Configure the system to not use the secondary GPU so it can be attached to a guest
Howdy folks,
Got an issue with my GPU, I attach it to the guest and when it starts my system just reboots.
It’s a secondary GPU a PCIEx4 slot. Works as a GPU if I want it to for Domain-0 but I want to pass it through to the guest instead.
I remember there being a post ages ago about this that I saw, but I can’t find it anywhere and searching resolves nothing. It was probably for an older version of Qubes anyway.
How would I remove the PCIE slot from Domain-0 and all forms until it is added to the guest please?
Thanks.
Thanks for that, but it still provides the issue of the card not being seen properly.
I installed the drivers and so NTOP can see it, but nothing else can see it…
LSPCI was able to always see it, after I installed LSPCI that is.
Had to install the NVIDIA drivers after downloading them from NVIDIA…
Nothing in the repos for them.
Things only seem to be using the Qubes GPU…
Did you try:
Create a Gaming HVM
or:
Create a Gaming HVM
Yes, I followed that, I can see the GPU in lspci, nvtop can see it.
But when I get something to try to use the GPU for video related things, it decides to just use the Qubes variant. Other things just can’t see the actual card, they can’t even see the Qubes video card, but they can use it.
So this is all very confusing. Hope someone can help that doesn’t just repeat what they already said again and again and again…
Again, which one did you follow:
[Case: No dedicated screen, mouse or keyboard] VirtualGL and vulkan
or
[Case: Dedicated Screen, mouse and keyboard] Linux guest — Integration with QubesOS
I read through them all to try to find a resolution.
I am not understanding exactly what stage you have got to, but if the hardware PCI device is available in a VM then maybe this recent thread could help.
I did see you mentioned immediate reboot when you start the VM. It can happen if there are other devices in the same IOMMU group which have not been passed through. There are other possible causes though.
No, that recent thread isn’t the issue, good thought though thanks.
I actually passed that issue as I forgot about the hide variable for Domain-0, which doesn’t do much other than stop it from being used as a display in Domain-0 and allows for passthru.
My issue is that it isn’t being seen properly. As in the device isn’t being passed through properly.
I did notice when I attach a USB card to a guest, when I plug things into it they appear in Domain-0 as well as the guest. So this may be an issue with Qubes and the way it handles the passthrough. but I did try the USB card with XEN instead of using the Qubes way, and that didn’t work either.
So it is confusing as to why it just won’t work now when it did work in Qubes 3. What got broken?
If the USB controller is on the PCI bus, then I think this can only mean that there is still a driver binding to the device in Dom0. Is it a combined device? Some usb controllers show up as two or 3 PCI BDFs.
When you look at the IOMMU group - which should contain all the associated devices - lspci -k must show “Kernel driver in use : pciback” for every one (in Domzero).
The groupings are really essential - for GPUs they often reveal an audio device which must be passed through with the VGA controller*, so it is equally important to know them. On some cheaper chipsets it seems there can be full length PCI slots which share a group with a whole bunch of essential hardware.
Edit: * maybe it is not always necessary to PT the other devices, but it must not be possible for any driver to try to violate the IOMMU protections (this is how I understand it, but I might be wrong).
