I would really appreciate if i could get a detailed guide on HOWTO install tripwire and snort in Qubes the right way…
I read on the forum those are the best intrusion detection systems in Qubes, and i think they should be installed by default, but they are not.
Could i get a link or a guide on howto install those in Qubes 4.1 the right way?
snort
just install in template of sys-firewall or a dedicated vm as in normal fedora, afaik
more detail:
How to install software | Qubes OS
tripwire
i haven’t tried it, maybe install in all template?
Thanks! Do you mean the service sys-firewall for snort, nethogs and similar sniffers?
Is that the best place to sniff traffic in qubes overall?
I will need to read more about tripwire, and how to sniff in qubes. Thanks
no, i mean a services qubes
might, it easy to remember were it is but a dedicated qubes also good too
Yes i meant the service sys-firewall. I tried that just now…
Thanks.
Another thing… If running a VPN you can’t sniff traffic because it’s encrypted.
Let’s say a system would be compromised. You would have to turn off the VPN and then sniff the traffic to see if you got some trojan/virus or similar am i right?
No way to sniff the traffic otherwise in between right?
that were a dedicated qubes come in
Can you explain more detailed? How can that one sniff if Qubes is connected to a VPN?
" Set up a ProxyVM as a VPN gateway using iptables and CLI scripts"
If that setup is used… Does the disposable whonix or qubes overall go through a VPN, or only the qubes you set to use a VPN then?
I’m not good with networks really…
Could you please explain some how the traffic works in Qubes a bit? How can i sniff traffic in Qubes, and also when i have a VPN and stuff… Also, which part of Qubes would be compromised firstly if an attacker tried to hack Qubes? You could install tripwire there i guess also, and maybe wireshark also?
I appreciate your knowledge on this here on this forum. Because i lack it, but want to understand some more. Where to install wireshark, tripwire in qubes and so on in the best way.
Hardening Qubes could be good, and to have an IDS. Every linux dist should have it really in my opinion… Open source.
Thanks!
you can still use if your ids is in between sys-vpn (for example) and your qubes
depend on how hacker get to your system
same network? sys-net!
browser? the qubes you run browser!
file? the qube you run the file
… and so on
Thanks. So IDS between sys-vpn and qubes is sys-firewall then? That’s where snort or any other should be? How do you put it between? I would be good if i can sniff, and nobody else…
The traffic is encryped so yeah… I did not think it was possible to sniff end-to-end encryption that’s all, i don’t know how it works really…
Ok, good to know that sys-net is the first one getting “owned”. Then they work up and take over dom0 i guess…
Also, yes i know about browser exploits existing, and files…
What are the best tools to harden Qubes with? Tripwire, snort, wireshark, what else?
no
ie: you qubes is “personal”
then you should place it between “personal” and sys-vpn
by that way it will see the unencrypted traffic
it very hard to do so, impractical for most hacker
as same as normal linux (selinux is a common example)(might tricky for you to find how to do it in qubes in the most effective way)
I have not read on how to reply like you do, so i’m answering in my own way now.
no
How do i do that? Where do i place it? Not in sys-firewall then as you wrote earlier?
Ok, how do they hack Qubes then?
I’m not good with linux so i would not know how to harden it… But i did read that selinux was unsecure, i could be wrong… It was shady or something, that was the impression i got last time i read about it.
I meant more with tools… hardening. Wireshark, tripwire and so on… close down stuff that are unnecessary, but i’m sure the expert hackers and coders that have created Qubes have thought about the security like that.
Still…
An IDS would not mess up anything in my opinion…
in dedicated qubes
they can just hack the appvm and persist there until reboot
afaik, there no malware for qubes because it doesn’t worth it
the only way to attack dom0 is xen flaw, which is unlikely to be found easily
ok, could you link me some info on how to set up snort on dedicated qubes? Wireshark could be used in sys-firewall right? Or do you need to create a dedicated qube, and then what? What setting do you change and so on?
Ok, so that’s how they work… Yeah well the annoying thing about hackers or crackers is that they don’t even ask for permission…
They just break in. And theres not much one can do. You can try to get some protection like VPN and a secure OS, that’s it…
Good to know if hackers don’t easily hack Qubes and Xen, but i bet some do.
It’s more secure then windows though!
might (for encrypted connection, it better for a dedicated qubes unless you want to see encrypted connection)
i don’t use wireshark for normal traffic monitoring, it very time consuming, so i don’t know
you can do a lot (not antivirus, all av are scam)
there more
that can’t be avoided
Thanks, but i’m still looking for a detailed guide or advice on how to install tripwire and/or snort in qubes.
If anyone has experience, please do help out.
Can anyone here help me with links or a guide on how to install tripwire and snort in Qubes please? That would be great! Please link all you got.
