Confused about split-gpg gui under 4.2
Hi I am getting around to migrating to qubes 4.2 and have a bit of a brain block figuring out the way to setup split-gpg on it. I am likely dense but all the guides seem to cover 4.1 method and don’t include the new gui.
What I have done so far
in the gui: enabled splig gpg and set all qubes can ask for access to key-vault
on my thunderbird vm: /rw/config/gpg-split-domain contains key-vault
on my key-vault vm: .profile for “user” contains export QUBES_GPG_AUTOACCEPT=86400
This so far sort of works but not properly.
  1. Thunderbird VM will prompt me to choose which vault contains my keys
  2. I will be prompted to accept the access to the domain for 1 day
  3. Each and every encrypted email I look at I am prompted to select which domain contains my gpg keys
From 4.1 guide linked to in the community guides and in the split-gpg gui in dom0 there is the option to set /etc/qubes-rpc/policy/qubes.Gpg to include along lines of @anyvm @anyvm ask,default_target=key-vault but that seems to not be correct now given the split gpg gui has a policy for qubes.Gpg and /etc/qubes-rpc/policy/qubes.Gpg does not exist
If I try to modify the gui to include a default domain I get a parsing error
qubes.Gpg * @anyvm key-vault ask,default_target=key-vault
Is there something I am overlooking to get my thunderbird domain to stop getting me to pick the appvm my keys exist in?
This policy format has been deprecated since 4.2.
As a starting point, you can use the new qubes-split-gpg2 and follow the installation steps from the github repo:
For reference, the package is named split-gpg2 in templates and split-gpg2-dom0 in dom0.
As for Thunderbird, I can’t really help since I’ve never used it with this setup.
I see. so what is the point of the gui setup in dom0 that comes with 4.2 if it has been depreciated?
The policy format and the file path in your post coming from the guide are deprecated. The GUI creates a custom file with the new policy format in /etc/qubes/policy.d/50-config-splitgpg.policy
The only issue here is that it uses the “old” version and not the new one. So if you want to use split-gpg2, you need to create a new file in the policy.d directory with the policy provided in the configuration steps from the github repo.
ah ok I understand now.
So I think my only issues is how to use the GUI to tell the qubes they should default to “key-vault” which at the moment I am being made choose on each encrypted mail access.
As far as I can see, you are not able to use “default_target” from the GUI.
If you want this to happen, you need to create a new file with a higher priority.
For example, you can create this file /etc/qubes/policy.d/30-user-splitgpg.policy with this in it:
qubes.Gpg	*	@anyvm	key-vault	ask	default_target=key-vault
Thanks that did help in that it now knows to pre-select the key-vault though it still asks for it on each email read.
If you want to get rid of the confirmation window, you can change ask to allow and default_target= to target=, but this would mean that all qubes will be able to access your key-vault qube without any confirmation. So be sure to change @anyvm to the name of the qube you use to read your mails.
nice thank you for all this!
And is there a way to still keep the ask and like the old method have a time limit ala the old QUBES_GPG_AUTOACCEPT
Am I missing documentation for the policy.d/*-splitgpg.policy files, if not I can look into creating something but I’m can’t be the only one who wants this sort of setup so I guess I am missing :slight_smile:
I just tried to recreate your setup @curbs94 but i didnt managed to do so. Thunderbird is telling me “the secret key to decrypt this message is not available”
Do you have any idea what my problem is. I would be happy do even arrive at the point where you started this topic :slight_smile:
My setup
  • Split gpg enabled in qubes global config gui
  • Config-file in thunderbird-vm contains to key-vault
  • thunderbird is configured to use external pgp-key as described in Split GPG | Qubes OS
I am sorry for spamming this question in your topic, i dont know if this is the right way to use this forum.
Anyways, would be happy to get help
I am also trying to get Thunderbird working with qubes-split-gpg2, but I am encountering problems as well. I have followed the installation instructions on GitHub, and when I run gpg -K on the thunderbird-vm, it shows “split-gpg2: connected” and displays the sec#. However, Thunderbird is unable to decrypt or encrypt emails (thunderbird is configured to use external pgp-key), displaying the error message “The secret key that is required to decrypt this message is not available.” Additionally, when I run gpg -K in the thunderbird-vm, I get the following message: “gpg: problem with fast path key listing: Forbidden - ignored.”
Has anyone managed to get Thunderbird mail encryption working with qubes-split-gpg2? Thanks!
I am getting confused by the existence of qubes-split-gpg2. The documentation on qubes-os.org doesn’t refer to it: Split GPG | Qubes OS
Do I really need this qubes-split-gpg2 stuff, or am I good with following the official documentation as it is right now (which uses qubes-gpg-split).
The documentation on the Qubes website refers to the first version of split-gpg. For split-gpgv2 you need to follow the configuration on Github instead. Then you could probably follow the documentation for everything related to usage, but I can’t confirm that it works with the v2 version.
Why is there v2 for split-gpg? Is v1 unfit for use?
I don’t think there is much to do, from my salt states I do this:
  • write the qube name with the gpg key in /rw/config/gpg-split-domain of the appvm
  • install qubes-gpg-split-dom0 in dom0
  • install qubes-gpg-split in templates
  • use qubes-gpg-client-wrapper in your AppVM instead of gpg command (making a symlink to it as gpg or gpg2 in $PATH can be useful to avoid configuring gpg binary everywhere)
I don’t think there is more to do, there is a split GPG GUI now in the Qubes OS global configuration manager.
@solene is this a reply to my latest comment, or to some other comment in this thread?
it was more a quick and short how-to :sweat_smile: this should works fine with this, I don’t understand why it should be more complicated
how do you install the new split-gpg2 package? qubes-dom0-update --action=search gpg2 doesn’t find it.
EDIT: the package name is split-gpg2-dom0
You don’t?
I recently tried to use Split GPG 2 and rewrote the documentation at the same time, I don’t recall the need to install anything in dom0. You need to install it in the templates of the client and server qubes.
You can take a look at my current attempt to rewrite the docs.
First, you need to search for *gpg2* in order to find the package.
Then, it will only install some python tests and this policy file: /etc/qubes/policy.d/30-user-gpg2.policy which content is:
# Policy for qubes.Gpg2 service.
# Add line like this:
# qubes.Gpg2 + gpg-client-vm @default allow target=gpg-server-vm
# to allow the VM named 'gpg-client-vm' use (but not export) the private keys
# in 'gpg-server-vm'.
Yes, it is a file full of comments! :slight_smile:
