Hello Everybody,
I am having partial success using the instructions in h**ps://www.qubes-os.org/doc/qubes-builder/ to compile a custom kernel. After issuing make linux-firmware linux-kernel the kernel compiles successfully (compiled kernel rpm install in dom0 still fails. See Related Notes below).
However, the compiled kernel version is not equal to kernel-latest. The compiled version is stable-5-4-80-1. I would like to compile v5.8.16-1-latest.
@fepitre, I know you have kindly suggested in https://github.com/QubesOS/qubes-issues/issues/5453 that:
“You can bump the rel file h**ps://github.com/QubesOS/qubes-linux-kernel/blob/master/rel to ensure to upgrade properly your dom0 version.”,
but I don’t know what “bump[ing] the rel file” means.
Since I don’t want to pester that issue thread with unrelated kernel compilation problems, I would like to kindly ask you if you could elaborate here a little further.
In the meantime, I’ve tried setting BRANCH_linux_kernel = v5.8.16-1-latest in builder.conf but I get a “Tag has the wrong hash” verification error during Updating sources for linux-kernel. I’ve tried setting CHECK=insecure-no-check below line NO_SIGN=1 but the error persists.
Any other suggestions would be greatly appreciated. Thanks in advanced for your support
Related Notes:
- The instructions in h**ps://www.qubes-os.org/doc/qubes-builder/ produce a Zstd rpm which dom0 then fails to install in dom0. Researching I found out there is a dirty fix in https://groups.google.com/g/qubes-users/c/_VCVM9AdhEM/m/RdgZKa4yAQAJ
sed -i ‘/%define version/a%define _binary_payload w6.gzdio’ qubes-src/linux-kernel/kernel.spec.in
- This user also mentions that “qubes-src/linux-kernel has questionable rules for selecting
linux-.tar.gz (which fails) rather than linux-.tar.xz.” and proposes the following fix:
sed -i ‘s/^SRC_FILE.*gz/SRC_FILE := linux-${VERSION}.tar.xz/’ qubes-src/linux-kernel/Makefile
sed -i ‘s/^Source0.*gz/Source0: linux-%{upstream_version}.tar.xz/’ qubes-src/linux-kernel/kernel.spec.in
Both Notes 1 and 2 were needed to install the compiled kernel successfully in dom0.
Regards,
SU
