Crazy this is
OK, so the dual monitor issue came back BUT instead of “mirroring” monitor1 & 2 I have this crazy sh*t happening now. I log in just fine and everything is up and running (sys-net-sys-firewall-sys-whonix,dom0). Once I launch a “domain” monitor 1 goes black and taskbar over to monitor 2. I go to display settings and mirrored isn’t check and I only have 1 monitor instead of 2 showing. IF i shut down whatever “domain” I have running which made this happened… O’ IDK vault or work, all of the sudden the other monitor 1 comes back up. Then I get a “POP-UP” box saying DOM0 [display settings] with 4 little pictures to chose from…mirrored,extended, monitor 1 on/monitor 2 off, monitor 1 off. monitor 2 on. I pick “extended”, it changes back, I click apply. All is well, until I launch a “domain” and again have to do this like 4 or 5 times then it stays to “extended”.
