I cloned a template VM and enabled network access to it for installing and using some third party software. This cloned VM is appearing as Template VM. Can I mark it as a standalone VM type?
I don’t know if you can just mark it as StandaloneVM, but you can create new StandaloneVM qube based on this cloned TemplateVM and then remove cloned TemplateVM.
I guess you can change property klass using qvm-prefs.
I’ve tried it but it didn’t work. It seems that it’s a read-only preference.
Ya. This sounds good and would work for me. Thanks.
