CPU Temperature is Higher using Qubes OS with KDE Plasma
Hi!
I have relatively old laptop, but not that old as far as I got it reading the forum. I used arch before that and my laptop was 44-50 degrees celsius on mid load.
I installed and used Qubes for around week now and even with no load at all, simply with sys-* vms running I’m getting above 55 degrees. And I can feel that heat. It’s very annoying.
I enabled SMT, but it didn’t affect CPU temp at all.
Under mid load its get hot with aroun 65-75 degrees, and under heavy load it just melt with 85+.
Do you have the same?
Can I do something software-wise to reduce the temp?
I really don’t mind to reduce the power of the cpu a bit if this would help.
P.S. I prefer to not disclose the model of the CPU if it’s ok.
How could anyone compare anything based on technical understanding or experience without knowing what your hardware is?
No. But security.
I don’t mean to sound rude. However, someone who enables SMT while at the same time being afraid of “disclosing” the CPU type seems a bit inconsistent to me.
As long as there is no further information, I recommend reading the documentation:
As far as cooling is concerned: If your machine is older, check the cooling paste and clean the fan(s) of dust.
No, but I do not consider the Librem 14 a relatively old laptop for Qubes OS.
It will be difficult to help with no specific information, but:
  • Does the HCL have any similar hardware? Read the details for power management issues.
  • In dom0, xentop can give information about running VMs.
  • In the sys-* and other VMs, ‘top’ can also give some clues.
  • Look for powe management messages in dom0 boot message log.
  • Are all the fans running?
It seems unlikely that there is no sign of a process causing extra heat.
Another question to ask yourself:
  • Are you sure you are comparing data from the same sensors?
https://forum.qubes-os.org/t/cpu-temperature-sensors-in-qubes-4-1/
It seems like the cause was KDE Plasma, because when I switched to XFCE there was no issue.
But I absolutely can’t stand XFCE. I’ve been running KDE since forever.
The most sad part is that there’s no specific indications for what is actually causing it, I didn’t use any third party widgets nor did I run any 3rd party software in dom0 vm, however the plasmashell was spiking occasionally up to 10-15%.
I’m running the latest stable release of Qubes with KDE installed as stated in the docs.
Is it still supported?
Based on your information, it sounds like it is supported fine.
@FranklyFlawless is correct… based on the very limited information we have.
My experience of Plasma vs XFCE is the exact opposite, and I haven’t touched Plasma for years, but I do remember a lot of graphical eye-candy, or visual effects, to be more polite.
Is it possible that you have excess CPU use because your graphics card driver is not installed/not working, and the rendering is done by the CPU?
OTOH, I would expect to see a lot of forum posts about it, but I only found a very old one:
