973 localhost kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jan 22 22:27:05.696983 localhost kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
Jan 22 22:27:05.696995 localhost kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000effff]
Jan 22 22:27:05.697015 localhost kernel: PM: hibernation: Registered nosave memory: [mem 0x000f0000-0x000fffff]
Jan 22 22:27:05.697025 localhost kernel: [mem 0x7bf00000-0xfbffffff] available for PCI devices
Jan 22 22:27:05.697035 localhost kernel: Booting paravirtualized kernel on Xen HVM
Jan 22 22:27:05.697044 localhost kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
Jan 22 22:27:05.697054 localhost kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:6 nr_cpu_ids:6 nr_node_ids:1
Jan 22 22:27:05.697065 localhost kernel: percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
Jan 22 22:27:05.697075 localhost kernel: pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
Jan 22 22:27:05.697084 localhost kernel: pcpu-alloc: [0] 0 1 2 3 4 5 - -
Jan 22 22:27:05.697094 localhost kernel: xen: PV spinlocks enabled
Jan 22 22:27:05.697104 localhost kernel: PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
Jan 22 22:27:05.697117 localhost kernel: Fallback order for Node 0: 0
Jan 22 22:27:05.697127 localhost kernel: Built 1 zonelists, mobility grouping on.  Total pages: 499459
Jan 22 22:27:05.697136 localhost kernel: Policy zone: DMA32
Jan 22 22:27:05.697147 localhost kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-17-amd64 root=/dev/mapper/dmroot ro xen_scrub_pages=0 root=/dev/mapper/dmroot console=tty0 console=hvc0 swiotlb=8192 noresume clocksource=tsc quiet modeset=1 pcie_aspm=off pci=nomsi fbdev=1
Jan 22 22:27:05.697157 localhost kernel: PCIe ASPM is disabled
Jan 22 22:27:05.697166 localhost kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-17-amd64 modeset=1 fbdev=1", will be passed to user space.
Jan 22 22:27:05.697176 localhost kernel: random: crng init done
Jan 22 22:27:05.697236 localhost kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Jan 22 22:27:05.697251 localhost kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Jan 22 22:27:05.697262 localhost kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Jan 22 22:27:05.697272 localhost kernel: Memory: 260860K/2030196K available (14342K kernel code, 2331K rwdata, 9048K rodata, 2792K init, 17416K bss, 114984K reserved, 0K cma-reserved)
Jan 22 22:27:05.697286 localhost kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Jan 22 22:27:05.697296 localhost kernel: ftrace: allocating 40159 entries in 157 pages
Jan 22 22:27:05.697306 localhost kernel: ftrace: allocated 157 pages with 5 groups
Jan 22 22:27:05.697315 localhost kernel: Dynamic Preempt: voluntary
Jan 22 22:27:05.697325 localhost kernel: rcu: Preemptible hierarchical RCU implementation.
Jan 22 22:27:05.697335 localhost kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=6.
Jan 22 22:27:05.697345 localhost kernel:         Trampoline variant of Tasks RCU enabled.
Jan 22 22:27:05.697355 localhost kernel:         Rude variant of Tasks RCU enabled.
Jan 22 22:27:05.697364 localhost kernel:         Tracing variant of Tasks RCU enabled.
Jan 22 22:27:05.697376 localhost kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Jan 22 22:27:05.697385 localhost kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
Jan 22 22:27:05.697395 localhost kernel: NR_IRQS: 524544, nr_irqs: 880, preallocated irqs: 16
Jan 22 22:27:05.697408 localhost kernel: xen:events: Using FIFO-based ABI
Jan 22 22:27:05.697418 localhost kernel: xen:events: Xen HVM callback vector for event delivery is enabled
Jan 22 22:27:05.697428 localhost kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Jan 22 22:27:05.697437 localhost kernel: Console: colour VGA+ 80x25
Jan 22 22:27:05.697447 localhost kernel: printk: console [tty0] enabled
Jan 22 22:27:05.697457 localhost kernel: printk: console [hvc0] enabled
Jan 22 22:27:05.697472 localhost kernel: ACPI: Core revision 20220331
Jan 22 22:27:05.697483 localhost kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 30580167144 ns
Jan 22 22:27:05.697492 localhost kernel: APIC: Switch to symmetric I/O mode setup
Jan 22 22:27:05.697507 localhost kernel: x2apic enabled
Jan 22 22:27:05.697519 localhost kernel: Switched APIC routing to physical x2apic.
Jan 22 22:27:05.697528 localhost kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
Jan 22 22:27:05.697538 localhost kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa69e70cf, max_idle_ns: 440795293732 ns
Jan 22 22:27:05.697551 localhost kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4991.97 BogoMIPS (lpj=9983944)
Jan 22 22:27:05.697561 localhost kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Jan 22 22:27:05.697571 localhost kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Jan 22 22:27:05.697581 localhost kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Jan 22 22:27:05.697591 localhost kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Jan 22 22:27:05.697602 localhost kernel: Spectre V2 : Mitigation: Enhanced IBRS
Jan 22 22:27:05.697612 localhost kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Jan 22 22:27:05.697621 localhost kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
Jan 22 22:27:05.697631 localhost kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Jan 22 22:27:05.697643 localhost kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Jan 22 22:27:05.697654 localhost kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jan 22 22:27:05.697663 localhost kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jan 22 22:27:05.697673 localhost kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jan 22 22:27:05.697683 localhost kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Jan 22 22:27:05.697692 localhost kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Jan 22 22:27:05.697702 localhost kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
Jan 22 22:27:05.697711 localhost kernel: x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
Jan 22 22:27:05.697721 localhost kernel: Freeing SMP alternatives memory: 36K
Jan 22 22:27:05.697730 localhost kernel: pid_max: default: 32768 minimum: 301
Jan 22 22:27:05.697740 localhost kernel: LSM: Security Framework initializing
Jan 22 22:27:05.697753 localhost kernel: landlock: Up and running.
Jan 22 22:27:05.697764 localhost kernel: Yama: disabled by default; enable with sysctl kernel.yama.*
Jan 22 22:27:05.697773 localhost kernel: AppArmor: AppArmor initialized
Jan 22 22:27:05.697783 localhost kernel: TOMOYO Linux initialized
Jan 22 22:27:05.697792 localhost kernel: LSM support for eBPF active
Jan 22 22:27:05.697802 localhost kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Jan 22 22:27:05.697813 localhost kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Jan 22 22:27:05.697822 localhost kernel: clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
Jan 22 22:27:05.697832 localhost kernel: Xen: using vcpuop timer interface
Jan 22 22:27:05.697842 localhost kernel: installing Xen timer for CPU 0
Jan 22 22:27:05.697852 localhost kernel: smpboot: CPU0: 12th Gen Intel(R) Core(TM) i7-1260P (family: 0x6, model: 0x9a, stepping: 0x3)
Jan 22 22:27:05.697861 localhost kernel: cpu 0 spinlock event irq 52
Jan 22 22:27:05.697875 localhost kernel: cblist_init_generic: Setting adjustable number of callback queues.
Jan 22 22:27:05.697885 localhost kernel: cblist_init_generic: Setting shift to 3 and lim to 1.
Jan 22 22:27:05.697896 localhost kernel: cblist_init_generic: Setting adjustable number of callback queues.
Jan 22 22:27:05.697907 localhost kernel: cblist_init_generic: Setting shift to 3 and lim to 1.
Jan 22 22:27:05.697917 localhost kernel: cblist_init_generic: Setting adjustable number of callback queues.
Jan 22 22:27:05.697927 localhost kernel: cblist_init_generic: Setting shift to 3 and lim to 1.
Jan 22 22:27:05.697937 localhost kernel: Performance Events: unsupported p6 CPU model 154 no PMU driver, software events only.
Jan 22 22:27:05.697947 localhost kernel: signal: max sigframe size: 3632
Jan 22 22:27:05.697958 localhost kernel: rcu: Hierarchical SRCU implementation.
Jan 22 22:27:05.697968 localhost kernel: rcu:         Max phase no-delay instances is 1000.
Jan 22 22:27:05.697978 localhost kernel: NMI watchdog: Perf NMI watchdog permanently disabled
Jan 22 22:27:05.697988 localhost kernel: smp: Bringing up secondary CPUs ...
Jan 22 22:27:05.697998 localhost kernel: installing Xen timer for CPU 1
Jan 22 22:27:05.698014 localhost kernel: x86: Booting SMP configuration:
Jan 22 22:27:05.698026 localhost kernel: .... node  #0, CPUs:      #1
Jan 22 22:27:05.698038 localhost kernel: cpu 1 spinlock event irq 57
Jan 22 22:27:05.698048 localhost kernel: installing Xen timer for CPU 2
Jan 22 22:27:05.698058 localhost kernel:  #2
Jan 22 22:27:05.698072 localhost kernel: cpu 2 spinlock event irq 62
Jan 22 22:27:05.698081 localhost kernel: installing Xen timer for CPU 3
Jan 22 22:27:05.698090 localhost kernel:  #3
Jan 22 22:27:05.698103 localhost kernel: cpu 3 spinlock event irq 67
Jan 22 22:27:05.698113 localhost kernel: installing Xen timer for CPU 4
Jan 22 22:27:05.698123 localhost kernel:  #4
Jan 22 22:27:05.698133 localhost kernel: cpu 4 spinlock event irq 72
Jan 22 22:27:05.698144 localhost kernel: installing Xen timer for CPU 5
Jan 22 22:27:05.698154 localhost kernel:  #5
Jan 22 22:27:05.698164 localhost kernel: cpu 5 spinlock event irq 77
Jan 22 22:27:05.698178 localhost kernel: smp: Brought up 1 node, 6 CPUs
Jan 22 22:27:05.698189 localhost kernel: smpboot: Max logical packages: 1
Jan 22 22:27:05.698199 localhost kernel: smpboot: Total of 6 processors activated (29951.83 BogoMIPS)
Jan 22 22:27:05.698209 localhost kernel: node 0 deferred pages initialised in 0ms
Jan 22 22:27:05.698220 localhost kernel: devtmpfs: initialized
Jan 22 22:27:05.698231 localhost kernel: x86/mm: Memory block size: 128MB
Jan 22 22:27:05.698241 localhost kernel: ACPI: PM: Registering ACPI NVS region [mem 0xfc000000-0xfc00afff] (45056 bytes)
Jan 22 22:27:05.698251 localhost kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 22 22:27:05.698262 localhost kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Jan 22 22:27:05.698271 localhost kernel: pinctrl core: initialized pinctrl subsystem
Jan 22 22:27:05.698281 localhost kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Jan 22 22:27:05.698291 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Jan 22 22:27:05.698302 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Jan 22 22:27:05.698312 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Jan 22 22:27:05.698327 localhost kernel: audit: initializing netlink subsys (disabled)
Jan 22 22:27:05.698338 localhost kernel: audit: type=2000 audit(1705958824.126:1): state=initialized audit_enabled=0 res=1
Jan 22 22:27:05.698349 localhost kernel: thermal_sys: Registered thermal governor 'fair_share'
Jan 22 22:27:05.698360 localhost kernel: thermal_sys: Registered thermal governor 'bang_bang'
Jan 22 22:27:05.698369 localhost kernel: thermal_sys: Registered thermal governor 'step_wise'
Jan 22 22:27:05.698379 localhost kernel: thermal_sys: Registered thermal governor 'user_space'
Jan 22 22:27:05.698389 localhost kernel: thermal_sys: Registered thermal governor 'power_allocator'
Jan 22 22:27:05.698398 localhost kernel: cpuidle: using governor ladder
Jan 22 22:27:05.698408 localhost kernel: cpuidle: using governor menu
Jan 22 22:27:05.698418 localhost kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Jan 22 22:27:05.698427 localhost kernel: PCI: Using configuration type 1 for base access
Jan 22 22:27:05.698438 localhost kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Jan 22 22:27:05.698448 localhost kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Jan 22 22:27:05.698463 localhost kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Jan 22 22:27:05.698474 localhost kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Jan 22 22:27:05.698486 localhost kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Jan 22 22:27:05.698496 localhost kernel: ACPI: Added _OSI(Module Device)
Jan 22 22:27:05.698507 localhost kernel: ACPI: Added _OSI(Processor Device)
Jan 22 22:27:05.698516 localhost kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Jan 22 22:27:05.698531 localhost kernel: ACPI: Added _OSI(Processor Aggregator Device)
Jan 22 22:27:05.698540 localhost kernel: ACPI: 3 ACPI AML tables successfully acquired and loaded
Jan 22 22:27:05.698551 localhost kernel: xen: --> pirq=16 -> irq=9 (gsi=9)
Jan 22 22:27:05.698561 localhost kernel: ACPI: Interpreter enabled
Jan 22 22:27:05.698609 localhost kernel: ACPI: PM: (supports S0 S3 S4 S5)
Jan 22 22:27:05.698633 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Jan 22 22:27:05.698647 localhost kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jan 22 22:27:05.698659 localhost kernel: PCI: Ignoring E820 reservations for host bridge windows
Jan 22 22:27:05.698676 localhost kernel: ACPI: Enabled 2 GPEs in block 00 to 0F
Jan 22 22:27:05.698688 localhost kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Jan 22 22:27:05.698861 localhost kernel: acpi PNP0A03:00: _OSC: OS supports [Segments HPX-Type3]
Jan 22 22:27:05.699010 localhost kernel: acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
Jan 22 22:27:05.699128 localhost kernel: acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
Jan 22 22:27:05.699148 localhost kernel: acpiphp: Slot [3] registered
Jan 22 22:27:05.699163 localhost kernel: acpiphp: Slot [4] registered
Jan 22 22:27:05.699175 localhost kernel: acpiphp: Slot [5] registered
Jan 22 22:27:05.699188 localhost kernel: acpiphp: Slot [6] registered
Jan 22 22:27:05.699201 localhost kernel: acpiphp: Slot [7] registered
Jan 22 22:27:05.699219 localhost kernel: acpiphp: Slot [8] registered
Jan 22 22:27:05.699233 localhost kernel: acpiphp: Slot [9] registered
Jan 22 22:27:05.699245 localhost kernel: acpiphp: Slot [10] registered
Jan 22 22:27:05.699257 localhost kernel: acpiphp: Slot [11] registered
Jan 22 22:27:05.699275 localhost kernel: acpiphp: Slot [12] registered
Jan 22 22:27:05.699294 localhost kernel: acpiphp: Slot [13] registered
Jan 22 22:27:05.699312 localhost kernel: acpiphp: Slot [14] registered
Jan 22 22:27:05.699331 localhost kernel: acpiphp: Slot [15] registered
Jan 22 22:27:05.699351 localhost kernel: acpiphp: Slot [16] registered
Jan 22 22:27:05.699370 localhost kernel: acpiphp: Slot [17] registered
Jan 22 22:27:05.699389 localhost kernel: acpiphp: Slot [18] registered
Jan 22 22:27:05.699408 localhost kernel: acpiphp: Slot [19] registered
Jan 22 22:27:05.699426 localhost kernel: acpiphp: Slot [20] registered
Jan 22 22:27:05.699451 localhost kernel: acpiphp: Slot [21] registered
Jan 22 22:27:05.699471 localhost kernel: acpiphp: Slot [22] registered
Jan 22 22:27:05.699490 localhost kernel: acpiphp: Slot [23] registered
Jan 22 22:27:05.699512 localhost kernel: acpiphp: Slot [24] registered
Jan 22 22:27:05.699530 localhost kernel: acpiphp: Slot [25] registered
Jan 22 22:27:05.699548 localhost kernel: acpiphp: Slot [26] registered
Jan 22 22:27:05.699566 localhost kernel: acpiphp: Slot [27] registered
Jan 22 22:27:05.699583 localhost kernel: acpiphp: Slot [28] registered
Jan 22 22:27:05.699601 localhost kernel: acpiphp: Slot [29] registered
Jan 22 22:27:05.699619 localhost kernel: acpiphp: Slot [30] registered
Jan 22 22:27:05.699637 localhost kernel: acpiphp: Slot [31] registered
Jan 22 22:27:05.699655 localhost kernel: PCI host bridge to bus 0000:00
Jan 22 22:27:05.699874 localhost kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Jan 22 22:27:05.699992 localhost kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Jan 22 22:27:05.700074 localhost kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Jan 22 22:27:05.700151 localhost kernel: pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfbffffff window]
Jan 22 22:27:05.700226 localhost kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Jan 22 22:27:05.700325 localhost kernel: pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
Jan 22 22:27:05.700435 localhost kernel: pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
Jan 22 22:27:05.700535 localhost kernel: pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
Jan 22 22:27:05.700654 localhost kernel: pci 0000:00:01.1: reg 0x20: [io  0x0000-0x000f]
Jan 22 22:27:05.700738 localhost kernel: pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
Jan 22 22:27:05.700853 localhost kernel: pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
Jan 22 22:27:05.700932 localhost kernel: pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
Jan 22 22:27:05.701010 localhost kernel: pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
Jan 22 22:27:05.701113 localhost kernel: pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
Jan 22 22:27:05.701198 localhost kernel: pci 0000:00:01.3: quirk: [io  0xb000-0xb03f] claimed by PIIX4 ACPI
Jan 22 22:27:05.701280 localhost kernel: pci 0000:00:01.3: quirk: [io  0xb100-0xb10f] claimed by PIIX4 SMB
Jan 22 22:27:05.701378 localhost kernel: pci 0000:00:02.0: [5853:0001] type 00 class 0xff8000
Jan 22 22:27:05.701469 localhost kernel: pci 0000:00:02.0: reg 0x10: [io  0xc000-0xc0ff]
Jan 22 22:27:05.701548 localhost kernel: pci 0000:00:02.0: reg 0x14: [mem 0xf2000000-0xf2ffffff pref]
Jan 22 22:27:05.701634 localhost kernel: pci 0000:00:03.0: [1234:1111] type 00 class 0x030000
Jan 22 22:27:05.701720 localhost kernel: pci 0000:00:03.0: reg 0x10: [mem 0xf3000000-0xf3ffffff pref]
Jan 22 22:27:05.701803 localhost kernel: pci 0000:00:03.0: reg 0x18: [mem 0xf5094000-0xf5094fff]
Jan 22 22:27:05.701890 localhost kernel: pci 0000:00:03.0: reg 0x30: [mem 0xf5080000-0xf508ffff pref]
Jan 22 22:27:05.701996 localhost kernel: pci 0000:00:03.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Jan 22 22:27:05.702097 localhost kernel: pci 0000:00:04.0: [8086:24cd] type 00 class 0x0c0320
Jan 22 22:27:05.702186 localhost kernel: pci 0000:00:04.0: reg 0x10: [mem 0xf5095000-0xf5095fff]
Jan 22 22:27:05.702348 localhost kernel: pci 0000:00:06.0: [10de:1c03] type 00 class 0x030000
Jan 22 22:27:05.702435 localhost kernel: pci 0000:00:06.0: reg 0x10: [mem 0xf4000000-0xf4ffffff]
Jan 22 22:27:05.702519 localhost kernel: pci 0000:00:06.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
Jan 22 22:27:05.702595 localhost kernel: pci 0000:00:06.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
Jan 22 22:27:05.702672 localhost kernel: pci 0000:00:06.0: reg 0x24: [io  0xc200-0xc27f]
Jan 22 22:27:05.702744 localhost kernel: pci 0000:00:06.0: reg 0x30: [mem 0xf5000000-0xf507ffff pref]
Jan 22 22:27:05.702815 localhost kernel: pci 0000:00:06.0: enabling Extended Tags
Jan 22 22:27:05.702887 localhost kernel: pci 0000:00:06.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Jan 22 22:27:05.702958 localhost kernel: pci 0000:00:06.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:06.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
Jan 22 22:27:05.703042 localhost kernel: pci 0000:00:07.0: [10de:10f1] type 00 class 0x040300
Jan 22 22:27:05.703131 localhost kernel: pci 0000:00:07.0: reg 0x10: [mem 0xf5090000-0xf5093fff]
Jan 22 22:27:05.703213 localhost kernel: pci 0000:00:07.0: enabling Extended Tags
Jan 22 22:27:05.703294 localhost kernel: pci 0000:00:07.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:07.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
Jan 22 22:27:05.703307 localhost kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 5
Jan 22 22:27:05.703317 localhost kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Jan 22 22:27:05.703327 localhost kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Jan 22 22:27:05.703337 localhost kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 5
Jan 22 22:27:05.703347 localhost kernel: xen:balloon: Initialising balloon driver
Jan 22 22:27:05.703356 localhost kernel: iommu: Default domain type: Translated
Jan 22 22:27:05.703366 localhost kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Jan 22 22:27:05.703380 localhost kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 22 22:27:05.703390 localhost kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 22 22:27:05.703402 localhost kernel: PTP clock support registered
Jan 22 22:27:05.703411 localhost kernel: EDAC MC: Ver: 3.0.0
Jan 22 22:27:05.703420 localhost kernel: NetLabel: Initializing
Jan 22 22:27:05.703431 localhost kernel: NetLabel:  domain hash size = 128
Jan 22 22:27:05.703439 localhost kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Jan 22 22:27:05.703447 localhost kernel: NetLabel:  unlabeled traffic allowed by default
Jan 22 22:27:05.703455 localhost kernel: PCI: Using ACPI for IRQ routing
Jan 22 22:27:05.703464 localhost kernel: PCI: pci_cache_line_size set to 64 bytes
Jan 22 22:27:05.703476 localhost kernel: e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
Jan 22 22:27:05.703485 localhost kernel: e820: reserve RAM buffer [mem 0x7beff000-0x7bffffff]
Jan 22 22:27:05.703575 localhost kernel: pci 0000:00:03.0: vgaarb: setting as boot VGA device
Jan 22 22:27:05.703760 localhost kernel: pci 0000:00:03.0: vgaarb: bridge control possible
Jan 22 22:27:05.703950 localhost kernel: pci 0000:00:03.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Jan 22 22:27:05.704074 localhost kernel: pci 0000:00:06.0: vgaarb: bridge control possible
Jan 22 22:27:05.704185 localhost kernel: pci 0000:00:06.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Jan 22 22:27:05.704212 localhost kernel: vgaarb: loaded
Jan 22 22:27:05.704235 localhost kernel: hpet: 3 channels of 0 reserved for per-cpu timers
Jan 22 22:27:05.704256 localhost kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Jan 22 22:27:05.704275 localhost kernel: hpet0: 3 comparators, 64-bit 62.500000 MHz counter
Jan 22 22:27:05.704293 localhost kernel: clocksource: Switched to clocksource xen
Jan 22 22:27:05.704358 localhost kernel: VFS: Disk quotas dquot_6.6.0
Jan 22 22:27:05.704379 localhost kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan 22 22:27:05.704397 localhost kernel: AppArmor: AppArmor Filesystem Enabled
Jan 22 22:27:05.704414 localhost kernel: pnp: PnP ACPI init
Jan 22 22:27:05.704591 localhost kernel: system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
Jan 22 22:27:05.704779 localhost kernel: system 00:01: [io  0x08a0-0x08a3] has been reserved
Jan 22 22:27:05.704926 localhost kernel: system 00:01: [io  0x0cc0-0x0ccf] has been reserved
Jan 22 22:27:05.705015 localhost kernel: system 00:01: [io  0x04d0-0x04d1] has been reserved
Jan 22 22:27:05.705029 localhost kernel: xen: --> pirq=17 -> irq=8 (gsi=8)
Jan 22 22:27:05.705041 localhost kernel: xen: --> pirq=18 -> irq=12 (gsi=12)
Jan 22 22:27:05.705052 localhost kernel: xen: --> pirq=19 -> irq=1 (gsi=1)
Jan 22 22:27:05.705064 localhost kernel: xen: --> pirq=22 -> irq=6 (gsi=6)
Jan 22 22:27:05.705154 localhost kernel: pnp 00:05: [dma 2]
Jan 22 22:27:05.705249 localhost kernel: system 00:06: [io  0xae00-0xae0f] has been reserved
Jan 22 22:27:05.705345 localhost kernel: system 00:06: [io  0xb044-0xb047] has been reserved
Jan 22 22:27:05.705359 localhost kernel: pnp: PnP ACPI: found 7 devices
Jan 22 22:27:05.705370 localhost kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Jan 22 22:27:05.705382 localhost kernel: NET: Registered PF_INET protocol family
Jan 22 22:27:05.705393 localhost kernel: IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Jan 22 22:27:05.705404 localhost kernel: tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Jan 22 22:27:05.705413 localhost kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Jan 22 22:27:05.705424 localhost kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Jan 22 22:27:05.705434 localhost kernel: TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
Jan 22 22:27:05.705463 localhost kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jan 22 22:27:05.705477 localhost kernel: MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
Jan 22 22:27:05.705488 localhost kernel: UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Jan 22 22:27:05.705500 localhost kernel: UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Jan 22 22:27:05.705510 localhost kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Jan 22 22:27:05.705520 localhost kernel: NET: Registered PF_XDP protocol family
Jan 22 22:27:05.705611 localhost kernel: pci 0000:00:01.1: BAR 4: assigned [io  0x1000-0x100f]
Jan 22 22:27:05.705705 localhost kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Jan 22 22:27:05.705786 localhost kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Jan 22 22:27:05.705863 localhost kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Jan 22 22:27:05.705947 localhost kernel: pci_bus 0000:00: resource 7 [mem 0xe0000000-0xfbffffff window]
Jan 22 22:27:05.706058 localhost kernel: pci 0000:00:01.0: PIIX3: Enabling Passive Release
Jan 22 22:27:05.706147 localhost kernel: pci 0000:00:00.0: Limiting direct PCI/PCI transfers
Jan 22 22:27:05.706161 localhost kernel: xen: --> pirq=23 -> irq=35 (gsi=35)
Jan 22 22:27:05.706269 localhost kernel: pci 0000:00:07.0: extending delay after power-on from D3hot to 20 msec
Jan 22 22:27:05.706284 localhost kernel: PCI: CLS 0 bytes, default 64
Jan 22 22:27:05.706301 localhost kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa69e70cf, max_idle_ns: 440795293732 ns
Jan 22 22:27:05.706312 localhost kernel: clocksource: Switched to clocksource tsc
Jan 22 22:27:05.706322 localhost kernel: Trying to unpack rootfs image as initramfs...
Jan 22 22:27:05.706332 localhost kernel: Initialise system trusted keyrings
Jan 22 22:27:05.706342 localhost kernel: Key type blacklist registered
Jan 22 22:27:05.706353 localhost kernel: workingset: timestamp_bits=36 max_order=19 bucket_order=0
Jan 22 22:27:05.706363 localhost kernel: zbud: loaded
Jan 22 22:27:05.706376 localhost kernel: integrity: Platform Keyring initialized
Jan 22 22:27:05.706386 localhost kernel: integrity: Machine keyring initialized
Jan 22 22:27:05.706395 localhost kernel: Key type asymmetric registered
Jan 22 22:27:05.706405 localhost kernel: Asymmetric key parser 'x509' registered
Jan 22 22:27:05.706415 localhost kernel: Freeing initrd memory: 23488K
Jan 22 22:27:05.706429 localhost kernel: alg: self-tests for CTR-KDF (hmac(sha256)) passed
Jan 22 22:27:05.706440 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Jan 22 22:27:05.706449 localhost kernel: io scheduler mq-deadline registered
Jan 22 22:27:05.706459 localhost kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Jan 22 22:27:05.706468 localhost kernel: xen: --> pirq=24 -> irq=24 (gsi=24)
Jan 22 22:27:05.706478 localhost kernel: xen:grant_table: Grant tables using version 1 layout
Jan 22 22:27:05.706487 localhost kernel: Grant table initialized
Jan 22 22:27:05.706497 localhost kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jan 22 22:27:05.706507 localhost kernel: Linux agpgart interface v0.103
Jan 22 22:27:05.706517 localhost kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
Jan 22 22:27:05.706527 localhost kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jan 22 22:27:05.706536 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jan 22 22:27:05.706550 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jan 22 22:27:05.706561 localhost kernel: mousedev: PS/2 mouse device common for all mice
Jan 22 22:27:05.706783 localhost kernel: rtc_cmos 00:02: registered as rtc0
Jan 22 22:27:05.706895 localhost kernel: rtc_cmos 00:02: setting system clock to 2024-01-22T21:27:04 UTC (1705958824)
Jan 22 22:27:05.707135 localhost kernel: rtc_cmos 00:02: alarms up to one day, 114 bytes nvram
Jan 22 22:27:05.707155 localhost kernel: intel_pstate: CPU model not supported
Jan 22 22:27:05.707167 localhost kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Jan 22 22:27:05.707181 localhost kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jan 22 22:27:05.707194 localhost kernel: NET: Registered PF_INET6 protocol family
Jan 22 22:27:05.707204 localhost kernel: Segment Routing with IPv6
Jan 22 22:27:05.707214 localhost kernel: In-situ OAM (IOAM) with IPv6
Jan 22 22:27:05.707224 localhost kernel: mip6: Mobile IPv6
Jan 22 22:27:05.707234 localhost kernel: NET: Registered PF_PACKET protocol family
Jan 22 22:27:05.707244 localhost kernel: mpls_gso: MPLS GSO support
Jan 22 22:27:05.707259 localhost kernel: IPI shorthand broadcast: enabled
Jan 22 22:27:05.707272 localhost kernel: sched_clock: Marking stable (365462779, 71921820)->(518704230, -81319631)
Jan 22 22:27:05.707281 localhost kernel: registered taskstats version 1
Jan 22 22:27:05.707291 localhost kernel: Loading compiled-in X.509 certificates
Jan 22 22:27:05.707303 localhost kernel: Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
Jan 22 22:27:05.707315 localhost kernel: Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
Jan 22 22:27:05.707325 localhost kernel: zswap: loaded using pool lzo/zbud
Jan 22 22:27:05.707334 localhost kernel: Key type .fscrypt registered
Jan 22 22:27:05.707344 localhost kernel: Key type fscrypt-provisioning registered
Jan 22 22:27:05.707353 localhost kernel: Key type encrypted registered
Jan 22 22:27:05.707364 localhost kernel: AppArmor: AppArmor sha1 policy hashing enabled
Jan 22 22:27:05.707375 localhost kernel: ima: No TPM chip found, activating TPM-bypass!
Jan 22 22:27:05.707390 localhost kernel: ima: Allocated hash algorithm: sha256
Jan 22 22:27:05.707400 localhost kernel: ima: No architecture policies found
Jan 22 22:27:05.707410 localhost kernel: evm: Initialising EVM extended attributes:
Jan 22 22:27:05.707420 localhost kernel: evm: security.selinux
Jan 22 22:27:05.707430 localhost kernel: evm: security.SMACK64 (disabled)
Jan 22 22:27:05.707440 localhost kernel: evm: security.SMACK64EXEC (disabled)
Jan 22 22:27:05.707450 localhost kernel: evm: security.SMACK64TRANSMUTE (disabled)
Jan 22 22:27:05.707460 localhost kernel: evm: security.SMACK64MMAP (disabled)
Jan 22 22:27:05.707470 localhost kernel: evm: security.apparmor
Jan 22 22:27:05.707480 localhost kernel: evm: security.ima
Jan 22 22:27:05.707509 localhost kernel: evm: security.capability
Jan 22 22:27:05.707520 localhost kernel: evm: HMAC attrs: 0x1
Jan 22 22:27:05.707530 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51712
Jan 22 22:27:05.707545 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51728
Jan 22 22:27:05.707555 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51744
Jan 22 22:27:05.707566 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vif/0
Jan 22 22:27:05.707575 localhost kernel: Freeing unused decrypted memory: 2036K
Jan 22 22:27:05.707585 localhost kernel: Freeing unused kernel image (initmem) memory: 2792K
Jan 22 22:27:05.707595 localhost kernel: Write protecting the kernel read-only data: 26624k
Jan 22 22:27:05.707605 localhost kernel: Freeing unused kernel image (text/rodata gap) memory: 2040K
Jan 22 22:27:05.707615 localhost kernel: Freeing unused kernel image (rodata/data gap) memory: 1192K
Jan 22 22:27:05.707625 localhost kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Jan 22 22:27:05.707635 localhost kernel: Run /init as init process
Jan 22 22:27:05.707644 localhost kernel:   with arguments:
Jan 22 22:27:05.707654 localhost kernel:     /init
Jan 22 22:27:05.707668 localhost kernel:   with environment:
Jan 22 22:27:05.707678 localhost kernel:     HOME=/
Jan 22 22:27:05.707688 localhost kernel:     TERM=linux
Jan 22 22:27:05.707697 localhost kernel:     BOOT_IMAGE=/boot/vmlinuz-6.1.0-17-amd64
Jan 22 22:27:05.707719 localhost kernel:     modeset=1
Jan 22 22:27:05.707731 localhost kernel:     fbdev=1
Jan 22 22:27:05.707741 localhost kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Jan 22 22:27:05.707751 localhost kernel: ACPI: button: Power Button [PWRF]
Jan 22 22:27:05.707761 localhost kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input4
Jan 22 22:27:05.707773 localhost kernel: ACPI: button: Sleep Button [SLPF]
Jan 22 22:27:05.707783 localhost kernel: blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Jan 22 22:27:05.707792 localhost kernel: ACPI: bus type drm_connector registered
Jan 22 22:27:05.707802 localhost kernel:  xvda: xvda1 xvda2 xvda3
Jan 22 22:27:05.707816 localhost kernel: blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Jan 22 22:27:05.707827 localhost kernel: blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Jan 22 22:27:05.707961 localhost kernel: bochs-drm 0000:00:03.0: vgaarb: deactivate vga console
Jan 22 22:27:05.707976 localhost kernel: Console: switching to colour dummy device 80x25
Jan 22 22:27:05.707987 localhost kernel: [drm] Found bochs VGA, ID 0xb0c5.
Jan 22 22:27:05.707998 localhost kernel: [drm] Framebuffer size 16384 kB @ 0xf3000000, mmio @ 0xf5094000.
Jan 22 22:27:05.708008 localhost kernel: [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:03.0 on minor 0
Jan 22 22:27:05.708018 localhost kernel: fbcon: bochs-drmdrmfb (fb0) is primary device
Jan 22 22:27:05.708028 localhost kernel: Console: switching to colour frame buffer device 128x48
Jan 22 22:27:05.708146 localhost kernel: bochs-drm 0000:00:03.0: [drm] fb0: bochs-drmdrmfb frame buffer device
Jan 22 22:27:05.708162 localhost kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
Jan 22 22:27:05.708179 localhost kernel: device-mapper: uevent: version 1.0.3
Jan 22 22:27:05.708190 localhost kernel: device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
Jan 22 22:27:05.708201 localhost kernel:  xvdc: xvdc1 xvdc3
Jan 22 22:27:05.708212 localhost kernel: Adding 1048572k swap on /dev/xvdc1.  Priority:-2 extents:1 across:1048572k SSFS
Jan 22 22:27:05.708224 localhost kernel: EXT4-fs (xvda3): mounted filesystem with ordered data mode. Quota mode: none.
Jan 22 22:27:05.708235 localhost kernel: Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
Jan 22 22:27:05.708248 localhost systemd[1]: Inserted module 'autofs4'
Jan 22 22:27:05.708264 localhost systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
Jan 22 22:27:05.708278 localhost systemd[1]: Detected virtualization xen.
Jan 22 22:27:05.708295 localhost systemd[1]: Detected architecture x86-64.
Jan 22 22:27:05.708308 localhost systemd[1]: No hostname configured, using default hostname.
Jan 22 22:27:05.708319 localhost systemd[1]: Hostname set to <localhost>.
Jan 22 22:27:05.708346 localhost kernel: input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input3
Jan 22 22:27:05.708360 localhost systemd[1]: /lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Jan 22 22:27:05.708372 localhost systemd[1]: Queued start job for default target multi-user.target.
Jan 22 22:27:05.708384 localhost systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1.
Jan 22 22:27:05.708396 localhost systemd[1]: Created slice system-getty.slice - Slice /system/getty.
Jan 22 22:27:05.708408 localhost systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
Jan 22 22:27:05.708420 localhost systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
Jan 22 22:27:05.708434 localhost systemd[1]: Created slice user.slice - User and Session Slice.
Jan 22 22:27:05.708449 localhost systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
Jan 22 22:27:05.708462 localhost systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
Jan 22 22:27:05.708473 localhost systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
Jan 22 22:27:05.708487 localhost systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
Jan 22 22:27:05.708498 localhost systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
Jan 22 22:27:05.708509 localhost systemd[1]: Reached target remote-fs.target - Remote File Systems.
Jan 22 22:27:05.708520 localhost systemd[1]: Reached target slices.target - Slice Units.
Jan 22 22:27:05.708531 localhost systemd[1]: Reached target swap.target - Swaps.
Jan 22 22:27:05.708541 localhost systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
Jan 22 22:27:05.708555 localhost systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
Jan 22 22:27:05.708580 localhost systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
Jan 22 22:27:05.708592 localhost systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
Jan 22 22:27:05.708603 localhost systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
Jan 22 22:27:05.708615 localhost systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
Jan 22 22:27:05.708663 localhost systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
Jan 22 22:27:05.708686 localhost systemd[1]: Listening on systemd-journald.socket - Journal Socket.
Jan 22 22:27:05.708699 localhost systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
Jan 22 22:27:05.708710 localhost systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
Jan 22 22:27:05.708722 localhost systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
Jan 22 22:27:05.708732 localhost systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
Jan 22 22:27:05.708747 localhost systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
Jan 22 22:27:05.708759 localhost systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
Jan 22 22:27:05.708769 localhost systemd[1]: Finished blk-availability.service - Availability of block devices.
Jan 22 22:27:05.708779 localhost systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early...
Jan 22 22:27:05.708808 localhost systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
Jan 22 22:27:05.708828 localhost systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Jan 22 22:27:05.708925 localhost systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
Jan 22 22:27:05.708939 localhost systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
Jan 22 22:27:05.708955 localhost systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
Jan 22 22:27:05.708967 localhost systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Jan 22 22:27:05.708978 localhost systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
Jan 22 22:27:05.708990 localhost systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
Jan 22 22:27:05.709001 localhost systemd[1]: Starting systemd-journald.service - Journal Service...
Jan 22 22:27:05.709012 localhost systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
Jan 22 22:27:05.709023 localhost systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
Jan 22 22:27:05.709034 localhost systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
Jan 22 22:27:05.709045 localhost systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
Jan 22 22:27:05.709056 localhost systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
Jan 22 22:27:05.709067 localhost systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
Jan 22 22:27:05.709082 localhost kernel: loop: module loaded
Jan 22 22:27:05.709095 localhost systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
Jan 22 22:27:05.709106 localhost systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
Jan 22 22:27:05.709117 localhost systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
Jan 22 22:27:05.709127 localhost systemd[1]: modprobe@configfs.service: Deactivated successfully.
Jan 22 22:27:05.709138 localhost systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
Jan 22 22:27:05.709149 localhost systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Jan 22 22:27:05.709160 localhost systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
Jan 22 22:27:05.709170 localhost systemd[1]: modprobe@drm.service: Deactivated successfully.
Jan 22 22:27:05.709182 localhost systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
Jan 22 22:27:05.709192 localhost systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
Jan 22 22:27:05.709204 localhost systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
Jan 22 22:27:05.709222 localhost systemd[1]: modprobe@loop.service: Deactivated successfully.
Jan 22 22:27:05.709233 localhost systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
Jan 22 22:27:05.709244 localhost systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
Jan 22 22:27:05.709255 localhost systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
Jan 22 22:27:05.709267 localhost systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
Jan 22 22:27:05.709278 localhost systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
Jan 22 22:27:05.709289 localhost systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
Jan 22 22:27:05.709300 localhost kernel: fuse: init (API version 7.37)
Jan 22 22:27:05.709310 localhost systemd[1]: modprobe@fuse.service: Deactivated successfully.
Jan 22 22:27:05.709321 localhost systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
Jan 22 22:27:05.709332 localhost systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
Jan 22 22:27:05.709350 localhost systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
Jan 22 22:27:05.709678 localhost kernel: EXT4-fs (xvda3): re-mounted. Quota mode: none.
Jan 22 22:27:05.709697 localhost systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
Jan 22 22:27:05.709710 localhost systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Jan 22 22:27:05.709722 localhost systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
Jan 22 22:27:05.709739 localhost systemd[1]: Starting systemd-sysusers.service - Create System Users...
Jan 22 22:27:05.709751 localhost kernel: lp: driver loaded but no devices found
Jan 22 22:27:05.709767 localhost kernel: ppdev: user-space parallel port driver
Jan 22 22:27:05.709783 localhost systemd[1]: Finished systemd-sysusers.service - Create System Users.
Jan 22 22:27:05.709798 localhost systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
Jan 22 22:27:05.711881 localhost systemd[1]: Started systemd-journald.service - Journal Service.
Jan 22 22:27:05.801961 localhost systemd-journald[267]: Received client request to flush runtime journal.
Jan 22 22:27:05.923902 localhost kernel: piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
Jan 22 22:27:05.932359 localhost kernel: input: PC Speaker as /devices/platform/pcspkr/input/input5
Jan 22 22:27:05.941306 localhost kernel: FDC 0 is a S82078B
Jan 22 22:27:05.944201 localhost kernel: SCSI subsystem initialized
Jan 22 22:27:05.947905 localhost kernel: ACPI: bus type USB registered
Jan 22 22:27:05.948080 localhost kernel: usbcore: registered new interface driver usbfs
Jan 22 22:27:05.948477 localhost kernel: usbcore: registered new interface driver hub
Jan 22 22:27:05.948514 localhost kernel: usbcore: registered new device driver usb
Jan 22 22:27:05.951921 localhost kernel: ehci-pci 0000:00:04.0: EHCI Host Controller
Jan 22 22:27:05.952244 localhost kernel: ehci-pci 0000:00:04.0: new USB bus registered, assigned bus number 1
Jan 22 22:27:05.952412 localhost kernel: ehci-pci 0000:00:04.0: irq 35, io mem 0xf5095000
Jan 22 22:27:05.967905 localhost kernel: ehci-pci 0000:00:04.0: USB 2.0 started, EHCI 1.00
Jan 22 22:27:05.968258 localhost kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
Jan 22 22:27:05.968441 localhost kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 22 22:27:05.968585 localhost kernel: usb usb1: Product: EHCI Host Controller
Jan 22 22:27:05.968685 localhost kernel: usb usb1: Manufacturer: Linux 6.1.0-17-amd64 ehci_hcd
Jan 22 22:27:05.968790 localhost kernel: usb usb1: SerialNumber: 0000:00:04.0
Jan 22 22:27:05.968901 localhost kernel: hub 1-0:1.0: USB hub found
Jan 22 22:27:05.969024 localhost kernel: hub 1-0:1.0: 6 ports detected
Jan 22 22:27:05.987900 localhost kernel: cryptd: max_cpu_qlen set to 1000
Jan 22 22:27:05.988071 localhost kernel: libata version 3.00 loaded.
Jan 22 22:27:05.991883 localhost kernel: AVX2 version of gcm_enc/dec engaged.
Jan 22 22:27:05.995884 localhost kernel: AES CTR mode by8 optimization enabled
Jan 22 22:27:05.995959 localhost kernel: ata_piix 0000:00:01.1: version 2.13
Jan 22 22:27:05.996164 localhost kernel: ata_piix 0000:00:01.1: enabling device (0000 -> 0001)
Jan 22 22:27:05.999924 localhost kernel: scsi host0: ata_piix
Jan 22 22:27:06.000459 localhost kernel: scsi host1: ata_piix
Jan 22 22:27:06.000600 localhost kernel: ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0x1000 irq 14
Jan 22 22:27:06.000623 localhost kernel: ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0x1008 irq 15
Jan 22 22:27:06.183895 localhost kernel: xen: --> pirq=21 -> irq=45 (gsi=45)
Jan 22 22:27:06.184020 localhost kernel: snd_hda_intel 0000:00:07.0: Disabling MSI
Jan 22 22:27:06.191883 localhost kernel: xen_netfront: Initialising Xen virtual ethernet driver
Jan 22 22:27:06.203908 localhost kernel: xen_netfront: backend supports XDP headroom
Jan 22 22:27:06.204019 localhost kernel: vif vif-0: bouncing transmitted data to zeroed pages
Jan 22 22:27:06.228013 localhost kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
Jan 22 22:27:06.231909 localhost kernel: intel_rapl_msr: PL4 support detected.
Jan 22 22:27:06.267903 localhost kernel: nvidia: loading out-of-tree module taints kernel.
Jan 22 22:27:06.268081 localhost kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 22 22:27:06.268117 localhost kernel: Disabling lock debugging due to kernel taint
Jan 22 22:27:06.291904 localhost kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Jan 22 22:27:06.407903 localhost kernel: usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
Jan 22 22:27:06.408235 localhost kernel: usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
Jan 22 22:27:06.408376 localhost kernel: usb 1-1: Product: QEMU USB Tablet
Jan 22 22:27:06.408492 localhost kernel: usb 1-1: Manufacturer: QEMU
Jan 22 22:27:06.408599 localhost kernel: usb 1-1: SerialNumber: 42
Jan 22 22:27:06.432086 localhost kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 245
Jan 22 22:27:06.432201 localhost kernel:
Jan 22 22:27:06.432236 localhost kernel: xen: --> pirq=20 -> irq=40 (gsi=40)
Jan 22 22:27:06.435904 localhost kernel: nvidia 0000:00:06.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Jan 22 22:27:06.436149 localhost kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  525.147.05  Wed Oct 25 20:27:35 UTC 2023
Jan 22 22:27:06.551903 localhost kernel: hid: raw HID events driver (C) Jiri Kosina
Jan 22 22:27:06.631897 localhost kernel: usbcore: registered new interface driver usbhid
Jan 22 22:27:06.632016 localhost kernel: usbhid: USB HID core driver
Jan 22 22:27:06.683890 localhost kernel: input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:04.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input6
Jan 22 22:27:06.684011 localhost kernel: hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:04.0-1/input0
Jan 22 22:27:06.747918 localhost kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  525.147.05  Wed Oct 25 20:21:31 UTC 2023
Jan 22 22:27:06.871891 localhost kernel: [drm] [nvidia-drm] [GPU ID 0x00000006] Loading driver
Jan 22 22:27:06.871970 localhost kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:00:06.0 on minor 1
Jan 22 22:27:06.871998 localhost kernel: xen:xen_evtchn: Event-channel device installed
Jan 22 22:27:06.943923 localhost kernel: memmap_init_zone_device initialised 32768 pages in 0ms
Jan 22 22:27:07.007904 localhost kernel: EXT4-fs (xvdb): mounted filesystem with ordered data mode. Quota mode: none.
Jan 22 22:27:07.137109 Gaming2 kernel: audit: type=1400 audit(1705958827.116:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=793 comm="apparmor_parser"
Jan 22 22:27:07.137137 Gaming2 kernel: audit: type=1400 audit(1705958827.116:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=793 comm="apparmor_parser"
Jan 22 22:27:07.137148 Gaming2 kernel: audit: type=1400 audit(1705958827.116:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=792 comm="apparmor_parser"
Jan 22 22:27:07.137161 Gaming2 kernel: audit: type=1400 audit(1705958827.116:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=796 comm="apparmor_parser"
Jan 22 22:27:07.137171 Gaming2 kernel: audit: type=1400 audit(1705958827.116:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=796 comm="apparmor_parser"
Jan 22 22:27:07.137178 Gaming2 kernel: audit: type=1400 audit(1705958827.116:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=796 comm="apparmor_parser"
Jan 22 22:27:07.137191 Gaming2 kernel: audit: type=1400 audit(1705958827.120:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=800 comm="apparmor_parser"
Jan 22 22:27:07.137204 Gaming2 kernel: audit: type=1400 audit(1705958827.120:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=799 comm="apparmor_parser"
Jan 22 22:27:07.143053 Gaming2 kernel: audit: type=1400 audit(1705958827.120:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/x86_64-linux-gnu/lightdm/lightdm-guest-session" pid=791 comm="apparmor_parser"
Jan 22 22:27:07.195902 Gaming2 kernel: snd_hda_intel 0000:00:07.0: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
Jan 22 22:27:07.759887 Gaming2 kernel: NVRM: GPU 0000:00:06.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
Jan 22 22:27:08.172004 Gaming2 kernel: NVRM: Xid (PCI:0000:00:06): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
Jan 22 22:27:08.172176 Gaming2 kernel: NVRM: GPU 0000:00:06.0: GPU has fallen off the bus.
Jan 22 22:27:08.172235 Gaming2 kernel: NVRM: A GPU crash dump has been created. If possible, please run
                                       NVRM: nvidia-bug-report.sh as root to collect this data before
                                       NVRM: the NVIDIA kernel module is unloaded.
Jan 22 22:27:08.172277 Gaming2 kernel: NVRM: GPU 0000:00:06.0: RmInitAdapter failed! (0x23:0xf:1413)
Jan 22 22:27:08.172326 Gaming2 kernel: NVRM: GPU 0000:00:06.0: rm_init_adapter failed, device minor number 0
Jan 22 22:27:08.179920 Gaming2 kernel: NVRM: GPU 0000:00:06.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
Jan 22 22:27:08.180728 Gaming2 kernel: NVRM: GPU 0000:00:06.0: RmInitAdapter failed! (0x22:0x56:760)
Jan 22 22:27:08.180810 Gaming2 kernel: NVRM: GPU 0000:00:06.0: rm_init_adapter failed, device minor number 0
Jan 22 22:27:09.908185 Gaming2 kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:07.0/sound/card0/input7
Jan 22 22:27:09.909015 Gaming2 kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:07.0/sound/card0/input8
Jan 22 22:27:09.909056 Gaming2 kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:07.0/sound/card0/input9
Jan 22 22:27:09.909065 Gaming2 kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:07.0/sound/card0/input10
The nvidia driver is borked, somehow it doesn’t like MSI-X interrupt. GPU passthrough not working on 4.2-rc4 while it worked on 4.2-rc3 · Issue #8631 · QubesOS/qubes-issues · GitHub
If instead of the nvidia driver you use the nvidia-open driver, it will work
I thought nvidia-open (the open source right?) was only available since 20x0 series? I’m using a 1060
edit: It’s not in the compat list GitHub - NVIDIA/open-gpu-kernel-modules: NVIDIA Linux open GPU kernel module source
sorry, you are probably right. So need to find why nvidia driver doesn’t like MSI-X :slight_smile:
I have a RX 480 lying around, but I don’t want to use a separate screen, NVIDIA can easily do discrete rendering, not AMD. Maybe it’s time to try the virtualGL thing :confused:
Thank you very much for your help, I’ll stay tuned to the GitHub issue to try again later :pray:
What are the usual troubleshooting steps if the display stays black?
I solved most of my issues from my post Need help with gpu passtrough
I added some kernel parameters, blacklisted drivers (followed the instructions for the amdgpu on the archwiki).
sudo dmesg does not give me any error messages anymore(related to the gpu (I think?)) but now everything shows up in my primary display again(when I set pci=nomsi and from what I can tell the driver loads with the gpu properly). Running gnome-shell or xorg.sh runs and does not crash but does not display much (sometime completely bugged windows on the primary display). The display connected to the GPU only flashes when starting or powering the VM off.
No Idea what I should do jus’t cant get anything to my other display.
[user@gpu-test ~]$ sudo lspci -vvvnns 00:06.0
00:06.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT] [1002:73df] (rev c5) (prog-if 00 [VGA controller])
	Subsystem: ASRock Incorporation Device [1849:5210]
	Physical Slot: 6
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 40
	Region 0: Memory at 400000000 (64-bit, prefetchable) [size=16G]
	Region 2: Memory at 800000000 (64-bit, prefetchable) [size=256M]
	Region 4: I/O ports at c200 [size=256]
	Region 5: Memory at f2000000 (32-bit, non-prefetchable) [size=1M]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [64] Express (v2) Legacy Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 16GT/s, Width x16
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
			 10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS-
			 AtomicOpsCap: 32bit+ 64bit+ 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
			 AtomicOpsCtl: ReqEn+
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
			 EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
			 Retimer- 2Retimers- CrosslinkRes: unsupported
	Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
[user@gpu-test ~]$ sudo dmesg | grep amdgpu
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6.12-100.fc38.x86_64 root=/dev/mapper/dmroot ro root=/dev/mapper/dmroot console=tty0 console=hvc0 swiotlb=8192 noresume clocksource=tsc radeon.cik_support=0 amdgpu.cik_support=1 radeon.si_support=0 amdgpu.si_support=1 pci=nomsi modprobe.blacklist=nouveau,nvidea,radeon,bochs-drm xen_scrub_pages=0
[    0.023610] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6.12-100.fc38.x86_64 root=/dev/mapper/dmroot ro root=/dev/mapper/dmroot console=tty0 console=hvc0 swiotlb=8192 noresume clocksource=tsc radeon.cik_support=0 amdgpu.cik_support=1 radeon.si_support=0 amdgpu.si_support=1 pci=nomsi modprobe.blacklist=nouveau,nvidea,radeon,bochs-drm xen_scrub_pages=0
[    4.584478] [drm] amdgpu kernel modesetting enabled.
[    4.584615] amdgpu: Virtual CRAT table created for CPU
[    4.584658] amdgpu: Topology: Add CPU node
[    4.601820] amdgpu 0000:00:06.0: amdgpu: Fetched VBIOS from ROM
[    4.601842] amdgpu: ATOM BIOS: 113-EXT800254-L04
[    4.647464] amdgpu 0000:00:06.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[    4.647774] amdgpu 0000:00:06.0: amdgpu: VRAM: 12272M 0x0000008000000000 - 0x00000082FEFFFFFF (12272M used)
[    4.647805] amdgpu 0000:00:06.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[    4.647831] amdgpu 0000:00:06.0: amdgpu: AGP: 267894784M 0x0000008400000000 - 0x0000FFFFFFFFFFFF
[    4.649064] [drm] amdgpu: 12272M of VRAM memory ready
[    4.649302] [drm] amdgpu: 1916M of GTT memory ready.
[    6.645218] amdgpu 0000:00:06.0: amdgpu: STB initialized to 2048 entries
[    6.647895] amdgpu 0000:00:06.0: amdgpu: Will use PSP to load VCN firmware
[    6.811948] amdgpu 0000:00:06.0: amdgpu: RAS: optional ras ta ucode is not available
[    6.826164] amdgpu 0000:00:06.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[    6.826489] amdgpu 0000:00:06.0: amdgpu: smu driver if version = 0x0000000e, smu fw if version = 0x00000012, smu fw program = 0, version = 0x00413b00 (65.59.0)
[    6.827054] amdgpu 0000:00:06.0: amdgpu: SMU driver if version not matched
[    6.827322] amdgpu 0000:00:06.0: amdgpu: use vbios provided pptable
[    6.885058] amdgpu 0000:00:06.0: amdgpu: SMU is initialized successfully!
[    7.119791] amdgpu: HMM registered 12272MB device memory
[    7.121659] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[    7.121967] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[    7.122415] amdgpu: Virtual CRAT table created for GPU
[    7.123043] amdgpu: Topology: Add dGPU node [0x73df:0x1002]
[    7.123295] kfd kfd: amdgpu: added device 1002:73df
[    7.123550] amdgpu 0000:00:06.0: amdgpu: SE 2, SH per SE 2, CU per SH 10, active_cu_number 40
[    7.124047] amdgpu 0000:00:06.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[    7.124290] amdgpu 0000:00:06.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[    7.124526] amdgpu 0000:00:06.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[    7.124755] amdgpu 0000:00:06.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[    7.124976] amdgpu 0000:00:06.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[    7.125204] amdgpu 0000:00:06.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[    7.125422] amdgpu 0000:00:06.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[    7.125637] amdgpu 0000:00:06.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[    7.125846] amdgpu 0000:00:06.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[    7.126060] amdgpu 0000:00:06.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 11 on hub 0
[    7.126260] amdgpu 0000:00:06.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[    7.126459] amdgpu 0000:00:06.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[    7.126653] amdgpu 0000:00:06.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[    7.126847] amdgpu 0000:00:06.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[    7.127050] amdgpu 0000:00:06.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[    7.127240] amdgpu 0000:00:06.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[    7.131035] amdgpu 0000:00:06.0: amdgpu: Using BACO for runtime pm
[    7.131967] [drm] Initialized amdgpu 3.54.0 20150101 for 0000:00:06.0 on minor 1
[    7.138384] amdgpu 0000:00:06.0: [drm] fb1: amdgpudrmfb frame buffer device
[   13.851755] snd_hda_intel 0000:00:07.0: bound 0000:00:06.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
I mean it’s loaded correctly right? So I should be able to just start a X session right?
I’ve give it another try, I just updated dom0 and I guess it’s related to this problem
local:
    python3-xen:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
    xen:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
    xen-hvm-stubdom-linux:
        new:
            4.2.9-1.fc37
        old:
            4.2.8-1.fc37
    xen-hvm-stubdom-linux-full:
        new:
            4.2.9-1.fc37
        old:
            4.2.8-1.fc37
    xen-hypervisor:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
    xen-libs:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
    xen-licenses:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
    xen-runtime:
        new:
            2001:4.17.3-1.fc37
        old:
            2001:4.17.2-8.fc37
No luck for the nvidia driver
Got it working thanks to this. Was just to stupid to properly configure X.
Noobs like me would appreciate if someone could write a short guide on how to properly configure XFCE/GNOME with a standard fedora/debian template. And maybe even Wayland?
So far it’s working perfectly and in hindsight this was way to easy.
The only thing that sucks is that my GPU likes to scream like it gets tortured under load. (was a nice surprises, pls send help if this is related to some settings/drivers).
Once I’m able to have the nvidia driver to work again, I plan to write more detailed instructions. :+1:
I wish I wrote more about my previous setup because I don’t really remember what I did :sweat:
If you follow Create a Gaming HVM and replace “i3” (my favorite WM) by “xfce4”/“xfce4-session”, it should work too
Pasted your script into my rc.local and it works like a charm. Just had issues with the xorg.conf
I never configured X manually and for some reason refused to open the archwiki for this.
BTW what about Wayland compositors? They should just work…? Would like to install Hyprland (the best WM).
How can I configure X so that it displays on the secondary display and also have the seamless integration with qubes os? Tried some stuff but can’t get it to work right now.
Also some tips for keyboard/mouse passtrough? I have a extra USB controller connected to the VM but they only work sometimes. (hope its not an issue with the controller, passtrough with the qubes-usb-proxy works fine)
If you take the file AOC.conf in the guide and modify the line “Driver” and “Modeline”, it should work. If it doesn’t, then there is an issue
can’t get your xorg.conf to work tried for almost two hours. The generated one works without any issues.
Currently the proprietary nvidia driver doesn’t work when MSI-X is supported in stubdom domain.
Could be interesting to do a bit of reverse engineering to understand how MSI-X is used by the nvidia driver.
I will try later when I have more time, if someone else is interested in doing that it could be interesting to share idea/progress
Update: I started to reverse engineer the nvidia driver and nvidia kernel. It is going to take quite some time.
did a clean install fix your no bootable device issue?
Clean 4.2 install did not help, I have to stay with 4.1 with the stubdom or else it doesn’t work at all unfortunately.
The stubdom from the testing repo solves the issue on 4.2
I just copied the stubdom files from a system with testing enabled, seems to work just fine.
