Crash and reboot after booting to Qubes OS
Hi, i recently installed Qubes OS on my Legion 5 17ACH6H. At first startup system booted up normally and it even let me to do some first-boot setup (such as which template to use, etc).
It started okay, but afterwards it crashed and rebooted. After that, each time i boot to Qubes OS it starts, shows mouse cursor, opens initial setup (which i did last time), freezes and crashes, then reboots. I cant acces terminal throught ctrl+alt+f2 e.g., I am thinking problem could lie in the GPU - NVidia RTX 3060, but i have switchable graphics with AMD Radeon
Try reinstalling Qubes OS again and see if you are able to reproduce the crash at the same step.
Reinstalled, same thing. Flash drive is okay, media was tested.
Okay, try switching to AMD Radeon integrated graphics through the BIOS, save the changes, then start Qubes OS afterwards.
My bios allows me to only choose from discrete graphics or swichable, i decided to disable dGPU in the grub for the boot like this nouveau.modeset=0 rd.driver.blacklist=nouveau modprobe.blacklist=nouveau
However still having the same error.
Also tried modifying grub to disable nvidia card using acpi and tried nomodeset, no changes
Is it possible to install Qubes OS on a different hard drive instead?
No, i unfortunately have only this one, though i am planning to buy an external SSD in future, but not in the nearest one.
@Akronym1 Has your problem been fixed?
I have the similar situation, but on a MacBook Pro Intel-based. Booting and LUKS password window are successful, but afterwards only black screen with freezed mouse cursor and a few seconds later the computer is rebooting. I don’t know why. Tried several approaches by GPT but nothing has solved the problem. The OS installation and first configuration were successful before.
Hi Andy1 - and welcome to the forum :slight_smile:
Can you boot your computer from a usb-stick and share the output of:
smartctl -x /dev/name-of-your-drive
The name-of-your-drive is probably something like sda, sdb, … or nvme..
Did you try the Qubes OS v4.2.4 or the Qubes OS v4.3-RC1 … the later is a Release Candidate, so still a test – but it could be nice to know if it works better for your, than the current release.
Note: I have a plan, to test the v4.3-RC1 on my MacBook pro (intel) … the old installer only worked, if I selected BTRFS …
:slight_smile:
Hi Chris,
Thank you for your quick reply.
I have installed the stable version 4.2.4.
Also tried it with acpi=off, but difficult without the keyboard afterwards :wink: So this has not been a solution. Please let me know if it works later with version 4.3.
Best regards
Andy
Hi Andy1
I made a lot of assumptions and forgot to ask some basic questions:
  • is it a fresh install?
  • do you know a bit about what’s inside your MacBook (some kind of GPU?)
  • what happens if you remove quiet and add qubes.skip_autostart to the kernel line in GRUB
It will be a few days, before I can test Qubes OS v4.3-RC1 on the MacBook … but I’ll let you know about it …
:slight_smile:
Yes, it is an absolutely fresh install.
GPU is Intel HD Graphics 630 + AMD Radeon Pro 555.
qubes.skip_autostart works! Is there a logical explanation for this?
Hi Andy1
As part of the boot, Qubes OS tries to start a set of qubes that you’ll “most likely need anyway” … and sometimes this can result in a hard crash.
If you look in the Qubes Manager, you can try to start some of the qubes you have set to autostart – be warned, that it might trigger the reboot (!?) … if you can narrow it down to starting a specific qube, you can disable autostart for that one, until it can be corrected.
:slight_smile:
Wow, thanks for that information.
You are an expert. :slightly_smiling_face::+1:
