After having multiple errors when trying to update to 4.1 from 4.0 when performing
sudo qubes-dom0-update --enablerepo=qubes-dom0-current-testing qubes-dist-upgrade
I get an error “failed to specify release version please use --releasever to specify version”. to correctly specify the version of upgrade, would I enter:
sudo qubes-dom0-update --enablerepo=qubes-dom0-current-testing qubes-dist-upgrade --releasever=r4.1.0-rc2
as the whole command?
hmm, have the strange feeling this “specify the release version” isn’t the full truth… Recently did the update also and it just was a wrong command I was using… It worked without any --releasever switch.
Could swear
should work, didn’t it? Otherwise try your command…
qubes-dom0-current-testing should be the correct repo
releasever=r4.1.0-rc2 should also be correct
PS.: have you tried
sudo qubes-dom0-update -y qubes-dist-upgrade
also? Maybe the package isn’t testing anymore???
