Cpupools not saving
i have performed editing of the cpu pools and after reboot it reset all pool back to just pool-0 even after setting it all up.
how to make it save and be normal the way it should?
Set it using a script executed by systemd service on boot:
Setting a script still means that I have to manually change the virtual systems every time they start. Nothing about it is permanently configured. …
