Global clipboard notifies me that copying is complete. Attempting to paste with the cntrl + shift V then cntrl+v returns nothing.
Error Log shows:
Invalid PMaxSize multiple times
XShmAttach failed for window
open var/run/qubes/qubes-clipboard.bin.xevent: no such file or directory
Window 0x2400ldc is still set as transient for xxxx window VM tried to destroy it.
connect: no such file or directory
Any help would be great as I am unable to troubleshoot properly and share logs without my clipboard.
It also matters when one changes the active window to the “pasteVM”. Waiting until after beginning the paste sequence with ctrl+shift+v will not paste anything, even if one selects the pasteVM as the active window before ctrl-v.
Might be unrelated but I have a dom0 and fedora update that I am failing to install, due to errors but cant get help with until I fix my clipboard : ’ )
I doubt this is the problem, but it’s still worth checking your clipboard RPC policies. Are there any entries that deny pasting when you check the following in dom0?
This is almost a fresh install of qubes I am running. I have only setup a VPN service and one additional vm with the network set to the VPN service, so I really haven’t been tinkering to much with the configs.
** I did delete the personal qube but I don’t think this should not have any effect afaik
