Hi, I just discovered AMD SEV-SNP, I see it’s limited to enterprise CPUs but if it was available to consumer CPUs, would it make QubesOS secured even if the hypervisor got compromised ? (and could it even be implemented in QubesOS ?)
There is an issue about SEV on Github: Consider support for AMD's SEV for Ryzen PRO (4750U) Laptop · Issue #6105 · QubesOS/qubes-issues · GitHub
That is about SEV in general though, it seems the advantages of SEV-SNP specifically are not yet discussed.
Thanks !
