I’m running Q4.0.4, fully patched. Sys-usb is based on Debian 10 Min template. (But I also tried with a Fedora33 template. The result is the same.)
I try to attach the Gemini PDA to an AppVM. Phzsically the PDA is connected via an USB cable. It is recognized as MediaTek_Gemini_Wifi on sys-usb:2-1. On the Gemini an Android 7.1.1 is installed. The system is set to “file transfer”.
If I try to attach the PDA to a VM via the GUI, I get an error “QubesException - Device attach failed”. If Itry to attach it via CLI (qvm-device usb attach {AppVM} sys-usb:2-1 I simply get “Device attach failed:” without any further information.
Any idea how to solve the issue?
Thx in advance.
Michael
