Consecutive replies
We're sorry, but your email message to ["replies+b8e626d6cc232c2a48993afe1b6f3564@forum.qubes-os.org"] (titled Re: [Qubes Forum] 3isec-qubes-cacher breaks fedora-42-xfce update [User Support]) didn't work.
Reason:
No more than 3 consecutive replies are allowed. Please edit your previous reply, or wait for someone to reply to you.
If you can correct the problem, please try again.
I did not know there was a limit like this. I do not think I can edit a
previous reply. Is this one of those things where I am at wrong level or
is it insurmountable?
I have replied on that topic, breaking your consecutive reply pattern.
Neither, this is the default limit for Discourse configuration, but the value can be changed by the admin.
Thanks to both of you.
@unman I’m guessing this could get annoying for email users, since there is no way to edit one’s post.
Is this a problem you (or others) using the forum via email run into often? If so, I’d say I could check with other mods on increasing this.
afaik this is the first time. Now I know of the limit I’ll make sure I
dont hit it in the future. (Gathering thoughts before hitting y is
a good idea in any case.)
